Old 02-08-2011, 03:04 PM   #1
prasac
prasac's Avatar
Default Ford Modulars dominate at this weekends PSCA Event in Las Vegas
PSCA: John Mihovetz led the list of winners at the PSCA’s Shootout After Sundown at the Strip at Las Vegas Motor Speedway on Saturday night after he downed veteran John Scialpi in the final, 6.20 to a slowing 8.24. Gary Soulages drove his Ford Lightining pickup to an impressive win in Outlaw 10.5, qualifying #1 with a 6.86 and earning the win with a 6.98 to 7.06 rout of Ron Weems’ GTO. Sandi Wold also picked up a win on the weekend in Extreme Drag Radial, cranking off a 7.79 to easily handle the slowing 9.19 of Jeff Longden.
3 Ford modular powered cars took out the Top 3 classes in the PSCA. as fantastic an achievement as that is, what is ever greater is all 3 engines were built by Accufab.
Pro Street (like our Top Doorslammer with 5-sec & 6-sec turbo, NOS & blown cars)
John Mihovetz won running a 6.20@232 4.6L Twin Turbo
Outlaw 10.5 (6-sec cars running a 10.5'' wide tyre)
Gary Soulages 6.98 4.6L Twin Turbo
Extreme Radial (7-sec cars running on ET Street type tyres)
Sandi Wold 4.6L Single 88mm Turbo
prasac is offline   Reply With Quote Multi-Quote with this Post
Old 02-08-2011, 03:24 PM   #2
Bluepower
KenneBell Australia
Bluepower's Avatar
Default Re: Ford Modulars dominate at this weekends PSCA Event in Las Vegas
Nothing quite like a modular. Badass.
Bluepower Racing Developments
Proud Australian Distributors of Kenne Bell superchargers
The Quickest, The Fastest, The Baddest Boss Blower of all.
www.bluepower.com.au
Bluepower is offline   Reply With Quote Multi-Quote with this Post
Old 02-08-2011, 03:45 PM   #3
63futura
63futura's Avatar
What blocks and internals are these guys running ?
And what kind of HP
These 4.6L mod motors just keep getting faster and faster
63futura is offline   Reply With Quote Multi-Quote with this Post
Old 02-08-2011, 04:05 PM   #4
prasac
prasac's Avatar
And what kind of HP
John likes the alloy Teksid blocks from the 93-97 Lincoln or 96-98 Mustang (same block i have) but any alloy or cast block is good
Manley Billet Steel rods
JE Pistons roughly 11.25:1 comp
Ford GT Supercar heads ported, Manley valves. factory lifters, John grinds his own cams.
C16/Q16 fuel
John makes 2500hp
Gary is probably pumping out 2100hp now.
Sandi is making around 1500-1600hp
Old 02-08-2011, 04:31 PM   #5
63futura
63futura's Avatar
C16/Q16 fuel
John makes 2500hp
And what crank ?
So really without too many mods you can pump alot of boost into these mod motors ?
How far can you push a std one and what the weak link ?
Old 02-08-2011, 04:51 PM   #6
prasac
prasac's Avatar
factory crank with some mods has gone 6.23@232 aftermarket Bryant crank has seen a 6.19@235
a standard 4.6L block with factory internals, not far have seen some make it to 700+hp. throw in pistons & rods, good tune u can make inexcess of 1200hp. to make around 1200hp u don't need to go into alot of work, pushing past 1500hp is a different story. alot of work should go into it but not many people do it. weak point on the modular, even though its a 6-bolt main setup the caps (mainly 2) tends to walk a bit.
the 5.4 alloy & cast blocks are very strong, and would be a good choice.
Old 02-08-2011, 05:18 PM   #7
63futura
63futura's Avatar
If the 5.4s are a better block why are they all using 4.6L ?
Is that to do with the rules ?
Its a pitty these things are so wide would love to slip one in the XL
Old 02-08-2011, 08:45 PM   #8
dieseltrain79
The 4.6l blocks handle the power better , plus they rev easier than the nuggety 5.4's
1998 AU VCT Ghia - Stock as a rock - Wifes car
1991 Toyota Soarer TT - 11.72 @ 116.7mph
2004 Ford Escape XLT V6 - Family Ride .
dieseltrain79 is offline   Reply With Quote Multi-Quote with this Post
Old 02-08-2011, 10:57 PM   #9
prasac
prasac's Avatar
as Danny said, the 4.6L revs alot freer and it's the combo they have done the most R&D on as it's more readily available than the 5.4L in the US. MMR is using a 5.4L and it proven to be the goods. a de-stroked 5.4 is good also, u can rev the hell out of it
the news i hear from the US is that MMR is just about to complete a full tube Mustang with a 5.4 which they intend on racing, going head to head not just with Accufab, but they have the intention of running it in NHRA Pro Mod (equivalent to our doorslammers) possibly being the first modular to run 5-seconds. knowing John from Accufab he won't give up without a fight
