Old 21-03-2013, 12:40 PM   #1
poppa smurf
poppa smurf's Avatar
Default BA Fairmont wheel centres..do they fall out
I have 16" standard fairmont MkII mag type wheels on my vehicle, I came out of a house I was visiting to find my rear wheel centre had gone
the centre has the Ford in a blue oval, I bought a new one from Ford at $22.00
after refitting the new one I took note of how hard it is to actually get it back i n there which poses the question
did it fall out or was it stolen?.......if it fell out how common is this?.......the things seem to sit pretty tight
thoughts?.....the offsider reckons someone flogged it, I'm not so sure
G'day....I'm Dave, ...everyone calls me Poppa,..05.. B.A. Fairmont mark II...
may your day's be filled with smiles, your life be filled with love, may your children know nothing but happiness and joy, cherish the memory of those who strove before us for they cleared the way, spare a thought for those who serve we owe so much to so many, life and the freedom to enjoy it is a special gift that can be taken away far too soon!
poppa smurf is offline   Reply With Quote Multi-Quote with this Post
Old 21-03-2013, 01:35 PM   #2
b2428
Default Re: BA Fairmont wheel centres..do they fall out
I would honestly say it has probably fallen out. I had one go missing between home and Sydney. If you have ever seen the way the tyre people wack them out and back in when doing balances its no wonder they become loose.
In the garage
2010 Triton GLX-R Dual Cab. So good to be back in a manual.
2008 MA TDCI MONDEO, recently became somebody elses problem haha.
1988 EA Fairmont Monza Red 3.9L CFI - the project beast. On hold for now.
2013 Nissan Pulsar ST-L - The better halfs car
b2428 is offline   Reply With Quote Multi-Quote with this Post
Old 21-03-2013, 01:54 PM   #3
XRGhia
meh.
XRGhia's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Contributions in the technical arena.
......because most of the time they're stuck in quite well, so need a decent push to dislodge and fall out before we can balance a wheel.
Previous - BF XR6T - 325rwkw, 6 Speed Auto, Process West, X-Force and Turbosmart gear
XRGhia is offline   Reply With Quote Multi-Quote with this Post
Old 21-03-2013, 01:59 PM   #4
poppa smurf
I'd agree with that, I couldn't find any scrape marks around the centre hole and without taking the wheel off I doubt anyone could get them out without scratching the surface
Old 21-03-2013, 02:06 PM   #5
b2428
Mine could have been a direct result of the amount of times the monts rims spent getting balanced. Seemed every week or 2 I was getting them done trying to chase a vibration that I eventually gave up on and learnt to live with haha
In the garage
Old 21-03-2013, 02:51 PM   #6
poppa smurf
I had the car start pulling to the left recently, had a wheel alignment done and found the left front tyre simply would not go straight
something to do with the steel belts within the manufacturing process of the tyre misaligned.....new tyre fixed him plus an alignment just to be sure
all good now
Old 21-03-2013, 05:45 PM   #7
svo supporter
Fixing Ford's **** ups
svo supporter's Avatar
The problem is, the plastic clips that hold this centre in place get brittle with age....and they're "wafer thin" and there are only 4 or 6 (can't remember the exact number)....So over time these clips break due to the brittleness of them and they end up falling out.
So common....As common as night turns to day...
A wheel alignment fixes everything, when it comes to front end issues. This includes any little noises.
Please read the manual carefully, as the these manufacturers spent millions of dollars making sure it is perfect.....Now why are there so many problems with my car, when I follow the instructions to the letter?....Answer, majority rules round here
Lock me up and throw away the key because I'm a hoon....I got caught doing 59 in a 60 zone
Old 21-03-2013, 06:34 PM   #8
MattsDisturbed
Bseries
MattsDisturbed's Avatar
Mine fell out once while I had the stock Fairmont wheels on. They just get loose with age, I feel like that's the same across all mag wheels.
His: 2003 BA Fairmont in Arctic White/Mercury Silver
Hers: 1999 AU Forte in Amaretto
Check it out:
http://fordforums.com.au/showthread.php?t=11336211
MattsDisturbed is offline   Reply With Quote Multi-Quote with this Post
Old 21-03-2013, 06:42 PM   #9
Maka
Au Falcon = Mr Reliable
Maka's Avatar
Happened with my au poppa, a little lick of silastic between the cap & mag wheel, wipe off excess completely & let the silastic cure for 20 min then you're good to go, a tyre fitter will have no problem removing the cap if the wheel needs a balance.
cheers, Maka
Old 21-03-2013, 06:46 PM   #10
poppa smurf
cheers, Maka
thanks for that.... sounds like the go.....I reckon I'll look for loose ones and put a squirt in there!
Old 22-03-2013, 11:50 PM   #11
Cobramad
Cobramad's Avatar
The centre caps on my Territory Turbo took it upon themselves to fall out, at various times, without ever being previously removed. Came upon one that had fallen out overnight and when I spoke to Fraud (vehicle was still under warranty) they insisted that I had removed the cap before, therefore damaging the plastic tags and causing them to fail. It was comical to hear their explaination so it was simply easier, as previously suggested, to use a dab of silicone on all the caps to prevent them disappearing
I actually managed to track down a set of AU Ghia centre caps and silicone them in, saving the standard Ford ones for our BF wagon, which has managed to lose a couple over the years.
So, in short, the little buggers just like falling off!
Cobramad is offline   Reply With Quote Multi-Quote with this Post
Old 23-03-2013, 10:00 AM   #12
poppa smurf
yep! I found another one that is a little on the loose side, put some goodligump on him and his mates and hope that stops the fallout.......
I also told them all that their performance was not up to par and to lift their game.....hopefully that will be the end of it
funnily enough I asked the service manager here about the problem and of course got the standard answer which covers everything from rattly callipers to centre bush destruction!
"nah! mate, never heard of it before"......."never had to do 'em!"
Old 30-03-2013, 01:21 AM   #13
mik
mik's Avatar
my au xr6 has a similar caps on the wheels to ba`s , i found if your careful tapping them out and don`t let the tyre guys do it they last a hell of a lot longer.
