View Poll Results: Do you lift your right foot off the floor to change from accelerator to the brake? | |||
Lift your foot |
11 | 34.38% |
Keep your foot on the floor |
21 | 65.63% |
Voters: 32. You may not vote on this poll |
This might be a weird thread but anyway...
When I brake, I pick my whole foot off the floor and accelerator, then onto the brake pedal. I thought that it could be quicker to just keep your foot in between the two pedals and then tilt it to accelerate and brake, without lifting it off the floor. I asked some people and had different responses. Some left their foot in one place while some moved it around. Is there a correct way? I feel like my foot could slip off the brake if I'm not careful when leaving it in one place but if I lift my foot up it takes longer. Also just as a side question, if I wanted to do a defensive driving course in Sydney, does anyone have some recommendations? Also is there a place that has their own cars because I'd like to do one in a car without ABS Thanks |
![]() Join Date: Jan 2005
I have size 16 feet so I brake with my big toe and accelerate with my little toe. That way I can keep my foot comfortable so i guess its keep my foot on the floor for me.
My Ford Family... 2014 GT-F, Manual, Kinetic with Black Stripes 2021 Mustang Mach 1, Manual, Velocity Blue |
When in the manual I have my heel in the one spot on the floor and then swivel my foot to press on the accelerator/brake as necessary. In the auto I use left foot braking.
I have to move my foot entirely off....
Unless you have big feet (as above!) or a nice set of racing peddles close together then it does make it a tad difficult.
You've seen it, you've heard it and your still asking questions?? Don't write off the Goose until you see the box going into the hole.... |
I've pretty much always left foot braked personally, unless it was around town in a manual.
Had: ED Fairmont AU engine 5 speed exhaust extractors, 17" mags, miss the old girl.... Have: 1JZ Soarer dump pipe, exhaust, coilovers ![]() |
The Experience...
Oddly enough I find i have more control over the two when I can use my entire foot over the pedal.
Her Daily: BF XR6T ZF
His Daily: FGX XR8 ZF ![]() ![]() ![]() ![]() ![]() ![]() |
SY TS AWD LPG TEZZA
Depends on the size of your feet and the difference in height between both pedals. My Dad's old Valiant had the brake pedal way up high, but the accelerator way down low. You had to pick your foot up. My old XB had both pedals almost the same level, much easier to drive too.
1st car 75 XB Fairmont wagon 302C converted to 351C. 2nd car 82 ZK Fairlane 351C 4spd AOD LPG/Avgas 3rd car 97 EL Falcon police car 4L auto dual fuel 4th car 90 XF ute (work car) 5th car 06 SY TS AWD Territory Orbital LPi 6th car 95 XG ute 7th car 2014 SZ Territory TX Petrol Fords all my life. |
True Blue
Im like Blue Sleeper, but I always left foot brake unless I drive a manual..... with both heels on the floor!!
I'm old and I fell
I used to left foot brake on my learners but my parents always told me that was bad.
These days, with size 15 feet, I have my heel on the floor and just swivel across to each pedal.
BF2 XR6 turbo 82lb injectors, Walbro fuel pump, bigger cooler, Plazmaman piping, SS Growler, tune, ZF tune, Crow valve springs so far. Ozracing coilovers, Pedders sway bars front and rear. 315rwkw |
I leave my heel on the floor as I find it easier to modulate the brake better with using the floor as a reference.
Benny.
GT 335 MKII, ZF6, Tein coilovers, YT snout, 61mm pulley, KPM 1500HP fuel system, 1000cc injectors, E85, KPM exhaust, BMC air filter, KPM Streetfighter intercooler, built tail shaft, Truetrac, 479rwkw - 950nm. |
#11 | |||
Lucifer's Angel
In a bus I have no choice but to move my whole foot though.
![]() ![]() Blueprint, manual, 4490's, Redback 2.5" dual exhaust, BA Typhoon rims, tint, fog light covers, BF tailights, blue illuminated window switches, Ghia bootlid carpet, lower grille, FPV door spears, steering wheel & interior bits, XR6T + F6 intake, K&N filter, Typhoon spoiler, tuned, sway bars, custom angel eyes & plates..YUM!
If there's one thing guys in Holdens hate more than being beaten by a Ford... It's being beaten by a girl driving a Ford ![]() |
#12 | ||
meh.
![]() Join Date: Jul 2010
I usually come off the brake and onto the accelerator unless I'm on a hill, then I'll come slightly off the brake, some throttle while I let the clutch out completely...
On track i brake with the left foot on the road i do both, but lift completely off when right foot braking
#14 | |||
#15 | ||
nou
Kombi I have to lift because the brake pedal is so much higher. Territory is hybrid, sometimes foot moves, most of the time pivots. I find I get a sore ankle in the Territory?? So usually I'm over-thinking my moves.
#16 | |||
Lucifer's Angel
I know someone who drives that way, and he's constantly chewing through brake pads, because he doesn't always realise that his left foot is lightly touching the brake pedal, so his brakes drag. Personally, if I am anticipating something going pear shaped around me, I 'cover' the brake with my right foot anyway. But of course we all drive in a way that we're comfortable with, which makes sense to us, and that's ok.
#17 | ||
Fixing Ford's **** ups
As previously mentioned, having your foot hovering over the brake pedal means there is an increased possibility of riding the brake, especially with long drawn out city driving.
Me, I right foot brake and accelerate with an auto and manual. On a hill in a manual, yes I heal and toe to start off.
A wheel alignment fixes everything, when it comes to front end issues. This includes any little noises. Please read the manual carefully, as the these manufacturers spent millions of dollars making sure it is perfect.....Now why are there so many problems with my car, when I follow the instructions to the letter?....Answer, majority rules round here Lock me up and throw away the key because I'm a hoon....I got caught doing 59 in a 60 zone |
#18 | |||
nou
#19 | ||
Browsing here and there..
I'm surprised there are people who brake with there left foot, didn't think it was that common.
#20 | ||
Lift the whole foot off usually.
#21 | |||
Most of the cars I've driven on the road have the brake pedal a lot higher like some of you mentioned which makes it harder to leave your foot on the floor, but I'm going to start trying to do it more because (imo) you have a quicker response. When I do a hill start in a manual it depends on what car I'm using. If the car has a crappy handbrake (ba falcon wink wink nudge nudge) or one of those handbrakes where you pull it out from the dash (xf falcon wink wink nudge nudge) then I do heel and toe but if the handbrake is nice then I find using the handbrake easier because you have your feet all over the place with heel and toe plus it just feels awkward. |
#22 | ||
Left foot braking?
I thought that was strictly for cab drivers. No? I swivel my right foot between pedals with heel fixed. Seems to flog out the carpet, but it feels more grounded and stable to me |
#23 | ||
Smash the Boost
Always brake with my right foot, feels weird left foot braking unless im in a kart.
if i am dawdling around, heel stays planted as i dont often require big pedal application. If im getting into it a bit, the foot lifts - especially for blipping the throttle on downshifts. FWIW now that i back in a auto i really notice how far apart the pedals are. My old SS was a much nicer setup. I hope the manual pedals in the FG are better because I doubt my feet are big enough or my ankle could rotate that far otherwise!
2023 Hyundai Palisade 1971 Fairmont Sedan 1974 SWB F100 Keyboard Warrior - A Person who, being unable to express his anger through physical violence (owning to their physical weakness, lack of bravery and/or conviction in real life), instead manifests said emotions through the text-based medium of the internet, usually in the form of aggressive writing that the Keyboard Warrior would not (for reasons previously mentioned) be able to give form to in real life.
#24 | ||
My feet are too big and I literally can't drive with shoes on, they get jammed up under the dash. Pretty easy to pivot on the ball of your foot >.<
#25 | |||
Chevy badges , the Polariser of the new millenia . |
#26 | |||
If doing handbrake hillstarts is tedious, you need more practice or the handbrake needs adjusting. That's one of the things you're tested on, when obtaining your drivers licence and one of the things tested on the car, when going for a roadworthy. Woops forgot....Quality german product ![]()
#27 | ||
I only use my right foot for both accelerating and braking, I thought everyone was taught to do that in an automatic? Coming from a manual it did take a little while to adjust but now it feels weird to use the left foot for braking so I never do, unless I'm reversing out of a steep driveway and I don't want the car to roll forwards, I might get the revs up slightly but hold the brake on.
2011 FG XR6 Sedan |
#28 | |||
nou
![]() Not tedious but a lot easier to heel toe. On smaller slopes I can let the clutch out a bit on idle to hold the car while I move my foot from the brake to the accel, which is good. |
#29 | ||
moderator ford coupe club
left foot autos and some manuals
not sure what i do when right footing the brake. i think i would probably be a swiveller, but in reality maybe a little more than just swivelling and a little less than lifting the whole foot and stomping |
