#1 | |||
AFF's 1st DM.......
hey folks, just wondering if anyone here has converted their old evap to a reverse cycle aircon using the current ducting, or is it even possible? Missus is over the hot weather in perth atm. Otherwise its a split system in the rooms.
Thanx in advance
FORD GIVING POWER TO THE PEOPLE Alloy headed 347ci EDXR8 13.21 @107.7mph Quote:
If you go with a split system, consider a ceiling cassette.
Bang it in the largest room, normally dining/entertainment, cools most of the house quite well, just bearable.
2015 FGX XR8 5.0 S/C 645 RWKW ![]() |
#3 | |||
We have a large refrig in our kitchen TV area, and just close off all the doors and veg out infront of the TV, but as soon as you go to the bedrooms, whew, melt. I think you can do the conversion but very expensive, thats why, me being a cheapskate, went for 1 refrig unit. Have a look at the ads they have in the TV guides from the weekend papers.
jaydee351 4DV8 |
See if you can put up with it for a couple of months (autum/winter) that's when the prices plummet from around 14,000 to 9-10,000 for a large 4 x 2.
There is a place that will design the system for you and you can buy the ducting and extras from them. I think in Kardinya/Myaree maybe?? Install yourself, grab a sparky/fridgy mate, save bucketloads. If you want trade/contractors price PM me ![]()
We had full ducted reverse cycle air-con fitted about 6 months ago.
$9500 fully fitted removed and disposed of the two old splits. Cools our 4*2 house to cold any day. Fitted by Jarrahdale air in one day no dramas at all. Quotes are free get them out and ask about the ducting. |
#6 | |||
#7 | |||
AFF's 1st DM.......
Cheers people, i do like the casette styled ones. There goes the FMIC and zorst for the terry, hard decision
Evap ducting is too big to run as a conversion. Most installers would want to replace the entire system rather that retro fit. Just rip the old swamp donkey out!!
#9 | |||
Keep the missus happy for now, plan for more mods later ![]() .
#10 | |||
Out with the old and in with the modern. .
Performance moderator
![]() Join Date: Feb 2005
Ahh happy wife... Happy life !!! Even if she's cool... Lol...
#12 | |||
AFF's 1st DM.......
Im hearing you there Graham
![]() Join Date: Oct 2006
You might want to try (or investigate trying) a larger fan motor in your evaporative system if you can. If you have a Breezair for example you can usually change to a larger wattage motor and re-gear it to give a much larger air volume output. It will make a noticeable difference in terms of cooling in this weather.
You can go too far and destroy the fan of course and you will have to be careful to leave enough windows open so the air can escape or you will blow your duct walls out or off their outlets. Check with whoever sells spares for your system as you will often well find that there is a higher output fan motor designed for your existing evap box when more outlets are connected. You can usually also adjust the fan pulley diameter for the new motor so its spins faster. This will need to be set up by an electrician or if you know how using a clamp on ammeter to get the pulley size to match the new motor. I found this out by accident. I have an 11 outlet Breezeair and when the motor failed the only one available was one designed for a system with more outlets (20 I think). When it's like this I set it to high and I have my own cooling mini-cyclonic wind. The extra air movement make a very noticeable difference on humid days like this. It's only when it's like this and when the dog does one of her noxious burnt rubber I set it to high. Even on the lower setting everyone remarks how much cooler our system is than theirs. Higher output water pumps for these systems are also available but I have needed to go down that path yet. And if it's only for a few days a large solid block of ice in the evap roof box each day will make a real difference too (I used to do this in a previous house).
regards Blue |
#14 | ||
Note also the our Government has been threatening to separately power all refrigerative air conditioners so they can turn them off in peak consumption periods so refrigerated air may end up meaning no air when you most want it.
regards Blue |
#15 | ||
See http://www.zdnet.com.au/wa-utility-t...-339289186.htm
http://www.mediastatements.wa.gov.au...?ItemID=130233 http://au.news.yahoo.com/thewest/a/-...-to-pay-price/ Re Big Brother or Nanny State's remote control of air con use.
regards Blue |
#16 | |||
AFF's 1st DM.......
Thanks aussie
#17 | ||
See here for the Breeezair options:
http://www.aercomountisa.com.au/eaparts.html 095011 Motor 2 Sp. 250W 240V 095028 Motor 2 Sp. 380W 240V EA70 Range 095042 Motor 2 Sp. 560W 240V EA90 + EA100 095066 Motor 2 Sp. 750W 240V EA120 095080 Motor 2 Sp. 1100W 240V EA140 095097 Motor 2 Sp. 1500W 240V EA150 but you need to match the motor to the other parts eg 500607 Fan Centrifugal Small EA70 Range 501307 Fan Centrifugal Medium EA82 + EA90 506807 Fan Centrifugal Large EA100 to EA150 Tank Small DD EA70D 505008 Tank Small SD EA70WV + 70S 505206 Tank Medium DD EA82 + EA90 505107 Tank Medium/Large SD/TD EA82 to EA150 505305 Tank Large DD EA100 to EA150 Lid Small DD EA70D 505107 Lid Medium/Large SD/DD EA82 to EA150 505008 Lid Small SD EA70WV + EA70S 505305 Lid Medium EA100, 120, 140 Top Discharge 604602 Lid EA150 Top Discharge 3 505404 Panel Front Small EA70 Range 505503 Panel Front Medium EA82S + EA90S 505602 Panel Front Large EA100S to EA120S 4 505701 Pad Frame Small EA70 Range 505800 Pad Frame Medium EA82 + EA90 505909 Pad Frame Large EA100 to EA150 5 100159 Filter Pad Small EA70 Range 100203 Filter Pad Medium EA82 +EA90 100258 Filter Pad Large EA100, 120, 140, 150 Fan Centrifugal Small EA70 Range 501307 Fan Centrifugal Medium EA82 + EA90 506807 Fan Centrifugal Large EA100 to EA150 502106 Shaft Fan Small EA70 Range 504605 Shaft Fan Medium/Large EA82 to EA150 800523 Bearing Kit all Models 501703 Pulley Fan 225Dia. all Models 100869 Pulley Motor Large Dia. 108 etc etc
regards Blue |
#18 | |||
AFF's 1st DM.......
cheers mate, heres to things getting cooler in perth hey :(
#19 | |||
regards Blue |
#20 | ||
We used Jarrahdale to replace our Cool Breeze unit, notice a big difference in comfort levels even in the extreme heat, only issue is really high humidity days where we get a lot of condensation on the tiles. They could have converted the evap to refrigerated for our home, but didn't have 10K to spend and the wife was pregnant and a hot summer last year when the other air con bit the bullet.
Jarrahdale installers did a great job and we had an issue with the drain valve, phoned them up, fixed same day. |
#21 | ||
Pity the fool
Yeah we've got one of those old school through the wall box air cons for our main room (3x1 duplex) and in there its fine, as soon as you go into another room you boil.
I like the cassette style ones, my Mum has a Fujitsu one at her house and its whisper quiet and cools quite well. Better than the stupid LG one she had thats like sitting behind a jet engine with all the noise to go with it. But yeah, sick of these hot nights. Bleh.
Fords I own or have owned: 1970 XW Falcon GT replica ![]() Proud to buy Australian and support Ford Australia through thick and thin |
#22 | ||
swampy's are useless in the current conditions we are having,the ducting for your evap will be of much larger diameter (some 600 diameter) and therefore be useless on your new system,daikin are one of the best units to use and are good to deal with for after sales warranty issues (hopefully you don't need them)
#23 | |||
jaydee351 4DV8 |
#24 | |||
Had an ac engineer design it and costs a fraction of the usual ac costs due to being a simple volume air fan , the air is moved through underground pipes getting a drop of 5 to 7 deg minimum and all you pay for is running the fan , it doesnt freeze you but its lots better than a swampy ad=nd way cheep ![]() |
