Old 10-02-2013, 09:29 AM   #1
Bexsarm
Default Led globes
I have BF xr6 and tried led globes in the indicators (rear only)and they flash like crazy, what needs to be done to slow them down.
Bexsarm is offline   Reply With Quote Multi-Quote with this Post
Old 10-02-2013, 01:03 PM   #2
a-total-tool
a-total-tool's Avatar
Default Re: Led globes
Issue is not enough load on the Blinker circuit (due to LEDs drawing less current than normal bulbs). You need to either replace the flasher unit to one that is LED compatible or add a resistor/bulb to each side of the car
a-total-tool is offline   Reply With Quote Multi-Quote with this Post
Old 10-02-2013, 03:55 PM   #3
Silver Ghia
Silver Ghia's Avatar
Yep, you can't just replace the indicator bulbs with LED's. Nor the brake light bulbs.
Silver Ghia is offline   Reply With Quote Multi-Quote with this Post
Old 11-02-2013, 03:17 PM   #4
Bexsarm
Can't change relay as I believe it is part of electronic system. How does the resistor fit into the system.
Old 11-02-2013, 03:26 PM   #5
flappist
Put it between the pos and neg of the lead going to the LED cluster.
The value and rating of the resistor will depend on the original rating of the bulb as it has to emulate its current draw.
e.g. if it was a 24w bulb it would draw 2 amps at 12v (2a x 12v) so your resistor would be 6 ohms (12v / 2a).
The resistor would have to be rated at least 5w or preferably 10w so it does not overheat easily. If you spend all day in traffic and indicate constantly then an even higher wattage would be prudent.
Old 11-02-2013, 06:58 PM   #6
Bexsarm
Great, thanks for the help
Old 12-02-2013, 08:25 PM   #7
roberts
globes plus resistors was the correct answer. Splice and solider the loom.
Can I ask why your bothering?
roberts is offline   Reply With Quote Multi-Quote with this Post
Old 12-02-2013, 08:30 PM   #8
Dash_XR
Dash_XR's Avatar
Yeah I blew a loom on one side with so called LED brake lights.. Lesson learned.
FG XR6 Turbo (Manual) - 301rwkws @ 15psi
Rapid Systems Intercooler & Battery Relocation - ID 1000 Injectors - Process West Surge Tank - Venom 100 Cell Bolt On Cat - XForce 3.5 inch Catback - Plazmaman 4 inch Turboside Intake - Crow HD Valve Springs - Glowshift Gauges (Oil temp, Oil Pressure, Boost, Volt) - Malwood Opt 5 - XR50 Interior - FG2 Limited Ed 19's - Nitto Invo's
Dash_XR is offline   Reply With Quote Multi-Quote with this Post
Old 12-02-2013, 08:34 PM   #9
roberts
no Chinese parts on and Australian car
Old 12-02-2013, 10:36 PM   #10
Franco Cozzo
Thailand Specials
Franco Cozzo's Avatar
Narva makes LED load resistors I think.
http://www.narva.com.au/products/bro...oad-resistor-3
Solder it in, don't use the scotch lock or it won't work after you drive out of the drive way.
Franco Cozzo is online now   Reply With Quote Multi-Quote with this Post
Old 13-02-2013, 06:50 AM   #11
mash again
I just stripped a ba for racing, given the markings on the wiring loom ib be betting the loom comes from china, or somewhere using a symbol type language!
mash again is offline   Reply With Quote Multi-Quote with this Post
Old 13-02-2013, 07:17 AM   #12
Nikked
Oo\===/oO
Nikked's Avatar
Yes, the Falcon is 100% australian, no parts at all from Mexico, Thailand, China etc...
Check out my Photo-chop page
T...I...C...K...F...O...R...D
\≡≡T≡≡/
Nikked is offline   Reply With Quote Multi-Quote with this Post
Old 13-02-2013, 06:16 PM   #13
Franco Cozzo
Thailand Specials
Probably manufactured by Lumen, thats who we use at work.
Old 13-02-2013, 07:15 PM   #14
Dash_XR
Dash_XR's Avatar
Sorta, my cars got a few Chinese parts.
When it's cheaper to get alloy bends shipped from china then walk across the road to supercheap then why not. Better quality too believe it or not.
Catch can's from America and was nearly half the price of anything similar I could find local.
Few silicone bends from the UK etc..
Most wedge LED's i've bought over the years are from china too just no more important electrics.
Allot of shops important the same stuff just add their bit on top.
Old 13-02-2013, 08:52 PM   #15
Bossxr8
Peter Car
Bossxr8's Avatar
Wiring looms are usually Sumitomo.
Old 13-02-2013, 09:15 PM   #16
twodogs
twodogs's Avatar
B S , My fg xr6 ute has a few factory Chinese parts.
twodogs is offline   Reply With Quote Multi-Quote with this Post
Old 13-02-2013, 09:27 PM   #17
Dash_XR
Dash_XR's Avatar
Pretty sure he was being sarcastic.
I will always try and support Australian built cars but if the aftermarket gets greedy then I have no problem going overseas.
