Site Support If something isn't working or you have a suggestion ( a nice one !! ) let us know here. |
Hi, I seem to be having trouble creating a new post in the for sale section.
Why I click on the 'post new thread' it opens a new page but nothing loads...it just stays on a blank white page. Every other section of the forum works and I am able to start a new thread or post...it's just the for sale area. I have tried it on 3 different computers in different houses and also on my phone through safari and always the same thing. Has anyone else encountered this problem? It was working a few days ago. Cheers |
Awesome
Location: In my own little world..Everyone here knows me :)
It is coming up blank for me as well. This is one for russellw to solve
Chairman & Administrator
![]() ![]() Join Date: Dec 2004
Got me mystified. I note that some people have managed to post using the forms this evening but as you are the second person to notice it and I can replicate it something has obviously broken although I can't see what.
I'll keep looking. Cheers Russ
Observatio Facta Rotae
Awesome
I am using Firefox Russ. I will clear my cache and see if it loads up
![]() Cheers Col
I just tried it too. using IE 10 but also tried in compatibility mode
[SIGPIC][/SIGPIC]
+1 for not working
Not working here either, rather annoying.
Perhaps you'd like to fix it then?
It's hardly as if we have deliberately broken it just to annoy you. I'm working on it but I happen to have a day job to go to as well which tends to restrict my available time. Russ
That's not at all how that comment was meant, sorry if it came across that way.
OK, the template used to post Cars for Sale is back working - I haven't fully tested it but at least the page displays properly now.
Unfortunately I had to reimport the hack code so the original hooks are gone so I will have to recreate the part and misc sales one. Shouldn't take too long. Cheers Russ
#11 | |||
I've reinstalled the part/miscellaneous form so that should now be working too. Cheers Russ
#12 | ||
#13 | |||
TEST POST 1 I will now go and try the miscellaneous area. Cheers Russ
#14 | ||
Misc area is now working - had to create a new form for it so that it stopped posting in the Spare Parts forum - I know we had to find a way around that when we first isntalled it but it's easier to make a new template!
TEST POST
#15 | ||
Worked for me too just now. Thanks Russ for the quick response and fix!
#16 | ||
Hey Russell my thread still won't post, any ideas why that may be?
#17 | |||
Cheers Russ
#18 | |||
#19 | ||
I presume that you:
1. Fill in the form 2. Upload an image using the button at the bottom then ... 3a. Press submit and then get the error? 3b. Post submit, get the edit page and then submit and get the error? Cheers Russ
#20 | ||
Press submit, it goes to the redirecting page, redirects me and then comes up with the error.
#21 | ||
Before you submit can you copy the url out of the browser navbar for me and then also copy it when you are at the error.
Cheers Russ
#22 | ||
#23 | ||
Hey mate, still not working for me unfortunately.
#24 | ||
I just posted a test and it worked fine, Russ feel free to delete the test thread.
Campo try deleting your cookies and see if that helps, you might also try a different browser. are you trying to post at work? if so you might be behind a firewall that's causing dramas
[SIGPIC][/SIGPIC]
#25 | ||
Au3xr6, have tried all that, exact same errors
#26 | ||
have you tried a different PC at a different location?
[SIGPIC][/SIGPIC]
#27 | ||
Ended up having to post from tapatalk on my iPhone and edit the post. Maybe its just something to do with the for sale template? Odd..
#28 | ||
For some reason i cant even se the for sale section.
#29 | ||
Experienced Member
#30 | ||
