20-05-2013, 12:02 PM | #1 | ||
Have a guess how much pressure is built up in say for example your crankshaft bearings ,
the pressure that mostly seperates moving parts so they dont rub together and destroy themselves
Fords are cool |
20-05-2013, 12:40 PM | #2 | ||
No idea mate, give the good oil !
20-05-2013, 01:00 PM | #3 | ||
It'd depend on the load, oil viscosity and relative speed but somewhere in the MPa (ksi) range. There's only a minute film of oil at the point of nearest contact though.
20-05-2013, 02:48 PM | #4 | ||
Your bearing clearance and surface finish play a part too
It can be over 6000 PSI at the thin part of the oil wedge , oil pumps and oil pressure have nothing to do with it , they just supply oil to the area needed, the rotation of the part does the rest When you have 6 tonnes of load coming from the rod you need that pressure
Fords are cool Last edited by 123Cat; 20-05-2013 at 03:05 PM. |
