04-09-2012, 10:57 AM | #1 | ||
Workshop & Performance
Posted in here as it's not necessarily specific to the Ka I'm working on.....
Have to replace the original '99 Ka TA return hose on the power steer (it's dated and has done well to survive 13 yrs). Anyway....looking for options as Ford spare is no longer available. Anywhere in Adelaide have a good selection of hoses I could check out and try the match game? Or any Ka owners know of a alternative that works? Thanks for any help
When close is good enough and the 6 MPS in the driveway has FoMoCo written all over the place. Xr5 for sale shortly...just not a hatch guy |
04-09-2012, 11:04 AM | #2 | ||
If it ain't broke........
Being a return line is it all rubber or does it have pipe then rubber ? If it's all rubber just go to a hose shop and ask for 3/8" R6 Hose. If it has a section of pipe put up a photo of it and measure the O.D of the pipe for me, and I'll let you know what else to grab.......
Visitors welcome Relatives by appointment only Last edited by buggerlugs; 04-09-2012 at 11:10 AM. |
04-09-2012, 11:19 AM | #3 | ||
It's all rubber, had factory crimp clamps on it but definitely the return not the high pressure side. Dimensions are around 16-17mm inside diameter outside 25mm. (could be slightly out with age/stretching on the fitting).
04-09-2012, 11:57 AM | #4 | ||
Is it moulded to shape ?
Visitors welcome Relatives by appointment only |
04-09-2012, 12:53 PM | #5 | ||
Yeah sure is but not over complicated heading to Repco see what they can supply.
04-09-2012, 03:07 PM | #6 | ||
Unfortunately my usually astute referrals fall flat :(
12mm max, inner diameter 5/8" needed (around 16mm), no deal. ANY idea's or suppliers welcome. Please remember I'm private, not trade, and I'm not up for buying 50m+ minimum orders ;)
04-09-2012, 03:41 PM | #7 | ||
pirtek, enzed, just regular hydraulic hose will do
04-09-2012, 06:35 PM | #8 | |||
04-09-2012, 06:39 PM | #9 | |||
06' BF XR6T manual sedan in Bionic Blue.....written off 08/15......greatly missed... New ride....07' RSpec manual Typhoon in Winter White....factory sunroof, Premium sound, Process West intercooler, upsized tubing, valve springs, 1000cc injectors, Delphi intank pump,*modified turbo, 4" dump, 5" cat, dual 2 1/2" Xforce exhaust, Mal Wood Opt 5 clutch, Herrod shifter, Ozrace coilovers with adj. Whiteline bars, 6 spot Brembos, Edit by Crescent Motorsport.....382rwkws @ 1150nms on E85.... |
05-09-2012, 04:56 PM | #10 | ||
Thank you will make some calls tomorrow
05-09-2012, 07:17 PM | #11 | ||
Another vote for Pirtek or hyd shop should be able to make something to match up
