Old 17-05-2011, 08:36 AM   #1
south21
Default WS Manual gearbox oil
My fiesta is now out of warranty and I wouls like to change the gearbox oil, does anyone know where the drain plug is, I have found the filler plug.
thanks
keith
south21 is offline   Reply With Quote Multi-Quote with this Post
Old 17-05-2011, 01:11 PM   #2
Fiesta God
Ford Fiesta
Default Re: WS Manual gearbox oil
If I recall correctly, there is no drain plug as the gearbox is a "sealed for life" type (never supposed to change the oil).
May have to get a pump and suck it through the filler? Not sure ...
Fiesta God is offline   Reply With Quote Multi-Quote with this Post
Old 18-05-2011, 01:52 AM   #3
Caydus
Caydus's Avatar
isnt the seal for life thing the auto?
Caydus is offline   Reply With Quote Multi-Quote with this Post
Old 18-05-2011, 09:59 AM   #4
Spinner77
I have a suspicion it's like a boat engine.
There is no drain plug. You have to pump it out from the top?
Spinner77 is offline   Reply With Quote Multi-Quote with this Post
Old 18-05-2011, 07:16 PM   #5
geelong festy
You guys are barking up the wrong tree! Check this thread: http://www.fordforums.com.au/showthread.php?t=11329627
Fiesta WS, Milltek tubular exhaust manifold' 200 cell cat, full milltek stainless race system, j1 CAI, Bluefin remap, ford race shifter, Team Dynamics Race rims 17x7', Spax Coil Overs, iridium plugs, CFM 8.5mm leads, R1 drilled & grooved discs & ceramic pads, HEL braided s/s brake lines, econetic front under tray & fitting kit, CG Belt lock, Bridgestone RE002, Armster arm rest, Rack limiter, PowerFlex Bushes.
FOR SALE!!
geelong festy is offline   Reply With Quote Multi-Quote with this Post
Old 18-05-2011, 10:51 PM   #6
south21
Geelong Festy, they are talking about an engine oil change with a reference to a gearbox oil change when he had the car serviced. What I want to know is where the manual gearbox drain plug is, if there is one ???.
The filler plug is behind the gear linkages which is behind the plastic cover.
