Old 01-05-2013, 09:00 PM   #1
fiestakid
Default coolant issues
hey guys i have a few quick questions im new to the ford world and especially the fiesta, ive always owned toyotas
anyway my partner has a 2006 wq fiesta ghia, the other morning her temp gauge shot up past the redline, she thought it was because her heater was on so she turned it off and temp dropped for a few mins but went.back up as she continued to work she.got to work with her gauge over 120° i went n sussed her car out and its out of coolant, but she said she had steam comming.from around her bottom radiator hose.
so.my question is could it be a split hose and its dropped its coolant or are there bigger problems?
i know.driving it at high temp is not ideal but im hoping its a simple solution
cheers for.the.advice in advance
fiestakid is offline   Reply With Quote Multi-Quote with this Post
Old 01-05-2013, 09:27 PM   #2
Russ
Russ's Avatar
Default Re: coolant issues
Easiest way to find out if it's leaking would be to refill the coolant and check for leaks. Hopefully it will only be a split or leaking hose. Depending on how bad the leak is, you may need to start the car first, let the temperature and pressure come up and then check it
Old 01-05-2013, 09:46 PM   #3
fiestakid
yeh its completely empty so fill overflow and turn car on and bring it up to temp? and see if its leaking?
