Old 11-09-2011, 07:59 PM   #1
Day-mow
rexnet
Day-mow's Avatar
Default Creaking while turning steering wheel.
When turn my steering wheel it has a dry creak. To me it sounds like it's got no oil. But it does. Is it possible a slightly leaking high pressure line is blocked and not letting fluid to flow? Or something like that?
Steering knuckle need greace is my other thought.
MY06 WRX Build Not Bought
Collingrove Hill Climb- 38.79
Old 11-09-2011, 08:22 PM   #2
dogman
Default Re: Creaking while turning steering wheel.
day-mow,my car has same problem,be interesting to see what the forum comes up with.
dogman is offline   Reply With Quote Multi-Quote with this Post
Old 11-09-2011, 10:44 PM   #3
mongrelEF
Bugger!
mongrelEF's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always offers competent advice. Always willing to help out in person. Never negative towards another. Always respectful. Always offers viable suggestions for solutions.
Sounds like a worn power steering pump? Could also be worth checking the return hose for blockages. How low is the car?
Whoops, there goes another factory setup!
Chop and change - butchering cars since 1990
mongrelEF is offline   Reply With Quote Multi-Quote with this Post
Old 11-09-2011, 11:05 PM   #4
zorba289
zorba289's Avatar
hi,
had the same problem and mine ended up being loose bolts that hold the steering rack to cross member...apparently this was a recall,if you go to FORD,they can still tell you if your car needed to be fixed...
the solution was a tab of weld on the threads...
john
zorba289 is offline   Reply With Quote Multi-Quote with this Post
Old 11-09-2011, 11:05 PM   #5
Day-mow
rexnet
Day-mow's Avatar
car has SL's in it. its only just happened. im gonna chuck it up on stands 2morro and have a look make sure everythings nice and tight. dad thinks my rack may be loose. or on its way out :\
Old 11-09-2011, 11:06 PM   #6
Day-mow
rexnet
Day-mow's Avatar
Originally Posted by zorba289
hi,
john
thanks John. so i could possibly call them and see if this was an issue yeah?
Old 11-09-2011, 11:30 PM   #7
Beer Baron
The recall was to the check the welds on some AU's. Its the welds on one side of the thread. If yours doesn't have the weld or its been poorly welded it gets redone i think.
Its been a long time since i saw an AU in for this recall.
AU XLS.
Beer Baron is offline   Reply With Quote Multi-Quote with this Post
Old 12-09-2011, 09:09 AM   #8
Day-mow
rexnet
Day-mow's Avatar
thanks beer baron. i'll jack the car up soon and have a look and try take some photo's
Old 12-09-2011, 03:05 PM   #9
Day-mow
rexnet
Day-mow's Avatar
problem seems to be power steering rack due by date has come.
there is a really big leak on the passangers side from the boot. so when funds permit i'll replace it.
Old 13-09-2011, 07:20 PM   #10
boinker43
It was in 2005.
Id say most of them were poorly welded because most people complained after the recall of the grinding noise.
Many have been ripped off by mechanics since buying new steering racks and god knows what else.
Mine only started doing it after I took it to ford for that.
And it is the rack bolts coming loose I guess they loosened them or something before welding them poorly.
I got under there got someone to turn the wheel and I could see the rack moving while it made the noise.
I tightened them up with a spanner and its never made the noise again.
The problem is though the rack moves, and this messes with your wheel alignment obviously.
And this is another thing people got stung for, camber and castor kits to get a proper wheel alignment.
When in reality its probably just the rack that needs to be properly aligned and tightened up properly and welded properly.
boinker43 is offline   Reply With Quote Multi-Quote with this Post
Old 13-09-2011, 07:22 PM   #11
boinker43
Remember a leaking rack end does not require a new steering rack remember this.
You can buy rack ends and boots on ebay for $15 and if you know what you're doing you can screw them in yourself.
Or buy them yourself and get someone to do it.
Old 13-09-2011, 07:24 PM   #12
boinker43
Get someone to turn the wheel and watch the steering rack move
See if you can get under and see without it jacked up so the wheels are on the ground because it doesn't always do it without pressure on the wheels.
Old 13-09-2011, 07:29 PM   #13
boinker43
hi,
john
Don't take it to Ford.
They will just wreck something else on purpose while they tighten the bolts and sell you a new steering rack.
So you have it back there next week handing over the cash again.
Mine was fine before I took it in for the recall.
It only came loose AFTER that. Tell me that's a coincidence huh?
Trying to get themselves more work I assume.
Product recall? I think more like bring it in so we can wreck it so you can come back and pay us more money.
Old 13-09-2011, 07:53 PM   #14
blueoval
Critical Thinker
blueoval's Avatar
I have had similar creaking before. Turned out it was ball joints. I also had the rack and rack ends replaced too.
Daymow, if in doubt, get someone to look at it to diagnose the problem before you fork out cash. Make sure you know for certain what the problem is.
There is nothing worse than forking out dough and finding the problem hasn't been solved.
"the greatest trick the devil pulled, is convincing the world he doesn't exist"
2022 Mazda CX5 GTSP Turbo
1967 XR FALCON 500
Cars previously owned:
2021 Subaru Outback Sport
2018 Subaru XV-S
2012 Subaru Forester X
2007 Subaru Liberty GT
2001 Subaru GX wagon
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1984 Datsun Bluebird Wagon
1975 Honda Civic
blueoval is offline   Reply With Quote Multi-Quote with this Post
Old 13-09-2011, 11:54 PM   #15
Day-mow
rexnet
Day-mow's Avatar
true that my good friend
Old 21-09-2011, 12:02 PM   #16
XESP351
XESP351's Avatar
Definitely loose steering rack bolts. Tightened them and the noise is gone.
Mind you they werent excatly what I would call loose, all it was is a quarter of a turn.
XESP351 is offline   Reply With Quote Multi-Quote with this Post
Old 23-09-2011, 08:27 AM   #17
shazaam
Had put up with creaking when turning left and right for a few years, then as part of maintenance had rack and upper and lower ball joints replaced and no more creaking since.
shazaam is offline   Reply With Quote Multi-Quote with this Post
Old 23-09-2011, 07:01 PM   #18
Day-mow
rexnet
Day-mow's Avatar
oh. well thats kinda encouraging. i need to do my rack. its leaking a fair bit of oil so i guess i'll just put up with it until funds are available to do stuff with it.
Old 23-09-2011, 08:54 PM   #19
mik
mik's Avatar
i`m intrigued boinker, i rebuilt my rack off car a few years ago, some of the small details i`ve forgoten, can you get at the hammer in keyway that locks the inner tie rods in place without dissasembly of the rack? same question ,o rings at the extremities where they usually leak from?
