Old 13-10-2009, 12:51 AM   #1
barra265t
Default Ripping a metal post out of the ground...
Is it alright to use a car to rip a metal post out of the ground? Contemplating tying a chain to the towbar of an xr6t and using it to rip out a large metal post set in concrete that used to be a gate. Will this cause any damage to the car.. pretty sure a 1700 odd kg car would win 100 times over a 10 odd kg metal post.
barra265t is offline   Reply With Quote Multi-Quote with this Post
Old 13-10-2009, 01:09 AM   #2
Racecraft
they call me Tibbo
Racecraft's Avatar
sedan or ute? how deep into the ground and how much concrete in the hole?
Old 13-10-2009, 01:14 AM   #3
Unco
Unco's Avatar
angle grinder?
try it by all means, but i don't think your 1700kg car will have much of a chance against a metal post buried in concrete...
Unco is offline   Reply With Quote Multi-Quote with this Post
Old 13-10-2009, 01:16 AM   #4
388cube_edxr8
Nutty Professor
388cube_edxr8's Avatar
It depends on how much traction you have, how you want to do it, and how stubborn the post is. I have heard success, and horror stories.
If the car is an auto and you have a lot of traction, you risk bending the rear axle if you floor it. If its a manual, you risk burning out the clutch.
Either way, if there is no traction, you will just burn rubber, which will be cool, but not really achieve anything.
If you do rip it out with the car, keep driving, and slow down gently. Drive in a circle if you must. If you pull it out and then slam on the brakes, the fencepost, concrete and all will likely hit the back of your nice XR6.
Whatever you do, don't tie the cable on loose and take a run up with the car to tighten the slack. That will more than certainly bend the chassis or something expensive.
Yes the car will win 100 times over a 10kg post, but the planet Earth is a bit bigger than your car, and attaching the post to it opens up a whole new playing field.
If you do try it, let us know how it goes.
Originally Posted by Jeremy Clarkson
If you buy a rubbish car, what you are saying is "I have no interest in cars." If you have no interest in cars, you have no interest in driving, and if you have no interest in something, it means you're no good at it, which means you must have your driving license taken away.
388cube_edxr8 is offline   Reply With Quote Multi-Quote with this Post
Old 13-10-2009, 01:19 AM   #5
atec77
if you can afford the damage
best to use some chain and a long strong lever to lift it from the ground you have soaked and dug some
A certain Italian said " Give a lever and a fulcrum and I will move worlds"
Old 13-10-2009, 01:40 AM   #6
Swordsman88
Getting it done.....
Swordsman88's Avatar
While it may be cool to try it, frankly i'm not a fan. For starters its alot harder to 'pull' these sorts of things out of the ground then it is to dig them out. Soften the soil around it at the very least...and follow the advise of the earlier posters.
However, i truly doubt it will work. Traction will be the big issue...the car (esp if manual) will go into wheelspin pretty easilly, particulary if you are on grass/dirt. and yes, a run up is a bad idea.
I remember years ago (when i was living in FNQld) a farmer brought what one would call a 'small' tractor from his farm to the front yard of his house to rip out some things because he was landcaping the yard. He pulled a pre loosened mailbox out withouth too much trouble (low gear, high torque 4 tonne tractor will do that) but funny enough, because it was a 2wd tractor he couldn't pull out a pretty small tree stump. It would have been a tree nothing more than 6 metre high when it was growing and a trunk of 5-6 inches. He softened the soil, used low gear, gunned it repeatedly and all he did was succeed in digging in the rear wheels. And yes he did try to remove the trea earlier with his SS ute....it didnt' work just lots of wheelspin on his driveway. Eventually he had to come back with a much larger 4wd plough pulling tractor to get the tree out, and it fought him all the way LOL! From memory his (70 year old) father ended up being the one to succeed....watching that from the from porch was great entertainment of an afternoon....
Dynamic White 1995 EF XR6 Auto
Now with:
Pacemaker 4499s
Lukey Catback Exhaust
Chrome BA XR-style tip
Airdam Mounted CAI with modified (bellmouth) airbox
Trip Computer install
KYB shocks
Bridgestone Adrenalin tyres
Coming Soon:
Exhaust Overhaul.....
Swordsman88 is offline   Reply With Quote Multi-Quote with this Post
Old 13-10-2009, 07:03 AM   #7
XR Martin
XR Martin's Avatar
If its a 10kg post then you should be able to lift it out...
This sounds like a whole lot of fail. Please get video of this so we can see the result.
2004 BA wagon RTV project.
Old 13-10-2009, 07:28 AM   #8
4Vman
4Vman's Avatar
Use a long chain and get a run at it.......... :
335 S/C GT: The new KING of Australian made performance cars..
4Vman is offline   Reply With Quote Multi-Quote with this Post
Old 13-10-2009, 07:33 AM   #9
Sam
shake it a bit, dig around it a little bit, stick a hose down it and flood the sucker, you need leverage to get it out. If you do use your car, video it please
Sam is offline   Reply With Quote Multi-Quote with this Post
Old 13-10-2009, 07:40 AM   #10
Charliewool
Bolt Nerd
Charliewool's Avatar
Reverse being the lowest gear... I'd also suggest tying on to the front bar and doing it backwards combined with the above suggested "run-up"
Ohhh.. And be sure your seatbelt is firmly fastened!!
Current vehicles.. Yamaha Rhino UTV, SWB 4L TJ Jeep, and boring Lhd RAV4
Bionic BF F6... UPDATE: Replaced by Shiro White 370z 7A Roadster. SOLD
Workhack: FG Silhouette XR50 Turbo ute (11.63@127.44mph) SOLD
2 wheels.. 2015 103ci HD Wideglide.. SOLD
SOLD THE LOT, Voted with our feet and relocated to COSTA RICA for some Pura Vida!
(Ex Blood Orange #023 FPV Pursuit owner : )
Charliewool is offline   Reply With Quote Multi-Quote with this Post
Old 13-10-2009, 08:26 AM   #11
duaned
duaned's Avatar
I once pulled a tree stump out with an AU wagon ( company car.) After a lot of wheelspin the mongrel came out, however the rope snapped back and hit my brother in the knee! At the time he was very sick, and the knee part furthur compounded the problem! So if you do try it, make sure there is no person around the attempted extraction site!
duaned is offline   Reply With Quote Multi-Quote with this Post
Old 13-10-2009, 08:52 AM   #12
AzuR
AzuR's Avatar
I pulled about 10 of my mates tree stumps out from his front yard, using my old xr8 ute, just used some crane slings tied together, slowly dipped the power on and they just popped out, although we had a close call when one of the slings slipped off and took a large chunk of wood with it, missing my car just haha.
|His| 2010 E3 Maloo ute, 20th Anniversary Edition, Build 022 of 100 in Black of course :P
All 20th Ann extras
: |||Mods To Date - Lowered all Round on Walkinshaw Springs. More to come . Tuned by ?????- Power - . ||| :
|Hers| 2009 LV XR5 Turbo in Silhouette
AzuR is offline   Reply With Quote Multi-Quote with this Post
Old 13-10-2009, 09:03 AM   #13
Allen
You win again, gravity!!!
Allen's Avatar
Why does this thread remind me so much of that Mythbusters episode where they loop a cable around the diff of the RC Cop car to recreate the American Graffiti scene?
In all seriousness, just dig the post out.
1966 Fairlane 500 XL
Allen is offline   Reply With Quote Multi-Quote with this Post
Old 13-10-2009, 09:52 AM   #14
sgt_doofey
sgt_doofey's Avatar
Having just pulled two posts out of the ground recently, I would also advise just digging them out. There is a lot less potential for damage if you don't use the car. Think about what would happen with a tightened rope/chain/whatever once that post finally gives out?
It took me about an hour with a jack hammer, spade and crowbar to get the two posts out.
Cheers,
Sam.
Old 13-10-2009, 09:52 AM   #15
GasoLane
Former BTIKD
GasoLane's Avatar
Definitely the way to go.... 50 metres should be long enough.
Make sure that you're doing at least 100kmh when the chain tightens.
If this fails a couple of sticks of gelignite should do it.
Oh, and don't forget to ask your parents permission before doing either.
Old 13-10-2009, 01:34 PM   #16
NC_Lane
NC Fairlane Ghia
NC_Lane's Avatar
hmm maybe stap a few blocks of c4 and blow the sucker sky high :P
Curent Rides:
-NC Fairlane Ghia 3.9L
-XC RallyPack Ute 5.8L
-AU Falcon Wagon 4.0L Still Stock
-80 Series LandCruiser 4.5 LPG
NC_Lane is offline   Reply With Quote Multi-Quote with this Post
Old 13-10-2009, 01:46 PM   #17
PHATAL
PHATAL's Avatar
Mate make us a video . . . . FAIL FTW LOL
ZG Fairlane 500 351 - First car - Now restoring! - LOOKING FOR ZG PARTS - BLACK AUTO CONSOLE - BLACK DASH PAD - BLACK SEAT BELTS (WITH THE METAL BUCKLES) -
RIGHT REAR CHROME TRIM
XF Falcon S Update EFI - SOLD
EL2 XR8 - SOLD
BF F6 RSPEC #139 - SOLD
Now rocking the SZ Territory Titanium Petrol Family Beast
PHATAL is offline   Reply With Quote Multi-Quote with this Post
Old 13-10-2009, 02:21 PM   #18
LANKY 1
Are the Supercars on yet?
LANKY 1's Avatar
Is it just a post with a bit of concrete down the bottom or a post in a full slab of concrete?
I would suggest like whinching someone out with a 4WD, u should put a bag filled with sand or something on the cable so if it does break it will fall to the ground and not hit anyone(or knee!)
A Ford win is a good win!
V8 dreamteam
1st: 2012, 2021
2nd: 2015, 2016, 2020, 2022, 2023, 2024
3rd: 2014, 2018, 2019
LANKY 1 is offline   Reply With Quote Multi-Quote with this Post
Old 13-10-2009, 02:35 PM   #19
Springfield_Johny
Springfield_Johny's Avatar
Your forgetting that ataching it to a car and pulling it, is not lifting it but rather drying to drag the whole thing through the earth like a big plough so the 10 kilo post suddenly has resistance applied to it, the resistance could be equivelent to anywhere from 12kg to 2000kg. Where on the car are you going to atach the rope to & will that be strong enough to take the load
Daily drive 2010 Mitsubishi triton single cab turbo diesel
1968 XT Falcon (project yet to be started)
Springfield_Johny is offline   Reply With Quote Multi-Quote with this Post
Old 13-10-2009, 02:44 PM   #20
Rubidium
Rubidium's Avatar
so what you are really trying to do is rip the concrete block out of the ground, you really need to consider its dimensions and weight.
assuming the pole is strong, you may want to consider attaching your rope to the top of the pole for better leverage
2005 BF XR6T, Winter White
2010 PK XLT, Winning Blue
Rubidium is offline   Reply With Quote Multi-Quote with this Post
Old 13-10-2009, 03:03 PM   #21
The Yeti
The Yeti's Avatar
and when it comes out with a bang, how are you going to stop it before it comes through your back window?
If you do it be sure to video it
Pariahs C.C.
What could possibly go wrong
I post images with postimg.cc (so I don’t forget)
The Yeti is offline   Reply With Quote Multi-Quote with this Post
Old 13-10-2009, 03:11 PM   #22
FreddyDUZ747
FreddyDUZ747's Avatar
Is anyone taking bets?
FreddyDUZ747 is offline   Reply With Quote Multi-Quote with this Post
Old 13-10-2009, 03:16 PM   #23
burnz
VFII SS UTE
burnz's Avatar
use a snatch strapp, that way the shock wont hurt your car.
and when it comes out and lands on your roof you wont have to carry it..
GO SOUTHS
Old 13-10-2009, 03:19 PM   #24
tickford2001
please please please let there be video!
tickford2001 is offline   Reply With Quote Multi-Quote with this Post
Old 13-10-2009, 03:38 PM   #25
jamesson1980
jamesson1980's Avatar
...then after it's done, film the remaining half of the car doing donuts in triumph!
customer: "My car seems to be changing colour and growing wings"
Ford Service: "That's normal, they all do that after about 10,000km
2009 FG XR6, Ego Paint, Darkest possible tint, Sunroof, Black Vic number plates. No performance mods. Born To Be Mild
jamesson1980 is offline   Reply With Quote Multi-Quote with this Post
Old 13-10-2009, 03:54 PM   #26
Airmon
King of the Fairy's.
Airmon's Avatar
He managed to move a warship on that principle, Im sure you will be able to manage a post.
www.bseries.com.au/airmon
They say less talk more action,
I say more torque less traction!
Airmon is offline   Reply With Quote Multi-Quote with this Post
Old 13-10-2009, 04:19 PM   #27
The Yeti
The Yeti's Avatar
Staring bugs bunny and daffy duck
Pariahs C.C.
Old 13-10-2009, 06:04 PM   #28
phantomxr6t
Do not attach chain to tow ball if you are going to tow it out with your car, there is a 50% chance ball will snap and then it will be firmly lodged in the back of your head. I have seen them snap by d/heads using snatch straps on there 4wd.
phantomxr6t is offline   Reply With Quote Multi-Quote with this Post
Old 13-10-2009, 06:31 PM   #29
frd906
should use a bungy cord
Welder/Fabricator at Beaudesert Exhuast
Posted by Xcabbi, Does it slap or rattle? Rattle is more to do with timing chains and tensioners. Slap is more to do with lifters, rings, bearings or GENIII boat anchors
frd906 is offline   Reply With Quote Multi-Quote with this Post
Old 13-10-2009, 06:41 PM   #30
XDV800
I highly recommend that you pop the post out with a small chemical reaction.
Simply purchase a bottle of pwdered pool chlorine, pour this down the post until it is just about 10 cm from the top. The open a bottle of brake fluid, tip it into the top of the post and let it sit ontop, IMMEDIATLY STEP BACK 20 PACES, then marvel as your post suddenly becomes a faraway neighbours problem.
Seriously you will probably do LESS damage to your car if you ram into it with the front of your xr6t...
Use a Landcruiser.
XDV800 is offline   Reply With Quote Multi-Quote with this Post
