Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Race Brakes Sydney
Race Brakes Sydney Street and race performance pad / rotor combinations as well as brake upgrades and Exedy clutch kits. Website Link
Old 04-12-2009, 01:31 AM   #1
Scaffy
Rlegaur Mbemer
Default New rotors for EL GT brakes
Hi, I have a set of EL GTs on my XR8 and want to replace the current rotors to a set of slotted ones. I was hoping to get a set of DBA 4000 series but nothing is listed. Are they available, or would you recommend something else?
Thanks
[YEAH NAH] Red EL XR8 with Trick Flow top end kit, 70mm tb, 73mm maf, 24lb injectors, tweecer, 3.73s & tired T5 = 275rwhp & 13.155@105mph NA. 12.375@116.73 N2O - Off the road, awaiting 347 293ci and Astro Performance gear-kitted T5 (A5)
White EL Series II XR8, manual, high flow cats, single 3" exhaust and Quarterhorse = 236rwhp and 14.18@97.5mph - E7 heads FTW! - SOLD
Scaffy is offline   Reply With Quote Multi-Quote with this Post
Old 04-12-2009, 12:44 PM   #2
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Thanks
If you have a EL GT then the rotors are a DBA 136 SL and SR but no 4000 series was done for them so only the DBA street series for $355 each are available.If you have a EL GT calipers on your car from a brake conversion then the rotors may be different depending on who made the kit.
MATTHEW PEARCE
RACE BRAKES SYDNEY = When you want it to stop
Street to track is what we expertise in
Phone 02 9609 1101
sales@racebrakessydney.com.au
www.racebrakessydney.com.au
Old 05-12-2009, 12:53 PM   #3
Scaffy
Rlegaur Mbemer
I got the brakes off another car which had GT rims and ecu, so I'm guessing it all came off a GT at some stage.
So those rotors from DBA are cross-drilled and slotted, right? Do you have anything that is just slotted, which perform well?
Old 05-12-2009, 01:05 PM   #4
FLOORED
Race Brakes Sydney
FLOORED's Avatar
The rotors i quoted are slotted only and are replacement for the original GT 330mm brakes.
If the other car was not a GT and /or the uprights are not GT then this could be a aftermarket brake upgrade which may or may not have the factory disc and hub in one assembly.Sorry to confuse but the GT kit without GT uprights will not bolt straight up to an E series and there are 3 or 4 aftermarket kits that use different rotors.
MATTHEW PEARCE
Phone 02 9609 1101
Old 05-12-2009, 08:27 PM   #5
Scaffy
Rlegaur Mbemer
If this is any help, here's a pic of the uprights and rotors. I don't know if you can tell by these pics whether it's
Old 07-12-2009, 10:44 AM   #6
FLOORED
Race Brakes Sydney
FLOORED's Avatar
I can't see the mounting holes of the uprights clearly but i am guessing the rotor at the bottom of the picture is the one you are replacing and by the looks of it could be a 3 piece deal .
1.The hub
2.Alloy hat
3.The disc
You will need to find the origins of this kit to replace the rotors as i haven't seen it before.
MATTHEW PEARCE
Phone 02 9609 1101
Old 07-12-2009, 11:57 PM   #7
Scaffy
Rlegaur Mbemer
The upright for the new brakes is the bottom one, I'm pretty sure. So I take it these aren't EL GTs with a different rotor then? And the rotors you quoted me will more than likely not fit?
Old 08-12-2009, 10:53 AM   #8
FLOORED
Race Brakes Sydney
FLOORED's Avatar
It is hard to see what you have there as it seems to be two different sets of uprights and rotors and with the shadow making it dark over the uprights it is hard to see what you have so can you take another photo in the light and also is the top rotor a std e series disc or a 328mm disc.Also take a photo of the caliper and any brackets .
MATTHEW PEARCE
Phone 02 9609 1101
Old 08-12-2009, 11:26 AM   #9
MAD
Petro-sexual
MAD's Avatar
That upright you have with the new brakes is definitely an EL GT type, none of the modified uprights put the mounting hole right in the middle of the upright like that.
Interesting about the rotor though. I thought there was only one disc available and that was a slotted rotor from DBA, whereas the one you have there looks like its a two piece to me.
- The Story
Old 08-12-2009, 10:25 PM   #10
Scaffy
Rlegaur Mbemer
Sorry, I should have been clearer. The top upright is standard EL, as well as the top disc being standard size EL, just slotted DBAs on there. Everything is currently on my car so can't take more pics. The caliper mounts directly to the 2 holes you can see in the bottom upright in that picture.
Here's the only pic of the calipers I got, next to the standard one
Old 09-12-2009, 11:41 AM   #11
FLOORED
Race Brakes Sydney
FLOORED's Avatar
OK what i am thinking and you will have to check is this.The upright is a EL GT one because the caliper mounts straight to it and the rotor you have may still be the same dimensions as a EL GT rotor of 329mm x 28mm thick but they have made a special disc for racing use.If this is the fact then you should be able to put a pair of dba slotted discs on to replace at $350 a rotor but check the rotor size.
MATTHEW PEARCE
Phone 02 9609 1101
Old 09-12-2009, 11:32 PM   #12
Scaffy
Rlegaur Mbemer
Cheers. I had another look at the DBA site and saw they have a list of dimensions. When I get a chance, I'll check them out to ensure they are the same, then let you know. Do the new rotors come with new bearings or are they a seperate purchase?
Old 09-12-2009, 11:34 PM   #13
MAD
Petro-sexual
MAD's Avatar
Is the rotor a 2 piece or 3 piece?
- The Story
Old 10-12-2009, 12:55 AM   #14
Scaffy
Rlegaur Mbemer
I'm pretty sure it's just a 2-piece
Old 10-12-2009, 01:52 AM   #15
XH5LWEPN
Boost is here!!
XH5LWEPN's Avatar
Yeah the whole kit we fitted Chad, was definately a genuine EL GT kit with the genuine uprights and calipers. Its just the rotors are some unknown aftermarket jobbie.
Matt, while your here. A quick question, the upgrade of yours on my ute, that uses a DBA slotted rotor to fit EL GT brakes yeah?
The kit is still going strong by the way mate, worth every cent ;)
STREETBUILT RACING
'99 XHII XR8, 363w, GT4508R on 16psi, E85, C4, 910rwhp - ET coming soon!
'78 XC Falcon 500, Desert Gold, 351w, V2 on 16psi, E85, C4, 9" - 10.15@132mph!
XH5LWEPN is offline   Reply With Quote Multi-Quote with this Post
Old 10-12-2009, 02:48 AM   #16
Scaffy
Rlegaur Mbemer
Geeze, I don't know why I didn't think to ask you in the first place Jeff. Thanks.
Old 10-12-2009, 11:05 AM   #17
MAD
Petro-sexual
MAD's Avatar
You might want to get in touch with DBA or similar and see if you can find out what the outer piece is from.
It will most likely be cheaper than the EL GT rotor, and being a 2 piece it wont be as prone to cracking under high loads either.
Does the rotor have its part number stamped around the outer edge?
It should have a part number and its minimum thickness stamped on it.
- The Story
Old 10-12-2009, 12:55 PM   #18
FLOORED
Race Brakes Sydney
FLOORED's Avatar
You will need to purchase the wheel bearings separate thanks.I have some feelers out with the rotor info and will let you know asap.
Let me know when you measure it up and also put up a photo from behind thanks as it may be a direct or strap drive style.
MAD Is the rotor a 2 piece or 3 piece?
It is a 2 piece disc but i call it a 3 piece because you have the hub the hat and the rotor as with the genuine one it is all one piece.
XH5LWEPN Yeah the whole kit we fitted Chad, was definately a genuine EL GT kit with the genuine uprights and calipers. Its just the rotors are some unknown aftermarket jobbie.
Yeah i am thinking the rotors were made for a racing car because you wouldn't go to that much trouble for a street car but so far the manufacturer has eluded me although i think i am very close to having an answer soon.
Yes the benefit of our kit is we actually use the DBA136 EL GT rotors.
MATTHEW PEARCE
Phone 02 9609 1101
Old 10-12-2009, 01:41 PM   #19
MAD
Petro-sexual
MAD's Avatar
That's a good point I should clarify what I mean when I say 2 piece or 3 piece.
1 piece - Hub and rotor all in one
2 piece - Hub, rotor
3 piece - Hub, hat, rotor
- The Story
Old 11-12-2009, 04:19 PM   #20
FLOORED
Race Brakes Sydney
FLOORED's Avatar
JACKPOT - I have found the maker of these rotors and i can supply the replacement disc with the bobbins to fit them for $385 each thankyou which is not as expensive as i thought they would be..
MATTHEW PEARCE
Phone 02 9609 1101
Old 13-01-2010, 01:24 AM   #21
Scaffy
Rlegaur Mbemer
Sorry mate, forgot to check this thread since I got the net on at the new place. Are you able to do these discs in just slotted, rather than drilled? Also, what are the bobbins?
Old 18-01-2010, 12:33 PM   #22
FLOORED
Race Brakes Sydney
FLOORED's Avatar
The rotors have a dimple not an actual hole and this is the only way they come sorry as they were designed for motorsport.The bobbins are what help the rotor mount to the hat and there is only one set available at the moment thanks mate.
MATTHEW PEARCE
Phone 02 9609 1101
Old 19-01-2010, 01:39 AM   #23
Scaffy
Rlegaur Mbemer
Cheers for the info mate. I think I'll be going with the DBAs when finances allow because these are really noisy, which I think is thanks to those dimples. A constant whirring sound. It annoys the crap out of me.
