Old 01-10-2010, 07:29 PM   #1
BA2003
BA XR6
BA2003's Avatar
Question Flywheel to Rwkw conversion??
G'day,
Can anyone tell me how to convert Flywheel kilowatt to Rear Wheel Kilowatt and vise versa?
XR6 Sedan 2003 Dark Blue
2.5" Stainless Mandrel Bend Pacemaker Cat Back Sports Exhaust, 83 Deg Thermo, 19" Rims, Tinted Windows, Black Altezza Tail Lights, XR6T Snorkel, F6 Tyfoon Secondary Intake Snorkel, Slotted and drilled RDA Rotors, 2.5" Venom High Flow Cat, Pacemaker Competition Extractors, SL King Springs, LSD 3.45 Diff. Dyno Tuned by ICES Performance (03) 9763 8854 = 164 RWKW
BA2003 is offline   Reply With Quote Multi-Quote with this Post
Old 01-10-2010, 07:48 PM   #2
TheInterceptor
Cruising...
TheInterceptor's Avatar
Im not to sure, but i dont think there is a specific calculator as the power losses depend on the cars mechanics? different resisting forces/friction and the likes.
FBT '98
BA XT '04
F100 4x4 '82
Subaru Outback '02
TheInterceptor is offline   Reply With Quote Multi-Quote with this Post
Old 01-10-2010, 08:31 PM   #3
GTP 044
Formally RED XR8
GTP 044's Avatar
I have been told that a rough guide is to divide the flywheel KW's by 1.3 to give you the approximate rear wheel KW's. Not sure how true this is.
PREVIOUS '03 GT-P Manual, Sunroof, Sat nav, Leather, reverse sensors
The only FPV ever built in CONGO GREEN
SOLD
CURRENT 2012 Manual, leather, sat nav GT 335 in SWIFT GREEN
1 of only 6 manual Swift Green GT’s and 1 of only 21 Swift Green GT’s in total
GTP 044 is offline   Reply With Quote Multi-Quote with this Post
Old 01-10-2010, 08:33 PM   #4
Road_Warrior
Pity the fool
Road_Warrior's Avatar
I've always used the rough guide of a 30% power loss from FWKW to RWKW
Fords I own or have owned:
1970 XW Falcon GT replica | 1970 XW Falcon | 1971 XY Fairmont | 1973 ZG Fairlane | 1986 XF Falcon panel van | 1987 XFII Falcon S-Pack | 1988 XF Falcon GLS ute | 1993 EBII Fairmont V8 | 1996 XG Falcon ute | 2000 AU Falcon wagon | 2004 BA Falcon XT | 2012 SZ Territory Titanium AWD
Proud to buy Australian and support Ford Australia through thick and thin
Road_Warrior is offline   Reply With Quote Multi-Quote with this Post
Old 01-10-2010, 09:14 PM   #5
ebxr8240
Performance moderator
ebxr8240's Avatar
Multiply or divide by 1.34 to convert kw to h.p or vise versa...
USUALLY and roughly ... rwhp is Fwkw...
Too many variables in transmission to accurately have a formula ...
Daily driver GTE FG..
Old 01-10-2010, 10:14 PM   #6
XBROO
Obsessed with wheels
XBROO's Avatar
Yeah that's the old school way but it is only a rough guide.
XBROO is offline   Reply With Quote Multi-Quote with this Post
Old 02-10-2010, 10:47 AM   #7
blackjack74
25-30% loss is about right. Which is close to the same difference between KW & HP. So 200 KW at flywheel is about 200 HP at the wheels?
blackjack74 is offline   Reply With Quote Multi-Quote with this Post
Old 02-10-2010, 11:02 AM   #8
flappist
Depends on the actual vehicle but a rough guide used by many.
Start with the FWKW of the next model engine above yours (does not have to be the same model or even make)
Multiply x 1.5
Add 5 for every "performance" sticker and 10 for every decibel of noise above the speaker at maccas drive through (exhaust holes and subwoofer are both used)
Add 20 for each bow-tie and shopping trolly wing.
Add 5 for every mm below the legal minimum ground clearance.
Add 1 for each supacheap receipt and 3 for every month interest free you got when you bought your "all rounder" tyre/mag package (n.b. add bonus 50 if you had to use spacers or redrill to fit)
Round the final number up to 10% more than any other car you know (or have seen in a magazine)
Old 02-10-2010, 11:03 AM   #9
388cube_edxr8
Nutty Professor
388cube_edxr8's Avatar
200 KW is 274 HP. That would mean that the transmission is draining 74 HP from the engine. That is way too much.
The best thing to do would be to find out what sort of gearbox you have, because the power loss is not really a percentage of the total power, but rather a set value for each different gearbox.
You will lose more through an auto than a manual too.
Originally Posted by Jeremy Clarkson
If you buy a rubbish car, what you are saying is "I have no interest in cars." If you have no interest in cars, you have no interest in driving, and if you have no interest in something, it means you're no good at it, which means you must have your driving license taken away.
388cube_edxr8 is offline   Reply With Quote Multi-Quote with this Post
Old 02-10-2010, 11:06 AM   #10
RAPID_BA
Too many variables, wheel size, weight of flywheel, diff gears, transmission.
For instance ba xt i6 seem to pop out 145rwkw with a claimed 182fwkw but go back a few years and the old 185kw hsv clubbies and 185kw windsors were belting out 120-125rwkw?
RAPID_BA is offline   Reply With Quote Multi-Quote with this Post
Old 02-10-2010, 02:42 PM   #11
3vXT
3vXT's Avatar
When I first dynoed my BA it was loosing 21 or 22% assuming it had 182kw at the flywheel to begin with. Its got a T5 and a 3.45 LSD.
3vXT is offline   Reply With Quote Multi-Quote with this Post
Old 02-10-2010, 02:52 PM   #12
blackjack74
? 200 x 1.34 = 268. 268 x 0.75 (a 25 % loss) = 201 sounds about right to me. It's trans & diff as well. I'm not trying to be argumentative but that formula has always been close for me for sub 200kw engines. Yes there are many variables but it's close.
Old 02-10-2010, 04:32 PM   #13
BFZF8
BFZF8's Avatar
Multiply x 1.5
That's definitely a tried and true method.
BFZF8 is offline   Reply With Quote Multi-Quote with this Post
Old 02-10-2010, 04:48 PM   #14
Qwik6
Unsafe @ any Speed
Qwik6's Avatar
I just done this with mine. Found it to be roughly correct.
As people are saying, autos sap more power than manuals, also bigger stalls & lower diff gears take a bit too.
EBII Fairmont 4.0L NA - 206rwkw E85 cocktail === 13.48@102mph
Thread here
http://www.fordforums.com.au/showthread.php?t=11334087
By HEINRICH PERFORMANCE & TUNING
E Series Falcon Image Museum on FB
https://www.facebook.com/pages/E-Ser...29864000453208
Qwik6 is offline   Reply With Quote Multi-Quote with this Post
Old 02-10-2010, 05:40 PM   #15
Revolver
Big Member
Revolver's Avatar
Yes as far as I know, manuals are less of a drain on power, autos heavier. Also whatever else is draining power, power steering, alternator, A/C, supercharger (yes they do suck some power, only to give you more). & Any other belt driven accessories.
I asked this question in the driveline-transmission section.... See if I can find the thread for you... I asked what the percentage "driveline loss" was got a few answers. That might help you out.
EDIT: Found it! Only one post, but it backs up the 30% notion...http://www.fordforums.com.au/showthread.php?t=11292240
Flappist.... That was awesome. I didn't stop laughing for about 5 mins, then once I stopped, I heard an Integra with a "cannon" on it. FFAAAAAAAAAAAARRRRRTTTTTT!!!..... Then started laughing again....
The Scarlet Fairlane: 94 5.Slow Litre NC II Fairlane 488800kms & Climbing
Rollin' on genuine ELGT wheels.
K&N Filter
/////Alpine Sound.
EBGT Momo Woodgrain Steering Wheel
The Scarlet Fairlane Build Thread
Project "White Knight"
93 ED XR6
ROH Alloys
Momo wheel
Cruise
Sunroof
Premo Sound
Manual
HO Goodies
PWK Build Thread
1990 Yamaha FZR 250: 59000ks & climbing. New fairing, old tank, my angry mosquito in a coffee tin! 14.977 1/4mile.
Revolver is offline   Reply With Quote Multi-Quote with this Post
Old 02-10-2010, 09:30 PM   #16
388cube_edxr8
Nutty Professor
Not just belt driven accessories drain power, electrical stuff puts more load on the alternator which in turn drains power. That's why electric water pumps provide negligible power gains. In car PC's, fooly hektik stereos, etc. all have the same effect.
Old 02-10-2010, 09:34 PM   #17
KPOJ
With the race car we are only losing around 10% through the drive train...
KPOJ is offline   Reply With Quote Multi-Quote with this Post
Old 02-10-2010, 11:36 PM   #18
The G6ET Spot
As has been said there are too many variables to have a definite answer.
Like my G6ET dynoed at 242 RWKW stock, they are supposed to be 270 FWKW. So does it mean that I have only lost 10% through the drivetrain or that Ford are understating the power these cars are putting out.
That is just 2 options, maybe the operator didn't strap the car down properly and that gave a higher figure.
See where this is going???
The G6ET Spot is offline   Reply With Quote Multi-Quote with this Post
Old 03-10-2010, 10:43 AM   #19
388cube_edxr8
Nutty Professor
How long is a piece of string?
Old 03-10-2010, 12:37 PM   #20
scoupedy
Firstly accessories don't drain the RWKw as they are already draining the FWKw... everything uses energy the gearbox, driveshaft, gear to pinion interface, axles etc. the more horsepower the less % you use as the box, shaft, diff & axles don't change eg. your 351 with fmx and 9" goes from 220 FWKw too 300 FWKW if you use the same running gear then the drive train power usage for a given rpm will stay the same i.e say 30Kw then you have gone from 190RWKw to 270 RWKw and ~14% loss too a ~10% loss
Every set up is different put a bigger diff in = more loses, Autos use more, larger heavier axles and driveshaft use more as do bigger heavier rims and tyres.
In Engineering we learnt that the best a gear interace can transmit is about 96% (feel free to correct me but it is around this mark) so with two interfaces the best is around ~92%.
10-30% seams resonable
scoupedy is offline   Reply With Quote Multi-Quote with this Post
Old 03-10-2010, 02:33 PM   #21
KPOJ
Or is your dyno man giving 'customer happy' figures, this is the case in most situations, seen dyno's up to 18% out.
Old 03-10-2010, 05:05 PM   #22
Revolver
Big Member
Revolver's Avatar
You just contradicted yourself. If your draining FWKw, your in turn Draining RWKw, Hence when you add/remove a belt driven accessory, it decreases/increases the FWKw & RWKw at the same time Respectively. Not just FWKw. Your cant add or lose HP from one OR the other. It MUST be both. It just means the power you just gained also loses the same percentage of power through the driveline....
K&N Filter
/////Alpine Sound.
93 ED XR6
ROH Alloys
Momo wheel
Cruise
Sunroof
Premo Sound
Manual
HO Goodies
PWK Build Thread
Old 03-10-2010, 05:49 PM   #23
Aulpgute
Slightly off topic but semi relevant, bout 15yrs back my factory XD 351/FMX ute with exhaust and small cam produced 195rwhp thru a BW 3.23 diff and days later after a 3.25 9 inch diff conversion produced 188rwhp under the same conditions. Worth a mention highlighting the parasitic losses of runing a much heavier diff than the original.
Aulpgute is offline   Reply With Quote Multi-Quote with this Post
Old 03-10-2010, 05:54 PM   #24
Aulpgute
Slightly off topic but semi relevant, bout 15yrs back my factory XD 351/FMX ute with exhaust and small cam produced 195rwhp thru a BW 3.23 diff and days later after a 3.25 9 inch diff conversion produced 188rwhp under the same conditions. Worth a mention highlighting the parasitic losses of turning a much heavier diff than the original.
