Old 19-08-2007, 05:49 PM   #1
OED666
OED666's Avatar
Default Computer PSU? Can you connect a 20pin connector to a 24pin motherboard
Right,
I am in the process of upgrading my desktop, and I have just purchased a ASUS P5K motherboard.
I am using my existing case, which is a 400w power supply, and it says P4 compatible. I assumed that this motherboard would accept the same power connection.
The connection on my power supply is 20pin, and on the new motherboard is 24 pins.
I can physically connect the power to the board, but there is 4 pins on the end that are not connected to anything.
These pins are +3volts, +12volts, ground and +5volts.
looking at the other pins that are connected there is supply at least once for all the above...
HELP PLEAESE
Powered by Rollin Motorsport
Turbo Barra ED 4L
OED666 is offline   Reply With Quote Multi-Quote with this Post
Old 19-08-2007, 05:54 PM   #2
Bundy
All Ford Club Life Member
Bundy's Avatar
No - Upgrade your PSU and do right and you wont have any headaches, $65 should see you right for a decent enough one.
Worked AU XR8 Ute - Toy
Std FG XR6T Ute - Daily
Supercharged BA 6 Ute - Wife's daily
351W F150 93 XLT 4x4 Supercab
Bundy is offline   Reply With Quote Multi-Quote with this Post
Old 19-08-2007, 06:37 PM   #3
ef_classic
ef_classic's Avatar
There should be a seperate 4 pin connector from your PSU.
ef_classic is offline   Reply With Quote Multi-Quote with this Post
Old 19-08-2007, 06:42 PM   #4
BeStRaFe
lpg = big boom!
BeStRaFe's Avatar
the standard 20 pin connector will work,
the extra 4 pins are useless at the moment, they are there but never used.
as long as its p4 compatible aka has the extra 4 pin connector to go into the 4 or 8 port bit on the mobo it will be fine
owning computershop and working in it has tought me alot...
they want you to upgrade when you really dont need to
BF Futura Dedicated E-GAS w/Ghia bling
Project: 86 ZL Fairlane, Red, Sunroof, 310,000KM
BeStRaFe is offline   Reply With Quote Multi-Quote with this Post
Old 19-08-2007, 06:49 PM   #5
OED666
OED666's Avatar
well, its running..
i connected the 20pin and there was an extra 4pin connector which is also now connected.
now the long process of formatting 320gb drives and installing win xp pro.
thanks for the help.
i think i will eventually get another PSU though.
Turbo Barra ED 4L
Old 19-08-2007, 07:23 PM   #6
ILLaViTaR
ILLaViTaR's Avatar
Holy crap with a P5K board I'm guessing you're running a CPU with 1333fsb?
I'd get a new power supply asap.
Right now your stressing the outta ya PC.
How many Amp's does the PSU have on the +12 section of the table?
Also how many rails does it have?
EB II 1992 Fairmont - koni reds, wade 977b, 2.5inch/4480's and much more to come!
ILLaViTaR is offline   Reply With Quote Multi-Quote with this Post
Old 19-08-2007, 08:07 PM   #7
BeStRaFe
lpg = big boom!
BeStRaFe's Avatar
if you know anything about electronics and computers....
the "500" watts a power supply gives in not 500 watts.
divide it by 1/3'rd and you will get a true measure.
if you want something good and reliable get a HEC
i have a 750w running all my pc
QX6800
2 x 8800GTX
4 x 72GB 15k SCSI
2 x 1TB Hitachi
its all the speed, and all the power you can want.
the "watt o meter" i have running is telling me im drawing 320w's
and thats me coding a dvd
Old 19-08-2007, 08:36 PM   #8
Riksta
Captain Malcolm Reynolds
Riksta's Avatar
And whatever you do, avoid Codegen power supplies :P
Currently: 2014 Mazda6 GT (Daily) and 1999 Mazda MX5 (Fun Car)
Previously: 2001 Ford Escape XLT; 2010 MC Mondeo; 1984 FD LTD; 2001 AU2 Falcon Forte; 2005 LS Focus Zetec; 1988 RE Colt; 1982 RB Colt; 1974 KE20 Corolla
Originally Posted by Nikked
Riksta likes VN's so much, he has the ashes of a VN in a jar on the mantle piece, a vile of VN engine oil hanging from his neck and a BT1 build plate locked up in a safe, buried under 6ft of concrete.
Originally Posted by Day-mow
pretty much what has happened here is i trolled you. and it was fun.
Riksta is offline   Reply With Quote Multi-Quote with this Post
Old 19-08-2007, 09:10 PM   #9
OED666
OED666's Avatar
well, it seems to be running fine... i am not the net again.
its only running at 800mhz FSB at the moment. i will get around to tuning it a little later
its much faster than my previous insides... PIII 733, 640MB Ram, 60 + 30GB Drive, 64Mb Video card...
This one is... Intel Core 2 2.0Ghz, 2Gb Ram, 2 x 320Gb SATA drives, 256Mb PCI-Ex Video card, blah....
Turbo Barra ED 4L
Old 19-08-2007, 10:08 PM   #10
BeStRaFe
lpg = big boom!
BeStRaFe's Avatar
cogen are the rebranded tywaneese company that do the likes of
aopen
ritmo
omni
and about 30 other no-name brands
Old 20-08-2007, 12:43 PM   #11
OED666
OED666's Avatar
ok... just to confirm something...
below is a pic of the motherboard.
Near the keyboard connection there is another 4 pin power supply. My current PSU has this connection as well as the 20 pin connection...
Do I still need a 24pin connection? I have searched the net, and from what i have read i dont need a 24pin supply, if i also have the extra 4 pin connection... slightly confused.. :(
Turbo Barra ED 4L
Old 20-08-2007, 01:31 PM   #12
BeStRaFe
lpg = big boom!
BeStRaFe's Avatar
the extra 4 pins on the 24 pin psu dont do anything at this stage
just an excuse to sell you a psu when buying a new mobo :-/
it will be adapted, but not yet probally
just like the 4 pins near the ps2 ports were needed to a few years go
