I have just changed my diff gears from 3.27 to 3.91 but my 60 foot time has barely improved from 2.37 sec to 2.34 sec,doesnt seem right to me.
Car is an auto v8. It goes faster in the top end but not where it counts at the start. Should i have expected to drop more time than what i did? I was expecting to get into the 2.2 second region but i was slightly wrong by a lot haha |
It depends on whether you are spinning the tyres. If you are - a change in ratio will not make a difference
XA coupe 8.8sec @ 150mph http://www.fordforums.com.au/showthr...coupe+drag+car BA GT-P for the shed Mustang GT for the other half E3 chubsport - fully fat (and slow), sitting there waiting for me to get sick of it and sell it. BA XR6T for a daily NT Pajero for the bush XB 4 door project- swallows a BF xr6 turbo My dad is a generous bloke. He gave away his dead car batteries free of charge.... |
Patience is a virtue
What rear tires are you using? Run or the mill street tires will NOT hook but upgrade to a drag radial and you will make the most of your new gears.
417ci CHI headed XD. Dynamic transmissions C4 Track times 60ft pb 1.365 ![]() 10.173 @ 134.97mph 1/4 6.324 @ 108.93mph 1/8th PB SOLD ![]() |
I dont have traction issues at the motorplex the grip is really good,i run a 14.6 so i only need my normal street tyres and they dont lose traction at all.
I try and stall it to the same speed every pass and try not to load up the convertor too much or else it goes slower if its stalled too much. Im just lost as to where my speed has gone,i have missed something i just know it... Doesnt make sense to me. |
Alright, If you are not suffering traction issues, then you need to be stall at a higher rev to make the most of the new ratio.
You also have to balance everything. I change in diff ratio will benefit you more if you have a high stall converter and a bigger cam. Just changing diff ratio on a fairly stock car will not make much difference at all. There are other limiting factors that will rob you of any gains (ie the small cam that will produce a faster time using less revs, and low stall speed which will do the same) Does that make sense?
I think you lost me a bit on the small cam faster time, robbing me of gains?
I have a matched cam and convertor so if i change from 3.27 to 3.91 my 60 ft time still wont improve unless i get a bigger stall or a bigger cam, is that what you mean because i got the gears to do what a small stall would do and get me off the line quicker. So my issue is that i used a standard cam and convertor which made me have less to no gains from the gears in the lower revs? Last edited by STINKY NINJA; 01-10-2010 at 11:17 AM. |
I just spoke to a torque convertor specialist and he has given me something to try with my takeoffs.
I havent been getting the best out of my convertor by stalling it a bit too much, i need to stall it a couple of hundred above idle and then stomp on it to get a slingshot effect.Ill try it and see how i go because its the last thing to try. Thanks for the replies |
Yes, you got it right about not getting a gain unless you put a bigger stall or a bigger cam in it. You said it yourself- if you stall it up too high then you go slower. This means you are working the engine beyond its maximum efficiency range.
#9 | |||
I just explained to you what the expert said to me and you seem to have misunderstood that. he told me basically im using the torque convertor the wrong way so if anything is out of its efficiency range it would be the convertor wouldnt it. To get the best of something it must first be used the correct way, not just stall it as hard as it can go. |
#10 | ||||
Maybe read my posts a bit better.. |
Whats with the attitude buddy. The man is trying to give a bit of advice and you are winging about him not reading your posts properly!! WTF.
Harden up and figure it out yourself. Either way, your car must be pretty lame to be pulling a 14.6 with no traction issues. The diff guy was laughing all the way to the bank when he saw you. The only thing you need to do is get more power. ![]() |
#12 | |||
335 - STILL THE BOSS ...
'73 Landau - 10.82 @ 131mph '11 FG GT335 - 12.43 @ 116mph '95 XG ute - 3 minutes, 21.14 @ 64mph 101,436 MEMBERS ......... 101,436 OPINIONS ..... What could possibly go wrong! Clevo Mafia [SIGPIC][/SIGPIC] |
