Old 09-11-2009, 05:50 PM   #1
Francis
Default Has anyone done a used oil test with Castrol Edge oils?
Hi guy's just wondering if anyone has done a oil test using any of the Castrol Edge oils.
Francis is offline   Reply With Quote Multi-Quote with this Post
Old 09-11-2009, 06:25 PM   #2
4VCLEVO
XA GT
4VCLEVO's Avatar
This might sound stupid, but what sort of oil test?
XA GT, 6.848sec 1/8 mile @ 101.68mph
4VCLEVO is offline   Reply With Quote Multi-Quote with this Post
Old 09-11-2009, 06:31 PM   #3
BOSHOG
avenge me
BOSHOG's Avatar
an oil test is only good as a starting point for future tests to see what is degrading in your engine/driveline etc.
a one off test is kinda pointless
FULL OF Autotech GOODNESS!
BOSHOG is offline   Reply With Quote Multi-Quote with this Post
Old 09-11-2009, 07:15 PM   #4
pottery beige
What he said..
Old 10-11-2009, 06:03 PM   #5
Francis
Im just interested to know the Zinc and Cal levels of the 0w 40 and the 10w 60.
Old 10-11-2009, 06:14 PM   #6
Whoosha
AU DIE HARD
Whoosha's Avatar
Have a read of this supplyed by Russ W, interesting, but as with most quality oils if you change them and filters at regular intervals most std,engines would be good for 300ks plus these days
http://www.fordforums.com.au/vbporta...article&id=333
Originally Posted by Riksta
Old 10-11-2009, 09:10 PM   #7
Tote
Tote's Avatar
I've recently changed from Corse Plus to Edge 25W50 in the clevo and subjectively it seems to quieten down the valve train a little bit better. Pressure when hot is in the same ballpark as the Corse Plus.
Regards,
Tote
Go Home, Your Igloo is on Fire....
Tote is offline   Reply With Quote Multi-Quote with this Post
