02-01-2013, 07:15 PM | #1 | ||
I've been driving a xr6 ef for the past few months, and it has been lowered on cut springs in the past. I havent yet put new springs in, and the car is way too bouncy and rubbish to drive (its not that low, just bouncy and if you go on an angle up steep driveways you can hear the springs pop out.
If i lower my car properly, will it be better/smoother/less of a pain in the *** to drive. If I buy lowered springs (King, Pedder, etc), what will the difference be? And if I buy lowered springs/shockies together, will the car drive like a normal height car, despite being lowered? Obviously if the shockies make no real difference, I dont wanna pay the extra $300+. Info? haha. |
02-01-2013, 07:26 PM | #2 | ||
The difference is you wont get your car taken off the road by the police if your driving around on cut springs!
Stop driving the car around is the first thing you should do.
You've seen it, you've heard it and your still asking questions?? Don't write off the Goose until you see the box going into the hole.... |
02-01-2013, 07:31 PM | #3 | |||
If you get it all done correctly, it will drive like it should. I am so against chopped springs. There was an accident a few years ago. Car driving 130ks on the freeway, had chopped springs, went over a bump, driver lost control because of the bounce and ended up in trees killing 4 of them. |
02-01-2013, 07:37 PM | #4 | ||
I've stopped driving it because of this, unless its down the road to the shops or whatever. I drive about 45min to work, and have started using my old car, I dont trust the falcon at higher speeds as it is, which is why Im looking at he best option.
So is it worth buying the right gear, or will it always drive like rubbish? Or should I just go get some normal ride height springs from the wreckers, and deal with a car looking like a 4x4. I understand proper lowered springs will help the ride, but will it be a huge change? Or will it still bounce and whatnot. Or are the shockies needed aswell to make it drive like it should? I'd prefer the cheaper option if it will make the ride noticeably better, but if it wont make a real difference I'll obviously get the full setup. |
02-01-2013, 07:37 PM | #5 | ||
And make sure you get all the camber adjusted properly or you'll be chewing tyres out like nothing ...... My guess is you probably already are if you cut your own springs !
02-01-2013, 07:56 PM | #6 | ||
It was the bloke before me who lowered it, not well at all. Only lowered the rear luckily. Camber wear is fairly terrible, but once I fix the suspension setup if you guys give me the info i need lol), I'll have an alignment, new tyres, and adjust the camber.
02-01-2013, 08:05 PM | #7 | ||
How on earth was the car re-registered?
Who did the road worthy?
02-01-2013, 08:09 PM | #8 | ||
Come on jimmy everyone knows a dodgy mechanic lol
02-01-2013, 08:09 PM | #9 | ||
I have only had it a few months, it doesnt need rego until May. Which is why its sitting outside, not being driven, and why Im asking these questions to correct the issues it has before they become BIG issues. Is there any help you can give me, or more irrelevant nonsense?
02-01-2013, 08:14 PM | #10 | ||
Maybe check the shock mounts as well. My advice would be do a bit of research on a combination of shocks & springs to get the result you want. Sometimes it can get messy when you swap over only the springs or only the shocks, without thinking of how it will affect the latter.
If you're worried about the cost of the components but you still want a low ride, might I suggest trying to find a second hand set of Monroe GT shocks & some new king springs?
DAS IT MANE
02-01-2013, 08:15 PM | #11 | ||
Thailand Specials
I've got standard height king springs in the rear of my EL Fairmont Ghia with new Boge shocks and the rear passenger side one pops out, so avoid King Springs when you go to do it properly, my mechanic who is checking over my car and doing the RWC on it said its not the first time he has seen this with king springs and chances are its a dodgy spring.
When you go to do it properly go with Lovells springs, I hear they're quite good. Cut springs are dodgy as hell. |
02-01-2013, 08:16 PM | #12 | |||
So you think, the simplest practice would be to just buy a set off ebay or somehing. SSL springs with the nesscessary shocks? Assuming if they're sold together they're meant for one another, lol. And the ride should be a lot more gentle? Less bouncy? Theres no scraping or anything, just stiff suspension. |
02-01-2013, 08:16 PM | #13 | ||
To answer your question on what I recommend.
I would say get a full set of springs and shockers. Get new ones because putting in second hand parts is counter productive. If you lower it buy a decent set of shocks which peddles should be able to help you with, so you get the stance you want, and the ride you want, which depending on what range you pick, you may be able to get it very stiff, or a nice firm feel, that will still be comfortable and not feel like your breaking your back. Profile of tyres also have a lot to do with this. If you go a super stiff shock and spring, no matter what height, if you have a decent profile like a 45 or 50 series, it will lessen the harshness of the ride. |
02-01-2013, 08:18 PM | #14 | ||
meh.
Lol, I had cut springs on standard shocks In the front of my car for a year, and honestly, I didn't feel unsafe at any moment. I was even pulled up and the cop didn't even check for chopped springs. I just said it had been lowered on factory shocks, which is why it's a little bit stiffer then standard.
I've now got some Boge shortened shocks, and King Lows, and I don't have any issue with the springs popping out, even at full travel.
02-01-2013, 08:19 PM | #15 | |||
Im happy to get the better brand springs/shocks, assuming they're a similar price, I just dont know how to get my hands on them. |
02-01-2013, 08:20 PM | #16 | ||
Agree with the above. Get some king springs off eBay and some lower shocks to go with them. Can be had pretty cheap. They will stiffen the car up a lot compared to what's in there now. If you like the ride height then go lowered springs and shocks. If you want it at standard height then king springs in the standard height will still stiffen the ride up for you.
Rapid "04" ba2 xr8 t56 sedan PERFORMANCE MODS CAI + pod filter. That's all for the moment. More to come soon VISUAL MODS 18in wheels wrapped in pirelli pzero nero. Push button start. Black XR8 badges, black 260 bonnet stripes, black 260 spoiler stickers, blackened sections on my tail lights, tinted side indicators, blue interior LEDs, HID head Lights, LED angel eyes and a BF typhoon front bar in the shed waiting to get painted. |
02-01-2013, 08:23 PM | #17 | |||
02-01-2013, 08:25 PM | #18 | |||
RE the second hand shocks if there is a limit of only about 300 to spend, don't expect to get a problem-free result by any means. Monroe GT shocks are good as a new and cost effective solution to old shocks, however my recommendation is Koni adjustables or bilstein shocks. But that is about $300 per shock lol
DAS IT MANE
02-01-2013, 08:30 PM | #19 | ||
In my Ef xr6 I had Monroe gt super low shocks and super low springs and it was so stiff it was to stiff. Other people have also said that king springs are a very harsh ride when going lower then stock height. Whereas pedders shocks and springs that were in a mates xr6 gave him same height, same handling, but when cruising, a far more comfortable ride.
02-01-2013, 09:36 PM | #20 | ||
no no no.... not true...
02-01-2013, 09:39 PM | #21 | ||
BURN RUBBER NOT OIL
This is my EF Fairmont Ghia setup:
- King spring superlows in the front - King spring ultralows in the rear - Ultima shortened sports shocks - Nolathane camber kit The car handled like it was on rails for years until I started doing heavy towing and the rear shocks slowly died. I have replaced them now. My tips: - Nolathane fine thread camber kits are rubbish. The securing nuts would always loosen off meaning I was doing my camber all the time. In the end the actual bracket failed and the top arm in the car could move.. NOT GOOD AND COULD OF CAUSED A SERIOUS ACCIDENT IF I DIDN'T PICK UP ON IT!!! - Use a shim type camber kit. Once they are installed they wont need to be touched. - Think hard about how you drive and where you drive. A low car WILL bottom out everywhere.
[TUFF4L] EF Fairmont Ghia build thread - http://www.fordforums.com.au/showthread.php?t=11381891&highlight=tuff4l [SMOKES] FG XR6 build thread - http://www.fordforums.com.au/showthread.php?p=4795218#post4795218 |
02-01-2013, 09:44 PM | #22 | ||
re
Location: Victoria - where being slow & incompetent is considered being "safe"
Also think about how long you are going to own the car. Go cheap on the short termers and expensive on something that you are going to hang on to.
I did the expensive route on a car that I sprinted and daily drove for 7 years after the suspension changes and never regretted it. +1 for the alignment check after the changes.
Scuderia Rev: Otto the tow pig - 2007 3.0 litre Coupé, vernünftig schnelle aber kein peilstab, Bathurst 2007 und 2010 zwölf Stunde Gewinner Jaffa the angry ant - mid 70's Honda 市民の, 73 と立方インチ LSD Elle "the body" shell - early 70's Datsun フェアレディ coupe. いい体は彼女の内側、内側と土台を待つ |
02-01-2013, 09:47 PM | #23 | |||
Thailand Specials
Justin at Tuff Car Parts, one of our sponsors can get us pretty much everything for E series Falcons and at good prices. Ask him if he stocks Lovells springs. http://www.lovellsauto.com.au/dist.php?d=3 Their website has distributors as well if he doesn't deal in them. |
02-01-2013, 09:59 PM | #24 | ||
Peter Car
What do you mean cutting springs isn't the right way to lower a car, thousands of Commodore drivers can't be wrong.
4 users like this post: |
02-01-2013, 10:00 PM | #25 | ||
What state are you in? Ive got King Springs V8 superlows/Monroe GT sport shocks sitting on my bedroom floor doing nothing, still new. Its one of the kits you see on eBay going for around $700.
02-01-2013, 10:40 PM | #26 | |||
DAS IT MANE
03-01-2013, 09:27 AM | #27 | ||
Im in NSW. I dont know how long ill have this car, considering travelling for work keeps coming up, and a smaller car would be.on the cards in that case. which is why i dont want to spend much more then $600 or so on a setup.
03-01-2013, 10:32 AM | #28 | ||
There are so many variables to suspension set up.
The best advice I can give is go to pedders, selby suspension or kmac suspension and tell them your budget and what you want out of the car and they will put you on the right track. On the forum if you get a hundred replies you will probably get a hundred different opinions. Most of them will probably be right for the poster but maybe not for your application. If you spend $600 your car will definately be better than cut springs. The problem with cut springs is that a lot of the spring action is taken away when they are cut. When you buy a manufactured spring the spring rate is upgraded to compensate for the loss of spring travel. When you cut a spring this doesn't happen. Also most people cut springs with a grinder or oxy putting heat into the spring and it can lose its actual springyness and become soft. Also most people cut too much off so the spring is completely stuffed. All these things contribute to what you are experiencing now. Ask about progressive rate springs they will give you a good ride and good handling when combined with the right shockies. Don't underestimate the importance of good quality shocks. They are very important to the ride and handling of the vehicle. Adjustables are great but dearer. Don't go too low you will get a harsh ride. As for your particular application go to the places mentioned above. They are the experts and will solve your problem. Hope this helps you with your decision. Cheers Ken
http://www.fordforums.com.au/showthr...sic+xp+cruiser |
03-01-2013, 11:26 AM | #29 | ||
King/Monroe combos are going for $650 inc shipping on eBay for E series at the moment. If you can pick them up from Western Sydney and are happy with the front end sitting higher being a V8 spring set, I still have my super lows.
03-01-2013, 11:42 AM | #30 | ||
I used to have an EBII Fairmont running King springs ("Lows" at XR height), with KYB struts and
a Nolathane camber kit up front and Monroe GT gas shocks in the rear. A good setup with a reasonable price.... Car handled great for a live rear axle and not too low either for every day driving situations.
