Old 13-08-2007, 04:24 PM   #1
Rob
Living the dream
Default Spotted - Aurion TRD?
Coming home from work just now, saw an Aurion with big wheels, so I did a bit of a double take, noticed it had exhaust pipes similar to the new Civic Type-R, but they were squared off at the top. The wheels were probably 19's, and on the back it had a TRD badge. At first I thought it was some idiot with badges, but on the side of the car it had 3500 S on it, proper badges that looked factory. Im sure I saw 3400 S, but I sort of discounted that because they run a 3.5 litre V6. Dunno, anyway, it also had HUGE brakes with shiny red calipers.
It was turning left off the Princes Highway onto Millers Rd, Altona (near Toyota factory).
Can anyone confirm I saw an actual TRD Aurion, has anything conclusive been released?
Rob is offline   Reply With Quote Multi-Quote with this Post
Old 13-08-2007, 04:31 PM   #2
fou_bleu
Get EcoBoosted
fou_bleu's Avatar
Sounds like you've one of the few to catch the TRD Aurion testing! Good on ya!
fou_bleu is offline   Reply With Quote Multi-Quote with this Post
Old 13-08-2007, 05:07 PM   #3
Dave_au
Hmm - I just did a quick search, and there is one 3.4L Toyota v6. You might be onto something as apparently TRD supercharges this engine elsewhere in the world. Perhaps TRD Aust couldn't be bothered with modifying the engine themselves.
(from WIKI)
5VZ-FE
The 5VZ-FE is a 3.4 L (3378 cc) engine. Bore is up to 93.5 mm (3.7 in) and stroke is 82.0 mm (3.2 in). Output is 190 hp (142 kW) at 4800 rpm with 220 ft·lbff (298 Nm) of torque at 3600 rpm. It has a cast iron engine block and aluminum DOHC cylinder heads. It uses MFI fuel injection, has 4 valves per cylinder with bucket tappets and features large cast connecting rods, a one-piece cast camshaft, and a cast aluminum intake manifold.
The 5VZ-FE also continued the 3VZ-FE's trend of being far overbuilt for its intended application. A handful of built versions exceed 900 hp (670 kW), and some stock engines can produce 450 hp (336 kW) or more. This has become a popular engine to consider when doing engine swaps with the avalibility of the 3.4 L TRD supercharger and custom turbocharger setups.
Dave_au is offline   Reply With Quote Multi-Quote with this Post
Old 13-08-2007, 05:09 PM   #4
BENT_8
BLUE OVAL INC.
BENT_8's Avatar
It's possible that you are right with the 3400s as i think the Prado uses a 3.4l V6.
BENT_8 is online now   Reply With Quote Multi-Quote with this Post
Old 13-08-2007, 07:04 PM   #5
Rob
Living the dream
Well thats what I thought, I'm sure it was a 3400 S badge, but like I said, I thought.. nahh. Looked pretty good I must say, but still.. front wheel drive. Cant get excited about that.
Old 13-08-2007, 07:15 PM   #6
Yellow_Festiva
Where to next??
Yellow_Festiva's Avatar
I spoke to a worker at Toyota months ago who has seen and sat in the TRD Aurion and told me that they were gonna have 20' wheels standard.
But he also told me there was no weight difference between the old Corolla and the new one......
Thats a salesperson for ya.....
Old 15-08-2007, 09:39 AM   #7
UNR8D
FORMER T3 OWNER
UNR8D's Avatar
Prado's use a 4.0L V6 same as that found in the Hilux with a different state of tune.
Aurion TRD is a S/C version of the 3.5V6 they are using in the stock models currently
unsure as to how this sales person sat in one they havent been even given release dates to us or final specs..
Mischief.TV
you can sleep in your car, but you cant drift your house...
UNR8D is offline   Reply With Quote Multi-Quote with this Post
Old 15-08-2007, 09:46 AM   #8
merlin
merlin's Avatar
It is the same 3.5L V6 in the normal Aurion as Eaton worked very closley with TRD in developing all the supercharger bits and pieces.
Front wheel drive wheelspin FTL.
1966 Ford Mustang coupe. 347 stroker, PA reverse manual C4, TCE high stall converter, B&M Pro Ratchet, Edelbrock alum heads, Edelbrock intake manifold, MSD ignition, Holley Street HP 750 CFM carb, gilmer drive, wrapped Hooker Super Comp Headers, dual 3" straight through exhaust, Bilstein shocks, custom springs, full poly suspension, American Racing rims, Open Tracker roller spring saddles and shelby drop.
Still to go - Holley Sniper EFI with integrated fuel cell.
merlin is offline   Reply With Quote Multi-Quote with this Post
Old 15-08-2007, 10:45 AM   #9
dallasv8
5.8 litres of fun
dallasv8's Avatar
there was pics of the TRD hilux in one of the carsguide magazines last week
2003 RTV
2015 Ranger XLS mk2
dallasv8 is offline   Reply With Quote Multi-Quote with this Post
Old 15-08-2007, 11:55 AM   #10
Poetic Justice
NOT A TOYOTA :/
Poetic Justice's Avatar
The TRD Aurion is called TRD Aurion 3500S which is released this month (august)... dealers should already have their alotment of them.
06 LandbargeCruiser Sahara
Managed to remain in the v8 fraternity
Poetic Justice is offline   Reply With Quote Multi-Quote with this Post
Old 15-08-2007, 06:56 PM   #11
hy_boi
Alan! Alan! Alan!
hy_boi's Avatar
I work for toyota, The TRD aurion will not be sold under the toyota name, It will be sold under TRD eg what lexus is to toyota, some dealers will have seperate areas for their TRD showrooms.
The TRD aurion will come in 2 forms,
3500S - supercharged
3500SL - supercharged luxury
Thats about all they are telling us. but yes release next month followed closely by the TRD hilux, then trd corolla next year, guess how many KW's the corolla will have?
hy_boi is offline   Reply With Quote Multi-Quote with this Post
Old 15-08-2007, 07:09 PM   #12
BENT_8
BLUE OVAL INC.
BENT_8's Avatar
The previous Prado used the 5VZ-FE 3.4l V6, google it :
Old 15-08-2007, 08:04 PM   #13
Yellow_Festiva
Where to next??
Are they going to use the 200kw 3.5?
Would be an awesome hot hatch if they did!
Old 15-08-2007, 08:18 PM   #14
sleekism
1999 Ford Fairmont Ghia
sleekism's Avatar
Wow I was so excited about the TRD Aurion I fell asleep.
Toyota are rolling in moolah couldn't they make something less cynical, at least give the damn thing All Wheel Drive.
My guess is they are going to milk their 80's and 90's Supra credibility for as long as possible to sell crappy bodykit half arsed built for idiot TRD's.
sleekism is offline   Reply With Quote Multi-Quote with this Post
Old 15-08-2007, 08:30 PM   #15
XplodE
Smashed Gecko Racing
XplodE's Avatar
I got one with the 4.0 sitting in me driveway...
XplodE is offline   Reply With Quote Multi-Quote with this Post
Old 15-08-2007, 08:42 PM   #16
BENT_8
BLUE OVAL INC.
BENT_8's Avatar
And this proves.....?
Second (Land Cruiser 90-series Prado model: 1996 to 2002)
2nd generation PradoIn May of 1996, the 70-series underwent a makeover and emerged as the 90-series Prado, an independent series. The body was enlarged in and out. The design was heavy-duty, like the 70-series Prado, but with a smaller engine and lighter classification compared to the full-sized Land Cruiser series. Although new in designs, the suspension is similar to those used in Tacoma and Hilux Surf made by Hino. The 3-door series starts with an R in the series ranging from RZ, RX, RS to RJ while the 5-door line-up starts with T in the series ranging from TZ, TX, TS, to TJ. All models comes with model front double wishbone and 4 linked suspension as well as full-time 4WD. ABS and Field Monitor showing altimeter, termometer and pressure was standard in all the models. Television display and audio set was also optional. Gasoline engines include 2.7 L (2693cc) 3RZ-FE and, new in Prado models, 3.4 L (3378cc) V-6 5VZ-FE.
Old 16-08-2007, 09:48 PM   #17
ZC001
Cruisin
ZC001's Avatar
TRD = T u R D ?
ZC001 is offline   Reply With Quote Multi-Quote with this Post
Old 16-08-2007, 11:51 PM   #18
yift
Technical Contributor: For members who share their technical expertise. - Issue reason: Countless sensible, accurate mechanical advice on all things Falcon and Territory.
i aw one of those but red pulling out of the toyota offices in clayton one morning, didn't take much notice of it. its a bloody toyota at the end of the day, front wheel drive grandpa car. if they were built rear wheel drive i may have considered getting a little revved up about it.
yift is offline   Reply With Quote Multi-Quote with this Post
Old 17-08-2007, 12:19 PM   #19
hy_boi
Alan! Alan! Alan!
hy_boi's Avatar
Originally Posted by ZC001
TRD = T u R D ?
you thought long and hard about that aye.
yeah is a pity its not awd, hell the camry is awd in other parts of the world, why can't we have it.
Guess its a slow step in the right direction(just taking the long way to get there)
Old 18-08-2007, 02:09 PM   #20
GTpilot
FG GT 5.4 w/ additions!
GTpilot's Avatar
have been seeing one regualrly for about a month now, around normanby Rd Port Melb & crown casino going into Burnley tunnel. usually on my way home, Never thought much of it to be honest. just throught thay had been released or some Toyota exec car. its Dark blue, sounds nice, must admit. Who ever has been driving it has tried to get me to have a go a few times. Never bothered, pfft, peak hr traffic, speed cameras, etc, Also It's just a bloody Toyota after all.
GTpilot is offline   Reply With Quote Multi-Quote with this Post
