Old 26-01-2013, 03:50 PM   #1
[XR6FTW]
JoshyXR
[XR6FTW]'s Avatar
Default Catalytic converter
I just put a series 1 bf cat system on my bf XR6 which had a cat and a small muffler on it all in one to begin with. Is it ok to replace a cat on it with no small muffler?
Thanks guys?
For every will.....there's a way
[XR6FTW] is offline   Reply With Quote Multi-Quote with this Post
Old 26-01-2013, 03:54 PM   #2
FPV GTHO
Technical Contributor: For members who share their technical expertise. - Issue reason: Sharing his knowledge of performance exhaust setups for the NA 6 cyc Barra Falcon from BA to FG.
Default Re: Catalytic converter
The BF system is as you describe, the BA factory cat pipe doesn't have the resonator although it doesn't have a Euro 3 cat either. It will fit and it won't be as bad as most aftermarket cats but I'd imagine if you ever run into any trouble and the car gets tested it will fail emissions. It's possible for an old BF cat to fail as well however.
FPV GTHO is offline   Reply With Quote Multi-Quote with this Post
Old 26-01-2013, 04:59 PM   #3
AWD Chaser
Formally Kia Chaser
AWD Chaser's Avatar
Dont know rules in VIC but up here im pretty sure you cant ruduce the number of mufflers from factory...
Kia Grand Carnival (2006)
Silver, Grill Mesh, Tints, Sidesteps (with lights), Towbar, 7" Touch Screen DVD Tuner with intergrated GPS & Bluetooth, Roof Mounted Flip Down 15.1" LCD Screen, Reverse Camera - 184Kw
HSV Clubsport R8 VY (2003)
Black, 6sp Manual, Coulson Seats, Red on black interior, Pacemaker extractors, Twin 2.5" exhaust, Custom Red 20" VE GTS Rims, Custom Red Stitching
AWD Chaser is offline   Reply With Quote Multi-Quote with this Post
Old 26-01-2013, 05:44 PM   #4
ryeman
FWIR I seem to remember something about 90db measured at 45deg x nr of metres fm outlet will determine if its acceptable but a pro exhaust shop should know.
Wherenoshockjocksfly
Facts or the twitterverse, your choice!
M3SR+ .......MG ZS EV
ryeman is offline   Reply With Quote Multi-Quote with this Post
Old 26-01-2013, 06:17 PM   #5
buggo
[BU66OS]
buggo's Avatar
He's more concerned about the emissions rather than the noise I gather. He's replaced it with a stock system.
FG XR6 Turbo Nitro
BA XR8 Manual
buggo is offline   Reply With Quote Multi-Quote with this Post
Old 26-01-2013, 06:36 PM   #6
ryeman
Yeah, but I don't think emissions other than noise would be affected by a muffler removal ....(?)
Old 26-01-2013, 06:52 PM   #7
ratter
ratter's Avatar
a different cat can affect emissions
Pit Lane Performance
Old 27-01-2013, 10:57 AM   #8
[XR6FTW]
JoshyXR
[XR6FTW]'s Avatar
Noise has deffinately increased. I was worried about whether it would affect the car. Engine light has gone off which is a good sign!
Dont know about emissions though.
Thanks guys
Old 27-01-2013, 11:00 AM   #9
[XR6FTW]
JoshyXR
[XR6FTW]'s Avatar
[WIKI][/WIKI]
I replaced it with an aftermarket systwm tht doesnt have a resinator!
Everything seems to be ok! Thanks for your help
Old 27-01-2013, 11:08 AM   #10
Franco Cozzo
Thailand Specials
Franco Cozzo's Avatar
Just don't attract attention to yourself, thats my plan.
Factory looking EL Fairmont Ghia, been lifted to standard Falcon height, 15" standard alloys, car looks plain on the outside.
Under the hood I've got ported and polished head, stiffer valve springs, cam, bigger exhaust valves, pacemaker 4499s, 200 cell stainless high flow cat and a pex 2.5" mandrel bent exhaust with 2 mufflers and a resonator.
Extractors are going to be covered up with an AU Falcon heat shield, so if you pop the bonnet, you wouldn't even see anything out of the ordinary.
Franco Cozzo is online now   Reply With Quote Multi-Quote with this Post
