Old 16-02-2010, 08:22 PM   #1
jarradgoodwin91
Default Halo Spark Plugs
just wondering if anybody has used the halo sparks plugs in there focus!
i got an 06 model,
been told by a number of friends(mechanics) that these are the way to go.
http://www.lsgbrisk.com/products/pro...recordId=18887
jarradgoodwin91 is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2010, 08:57 AM   #2
#Russ#Es#
Hello Koni's!
#Russ#Es#'s Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: This member has made a few valuable contributions to the Forum in the Focus section, seems to know exactly what he is talking about with his posts, which are helpful and concise.
i got an 06 model,
The most important thing to remember with our model Focus is to use Platinum plugs. Unsure of the specific reason why, but most dealers seem to use platinum plugs as part of the 60k major service. If you have heard good things about these plugs from a number of mechanics, why not give them a go, definitely cheaper than the conventional brands.
2006 LX FOCUS SEDAN
Titanium Grey, factory bodykit, slightly debadged
CSA Motorvatr 17's/Kumho KU31's, Eibach Prokit/Lovells rear springs, Koni Sports Kit
Lower airbox removed, K&N Panel filter
Momo gear knob + boot + pedals, Ghia boot garnish, Zetec Chrome interior door handles
JVC KW-XR816 Headunit + more to come...
#Russ#Es# is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2010, 10:51 AM   #3
melbzetec
Old enough to know better
melbzetec's Avatar
I tried to do a search on reviews of these. They are a bit thin on the ground.
But I do question how the "halo" can be effective, as electrical current takes the path of least resistance, so will only spark across to one point on the "halo"....it will not form a "circle" of ignition.
Feels like a gimmick to me. If it was really effective, I think it would be a bigger success in the market
Old 18-02-2010, 03:20 PM   #4
marg99
The lack of any regap adjustment will hopefully mean longer life in high compression engines. Hope the halo does not stick too far into the combustion chamber!!
