Old 10-06-2011, 09:26 PM   #1
Dustin_80
Default testing of brakes during rwc
How exactly does a mechanic test your brakes during a rw test?
I got my car back after a roadworthy test to find my rear brakes were locking up so badly I had to get the vehicle towed home.
As politely as possible I explained there's no way I could have gotten it there that morning if it was like that when it arrived.
"I play paintball three times a week bro. I'm even one of those douchebags who brings his own equipment."
Dustin_80 is offline   Reply With Quote Multi-Quote with this Post
Old 10-06-2011, 09:34 PM   #2
ratter
ratter's Avatar
Default Re: testing of brakes during rwc
They use a brake tester and check using moderate to firm braking I believe, the tester should give a print out of the results, well in vic that's what is expected
Off topic from reading your sig
I used to play competition paintball myself a while back
Pit Lane Performance
Old 10-06-2011, 09:40 PM   #3
fasty73
fasty73's Avatar
[QUOTE=ratter]They use a brake tester and check using moderate to firm braking I believe, the tester should give a print out of the results, well in vic that's what is expected
That's how it's done in nsw too., up here in qld, it's just see if they work.
fasty73 is offline   Reply With Quote Multi-Quote with this Post
Old 10-06-2011, 10:41 PM   #4
fmc351
let it burn
[QUOTE=fasty73]
Not quite so for Qld, but in practice seems to be pretty much it. I had one mech who hopped in the passenger side with a doohickey (kind of shaped like Dalek (in b4 Ricksta)) he sat on the floor at his feet and he asked me to brake while driving. It had a disc/ball floating in liquid that gave a reading based on angle to apportion braking front to rear. Only time Ive had anything like it in quite a few RWC's Ive had done.
They often pull a wheel off and inspect pads and rotor, but sometimes they just look while on the hoist without removing a wheel.
Old 10-06-2011, 11:04 PM   #5
ray38l
I often wonder why they worry about the brake test. I have had a few cars pass the brake test when the brakes were hardly working.
ray38l is offline   Reply With Quote Multi-Quote with this Post
Old 11-06-2011, 02:07 AM   #6
matty88
Did the rwc tester adjust the handbrake at all?
matty88 is offline   Reply With Quote Multi-Quote with this Post
Old 11-06-2011, 02:30 AM   #7
FG50T
FG50T's Avatar
Yep you can get anything to pass if you jump on the pedal hard enough unless there's a fault in the braking system. Probably why we do the test.. As long as they work, disc's aren't undersize and there's meat on the pads - it's all gravy.
FG50T is offline   Reply With Quote Multi-Quote with this Post
Old 11-06-2011, 08:17 AM   #8
Dustin_80
I asked them if they adjusted them in any fashion or removed the drums.
They said they didn't.
Old 11-06-2011, 08:49 AM   #9
cobramania
FPV BFII GT Cobra No.249
cobramania's Avatar
In NSW they have a small machine that sits on the front passenger seat & a pressure pad that goes over the brake pedal. They drive along a short distance usually only at about 40kph & hit the brakes, the machine records the G force, pedal pressure & time taken from initial pedal push to stop. If it's within certain pre-set guidelines the test passes & the report will be printed out off the machine, (similar to dyno graphs). If the test passes & there's nothing else wrong with the car (that makes them go looking), very rarely will wheels be removed, brakes visually looked at or any adjustments made.
The same machines used to have light sensors on them & they were used to do the "legal" window tint test, most mechanics I seen, used to just place it on the front windscreen if you had side tinted windows so it'd pass. There's still a legal tint level, but it doesn't have to be tested to pass for rego, if you get a defect on your car, it'll likely be tested when the RTA goes over the car though.
cobramania is offline   Reply With Quote Multi-Quote with this Post
Old 11-06-2011, 09:12 AM   #10
XDV800
What sort of car ?
XDV800 is offline   Reply With Quote Multi-Quote with this Post
