21-02-2013, 11:38 PM | #1 | ||
folden guy
So today i drove back from dalby in qld where i filled up and drove back to brisbane, i useed 1/4 of a tank.....it sais it was 10.2L/100K doing highway driving.....could i make that better by changing fuel filter or other things (unknown) ?
21-02-2013, 11:40 PM | #2 | ||
What were you driving?
21-02-2013, 11:44 PM | #3 | ||
folden guy
A 1996 ef fairmont sedan
22-02-2013, 01:06 AM | #5 | ||
folden guy
I said to my mum "ill be happy if it hits 10" but i want it using much less lol
22-02-2013, 02:22 AM | #6 | |||
Possibly acceptable for an auto, not so good for a manual. Also 6cyl or 8cyl? Cheers Vincenzo
$DO || ! $DO : try try: command not found - (YODA the Geek) "WRC is for boys, Group B was for men" - Juha Kankkunen 4 times World Rally Champion Romanes Eunt Domus - 'people called Romanes they go the house' - You mean Romani Ite Domum [SIGPIC][/SIGPIC] |
22-02-2013, 03:08 AM | #7 | ||
folden guy
It was visual by the guage, sorry its auto with the 4.0 engine no mods or anything stock
22-02-2013, 05:38 AM | #8 | ||
If the oxygen sensor is old, it will usually help replacing that.
FG MkII G6 Ecoboost in Lightning Strike
22-02-2013, 07:10 AM | #9 | ||
folden guy
Oh easy replacement?
22-02-2013, 07:20 AM | #10 | ||
Gauges aren't always accurate. iPhone (if you have one) has an app called road trip, and you can track how much fuel you put in and how much it costs. It alway allows you to track accurately how much fuel you use only if you fill it up all the time. Mine was saying I was getting fourteens city driving on the dash computer but in reality on thenphonebwhich is accurate I was getting 12s
22-02-2013, 08:57 AM | #11 | ||
Very easy, just unplug and unscrew, then screw in and plug in.
The cheap eBay ones aren't known for there longevity, you're better of spending a bit more on Bosch or genuine Ford Have a look at this to put your cluster into debug, that'll tell you how much fuel you're using. http://www.fordmods.com/documents.php?d=12
22-02-2013, 09:07 AM | #12 | ||
use cruise control where safe - consistent speed helps, also there are two modes on the auto, my eb had econ mode button, later models had sports mode, so econ on or sports off on can help on roads that are not too hilly.
His: : BA RTV V8 Lightning Strike LILP Gas :FG XR6 Kinetic Eco-LPI, Hers: Titanium Territory, Smoke |
22-02-2013, 09:17 AM | #13 | ||
make sure your air filter is clean, also that engine is is good tune, tyres are at highway pressure, a couple of pounds more than normal..
22-02-2013, 09:22 AM | #14 | ||
FG Falcon fan
You would need to do proper calcs by actually resetting your odo to zero at a fuel tank fill, and I mean fill it up 100%.
Then at next fill you note how many KM you did and how many liters u put in - then do the maths like a champ! |
22-02-2013, 09:32 AM | #15 | ||
Weight: don't carry anything in your car that you don't need. it all adds up and costs you in extra fuel if you're carting a lot of 'junk' around with you.
Style: Smooth acceleration and braking is also important. The more you brake, the more fuel you have to use to get back up to speed. Coasting (zero throttle) from when you see a lower speed limit can also help, instead of driving at speed right up to the signpost (most drivers seem to brake at the last second).
My ride: 2007 Falcon Ute BF XR8 Orange, MTO. |
22-02-2013, 09:34 AM | #16 | ||
Got my EF XR8 manual down to 7L per 100km highway driving
22-02-2013, 10:41 AM | #17 | ||
no, dont use cruise control. That does not help. As it puts the foot down too much to keep you at the same speed up hills. You actaully save lots if you keep your foot at the same point coming up to the hill and let it slow to 90 or whatever. Even speed up before the hill so you can make it over without putting your foot down too much. You would be surprised how it helps!
Still 10 in an auto EF is fine. |
22-02-2013, 11:07 AM | #18 | ||
Flairs - Truckers Delight
10 in an EF is fine
if you want good fuel economy, don't drive a six cylinder car from the 90s
2 users like this post: |
22-02-2013, 02:18 PM | #19 | ||
Anything over 6.0 is not acceptable these days. 10 is OK for a car of the EFs vintage although manual commodores of that age can do high 7s. For an auto 10 is ok.
AUs are much better. They will do 7s in the auto on a smooth highway. The AU is probably the most efficient big car you can get almost for free. |
12 users like this post: |
22-02-2013, 05:45 PM | #20 | ||
64 Deluxe 4 door
Look at what type of oil you run. I picked up 1L/100 by changing to a thinner grade oil (as specified in the manual) in my AU, so I cant see it being any different in an E series
I honestly cant remember what I used to get in my EF Wagon. Even if I did it nearly always had a trailer behind it
XM Deluxe FG XR50 BA Pursuit Ute |
23-02-2013, 03:10 AM | #21 | |||
folden guy
23-02-2013, 09:46 AM | #22 | |||
Just doesnt happen, maybe once in a while,but once awhile doesnt help an average I can get my AU to run good on the highway,but when a car in front sits on 90 clicks in a 100 zone,im not gunna sit back just to save a buck or two on juice An average of 10 ish L/100Ks in an ol EF doenst sound to shabby,but does solely depend on the drivers driving, was it grannie speeds and granny driving ,or was there the odd power up here and there to round up a few slower drivers |
23-02-2013, 11:09 AM | #23 | ||
Back in the early nineties I took my XF Fairmont with EFI from Brisbane to Melbourne and back with wife daughter and 2 grandkids and it did surprise me it was doing 600Ks for sixty litres thats 10 to the 100 using cruise control
going back even further we the Mrs and 2 kids went around the country Melbourne to Darwin and back in an XL 170 wagon and it returned 35 MPG even old Holdens and Valiants and such could get those numbers easily back in the day now Ive got a Territory Ghia AWD and cant get anywhere near 10s in normal driving maybe on a trip but not oround town thanks John |
23-02-2013, 12:15 PM | #24 | ||
I am always confused as to why all of these Falcons that get 6-8l/100km always seem to run out of fuel at between 500 and 600km. Maybe they were not fitted with the factory 68l tank.
3 users like this post: |
23-02-2013, 12:26 PM | #25 | ||
Ha , our AU is lucky to better 10L / 100km on the highway . Mostly 10.5-11.2 .
City use , 16-18L/100km . It's a guzzler ! Just changed 02 sensor , and fitted k&n filter and seems to have dropped to 13-14L city driving already .
1998 AU VCT Ghia - Stock as a rock - Wifes car 1991 Toyota Soarer TT - 11.72 @ 116.7mph 2004 Ford Escape XLT V6 - Family Ride . |
23-02-2013, 12:38 PM | #26 | ||
Falcon RTV - FG G6ET
That's ok for economy, may EL Fairmont used to get high 9's up & down the Warrego.
BAII RTV - with Raptor V S/C. RTV Power FG G6ET 50th Anniversary in Sensation. While the basic Ford Six was code named Barra, the Turbo version clearly deserved its very own moniker – again enter Gordon Barfield.
We asked him if the engine had actually been called “Seagull” and how that came about. “Actually it was just call “Gull”, because I named it that. Because we knew it was going to poo on everything”. |
23-02-2013, 02:13 PM | #27 | ||
64 Deluxe 4 door
My petrol 80 series cruiser gets 20l/100km
stop complaining.....
23-02-2013, 03:05 PM | #28 | ||
folden guy
23-02-2013, 03:11 PM | #29 | ||
folden guy
How hard and expensive was the sensor?
23-02-2013, 04:40 PM | #30 | ||
Bosch sensor from eBay , $54 landed . And about 3 minutes to install
