Go Back   Australian Ford Forums > Club and Speciality Forums > Ford Car Clubs > Mid North Coast Ford Owners Club
Closed Thread
Old 29-11-2009, 05:26 PM   #1
thunderoo
Blueprint of Perfection
thunderoo's Avatar
Default Technical
See how we go in this section, when the club gets its own website. It can be set out more easier. If you have any technical videos, on anything to do with vehicles, send me the link via email. I hope some of this info will be usefull to some.
HIS
426 RWHP / 1100 NM OF TORQUE 393 CLEVELAND
AFD 2V CYLINDER HEADS
1974 XB COUPE
NO TRACTION AT EASTERN CREEK
HERS
BOSS 260 03 XR8 SEDAN
COLD AIR INTAKE BY PERFORMER SHAKERS
FULL X-FORCE QUAD TIPPED EXHAUST SYSTEM
thunderoo is offline
Old 29-11-2009, 05:45 PM   #2
thunderoo
thunderoo's Avatar
Default Carb Adjustment
CARB INSTALLATION
CARB REMOVAL
DOUBLE PUMPER INSTALL AND ADJUSTMENT
POWER VALVE SELECTION
CARB PUMP CAM SELECTION
SETTING CURB IDLE
HIS
1974 XB COUPE
HERS
Old 29-11-2009, 05:48 PM   #3
thunderoo
thunderoo's Avatar
Default How To Work Out Your Diff Ratio
HOW TO WORK OUT YOUR DIFF RATIO
HIS
1974 XB COUPE
HERS
Old 29-11-2009, 06:02 PM   #4
thunderoo
thunderoo's Avatar
Default How To Install A Distributer
HOW TO INSTALL A DISTRIBUTER
DISTRIBUTER SET UP / IGNITION LEADS AND PLUGS INSTALL
HIS
1974 XB COUPE
HERS
Old 29-11-2009, 06:14 PM   #5
thunderoo
thunderoo's Avatar
Default Camshaft Installation
CAMSHAFT INSTALLATION
VALVE LASH ADJUSTMENT
CAMSHAFT BREAK IN PROCEDURE
HIS
1974 XB COUPE
HERS
Old 29-11-2009, 06:39 PM   #6
thunderoo
thunderoo's Avatar
Default Nos
WHAT IS NOS
NOS DRY FOGGER SYSTEM
MULTIPORT WET FOGGER SYSTEM
NOS WET FOGGER SYSTEM
NOS SPRAY BAR
HIS
1974 XB COUPE
HERS
Old 29-11-2009, 07:07 PM   #7
thunderoo
thunderoo's Avatar
Default 351 Windsor
351 WINDSOR
HIS
1974 XB COUPE
HERS
Old 29-11-2009, 07:14 PM   #8
thunderoo
thunderoo's Avatar
Default Fuel Pump / Water Pump / Thermostat Install
FUEL PUMP / WATER PUMP / THERMOSTAT INSTALL
HIS
1974 XB COUPE
HERS
Old 29-11-2009, 07:29 PM   #9
thunderoo
thunderoo's Avatar
Default Cylinder Bore Honning
CYLINDER BORE HONNING
CYLINDER BLOCK MACHINING
CONECTING RODS
HIS
1974 XB COUPE
HERS
Closed Thread
