Old 14-02-2013, 12:09 PM   #1
bigev
Bloke
Default Mondeo Rear Brakes - Tricky Little Buggers
I wanted to share my experience with changing the rear pads on my 2010 Mondeo, a task which I assumed(!) would be as easy as that on my Falcon. Turns out, not so much ……
This is more a note of possible issues for those planning on doing it themselves, as well as a future note for myself as I have a memory like a sieve. If I’ve missed something that would make this an easier job in the future please comment. I do not suggest that the way I went about this job is the right way. Is there a better way?
It all started with the obvious sound of metal-on-metal when braking. The car is just over 60,000kms and still on it’s first set of rear pads and disks.
I made the decision to change the pads that afternoon to avoid any significant disk damage, so I headed on down to my local Repco and bought the default pair of rear pads.
Starting on the passenger side I took the rear wheel off and undid the caliper – that was where things started to get tricky.
It became clear pretty quickly that I could not press the piston back at all. This was a real issue as the pads had caused a small lip on each side of the rotor. No matter how I tried I could not get the pads over those lips as there was no play from the piston. After some researching I discovered the fact the pistons are screw-in type and not push in like my EF. Now I will admit I had not done any research in to how to change these pads, but I realised I was in a bit of bother.
In the end I had to file a section of lip off each side of the disc so the caliper would slide off the rotor. This worried me as removing some lip off just one section of the rotor would make the rotor unbalanced and may introduce some wobbling to the wheel. I decided that it would be smart at this stage to buy new rotors so this would not be an issue. After checking with the three local big stores (Repco, Bursons and SuperCheap) none of them stocked the rotors (and I wasn’t paying Ford prices). So I skipped that step and decided to risk keeping the old rotors. (it’s worth noting the rotors are only about ½ used).
My next difficulty was screwing the piston back. Turns out you need a special tool. So, back to Repco to buy a dice-shaped device that does the trick.
Now this dice-tool didn’t properly fit the piston. I had to use an angle grinder to modify one of the sides so it would fit (I turned a 4-pin side to a 2-pin side). Hooray – it fits.
Next difficulty came after about 10 minutes of screwing the piston in – it wasn’t going back in. Another quick Google reveals you need to push in HARD to get the piston to lock on the threads. Finally, I got it going and after about 15 minutes of stuffing around the piston was screwed in.
The new pads took a bit of stuffing around to get on to the caliper but went on OK in the end.
After the lessons learnt on wheel one, the second wheel was much faster. I reckon all up I spent maybe four hours on the first wheel and a little under 1 ½ hours on the second. The most time consuming part in all this was the filing back of the lips on the rotors. If there’s a next time I might try a power tool of some sort to help out with the lip removal rather than a hand file.
I reckon I’ve reduced the lifespan of my knees by a few years. Turns out kneeling for long periods on concrete makes ‘em a bit sore.
Also FWIW there’s no noticeable wobble in the wheels from the modified rotors. Hopefully I’ll get a couple more years out of them yet.
bigev is offline   Reply With Quote Multi-Quote with this Post
Old 14-02-2013, 02:43 PM   #2
tweeked
N/A all the way
tweeked's Avatar
Default Re: Mondeo Rear Brakes - Tricky Little Buggers
Yeah I had this with an Astra a couple of weeks back. Got the old pads out and after 20 minutes trying to turn/push the piston back, I gave up and took it to a mechanic.
BA GT
5.88 litres of Modular Boss Powered Muscle
300++ RWKW N/A on 98 octane on any dyno, happy or sad, on any day, with any operator you choose - 12.39@115.5 full weight
tweeked is offline   Reply With Quote Multi-Quote with this Post
Old 20-02-2013, 01:11 PM   #3
73gscoupe
73gscoupe's Avatar
Not that tricky.. they are similar to the old XD - XF falcon rear disc setup with the wind in piston. But certainly not easy like the fronts.
Wheel off, two bolts and the caliper is loose. Torx bit to remove the disc retaining screw. No need to touch the handbrake, but you can slip the cable out at the caliper to make things easier.
Hit the lip with the angle grinder (I was replacing discs anyway) and the caliper is free.
Remove pads, wind the piston in with a set of needle nose pliers, pushing in hard. The piston should move/ rotate smoothly, but not easily. Check the reservoir whilst your doing it in case of overflow. Bolting the caliper back to the car can help steady it whilst you wind it in.
New pads in, reassemble. Takes about 30 minutes per wheel, 1 hour total, if your setup to do it.
73gscoupe is offline   Reply With Quote Multi-Quote with this Post
Old 16-03-2013, 01:14 AM   #4
marcusturbo
marcusturbo's Avatar
I posted up something similar about 6 months after I discovered exactly the same problems as yourself. I started by doing the front pads, bing bang bosh, both sides done without any dramas. Moved to the back and it took me about the same length of time as you on one side. I did the otherside the following morning.
I will be doing the same again soon as the rear disc's are close to needing replaced, least it will be slightly easier this time but still need to get pads passed that damn lip!!!!
Accept that some days you're the pigeon & some days you're the statue.
marcusturbo is offline   Reply With Quote Multi-Quote with this Post
