Trying to get my timeing right on my cortina , got it lined up sweet with centre mark but has a weird poping sound coming from ex aught ,or chugging sound where is best spot to set should I retart or advance more hope some one can help thanks
64 Deluxe 4 door
![]() Join Date: Jun 2007
What marks do you have lined up?
I assume you are using a timing light........ is it auto or manual try about 8 deg BTDC for manual & 12 for an auto if it pings pull it back a bit. Make sure the balancer hasnt slipped.... read ----------->>>>>>>>>> http://www.classicinlines.com/IgnitionTiming.asp
XM Deluxe FG XR50 BA Pursuit Ute |
Is the popping noise coming through the exhaust when down gearing/ stopping at lights etc?
Yeh the popping noise is when I am stopping at lights but not sure about down gears cause my te is a auto , and when we had the rocket cover off a few weeks ago my old man marked TDC on the fly wheel I think it is , I lined up top dead centre with the 3marks on the motor it is perfectly lined up with centreone but sounded **** one of my mates advanced it a little more witch got rid of the flat spot I had on xlration (mind my spelling ) and sounded smooth as ,but now more pre ex notion , I bought a second hand redline intake manifold and it has a carby witch looks just like a 350 Holley ,can not remember what the brand was ,and it has bugger all markings on it , but the bloke said it runs sweet as , going to put that on today ,and see how she goes , there is no need for the heater box any more so I will get rid of that , and plate up the hole when I have removed it , just sick of that little stromburg single barrel , I will post about how I go but thanks for your help winton ,redxm
If its popping out the exhaust you might won't to lift the rocker cover and check the valves, sounds like one may have dropped, if this is the case eventually it will drop in to the motor if left,.
