Old 22-08-2011, 04:18 PM   #1
frd906
Default Thermostat Problem
Hey guys.
My friend bought a 89 ea spack, manual, 3.9
The problem he is having is when the car gets to operating temperature and the thermostat opens up it runs like crap, coughs and splutters,
But if he revs it over 2 grand the problem dissapears
He has replaced alot of things. map sensor, thermo sensor,all of the vaccum lines etc
Put a brand new thermostat in and it still does the same thing
Even had the ecu looked out and theres nothing wrong with it.
If any one would have a idea of what might be cuasing it, would be good
Welder/Fabricator at Beaudesert Exhuast
Posted by Xcabbi, Does it slap or rattle? Rattle is more to do with timing chains and tensioners. Slap is more to do with lifters, rings, bearings or GENIII boat anchors
frd906 is offline   Reply With Quote Multi-Quote with this Post
Old 22-08-2011, 04:26 PM   #2
pcman
Default Re: Thermostat Problem
sounds like a ignition problem to me like the coil is stuffing up once it gets warm/hot
pcman is offline   Reply With Quote Multi-Quote with this Post
Old 22-08-2011, 04:32 PM   #3
frd906
He has replaced the dizzy with a brand new one as well as the coil.
Old 22-08-2011, 04:44 PM   #4
Jason[98.EL]
Jason[98.EL]'s Avatar
does it have a worked cam in it if so it might be like my EL and run crap down low but once it gets over 2600 it goes way better
Jason
[SIGPIC][/SIGPIC]
Old 22-08-2011, 05:41 PM   #5
frd906
Nope no cam all standerd,
Old 24-08-2011, 12:50 AM   #6
BA Turbo
try placing your AU injectors in his car if its MPFI
had the same problem in my EA
exhaust leaks ?, fuel pressure
BA Turbo is offline   Reply With Quote Multi-Quote with this Post
Old 24-08-2011, 10:10 PM   #7
frd906
Will let him no, cheers
