Old 05-08-2013, 08:54 PM   #1
THE D
THE D's Avatar
Default Drag racing.
Hey guys,
Alright this has had no replies in the general section so I thought here might get more action.
I'm doing the rear end in my XD ute and I'm thinking of going ladder bars with coil overs. What sort of spring rating would I need for the rear. It will be used 99% for drag use. I see they are like from 200lbs up to like 400lbs.
THE D is offline   Reply With Quote Multi-Quote with this Post
Old 05-08-2013, 09:02 PM   #2
cs123
cs123's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: Can't think of anyone more deserving. Russ Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For all the technical support behind the scenes. Tech Writer: Recognition for the technical writers of AFF - Issue reason: Technical submission
Default Re: Drag racing.
Maybe you should try the drag racing section
I love Holdens....
cs123 is online now   Reply With Quote Multi-Quote with this Post
Old 05-08-2013, 10:01 PM   #3
ebxr8240
Performance moderator
ebxr8240's Avatar
What they told me years ago.. Start at 120 and work your way up with four link..
I guess 150 Lb ...
Daily driver GTE FG..
Old 06-08-2013, 08:43 AM   #4
blownxe393
Wow the xd Ute is really getting a birthday. Is the old rear end not up to the challenge Jason ?
blownxe393 is offline   Reply With Quote Multi-Quote with this Post
Old 15-08-2013, 10:07 PM   #5
THE D
THE D's Avatar
Hey. Just wanted to tidy up the rear. Started with putting tubs in, then just got excited now I chopped out chassis rails and want fit ladder bars.
Old 16-08-2013, 01:22 PM   #6
prasac
prasac's Avatar
finish the *** end up, then weigh it all and pick a spring from there, no point saying put this, this and this in until you have all the weights after that, you can pick something that will be perfect for the combo, springs are the last things you choose after you have all the specs. you want to try and get a decent shock for the back.
prasac is offline   Reply With Quote Multi-Quote with this Post
Old 16-08-2013, 01:34 PM   #7
ratter
ratter's Avatar
are you trying to keep the car on the road? years ago they would not engineer a ladder bar rear end for the street, not sure of current regs though, a 4 link with bushes rather than heim joints was passable if done correctly
Pit Lane Performance
Old 17-08-2013, 10:34 PM   #8
THE D
THE D's Avatar
It's still registered. But if it got stickered then it would become just a drag car.
Old 20-08-2013, 09:03 PM   #9
THE D
THE D's Avatar
Got a bit more done today on the ute. Need to buy some more steel for cross beams.
Old 01-09-2013, 06:03 PM   #10
daryle
Old drag racer
Not helping you here but back in the day guys with rear ends that worked really well would not tell you what they used. I know this is going to hurt but your best bet is to get a proven performer and ask for help but unless things have changed it will cost you. Basic setups are easy, it is the fine tuning of the rear end that counts.
daryle is offline   Reply With Quote Multi-Quote with this Post
