Old 06-08-2013, 07:19 PM   #1
NCII40
XR6T BA 2002
NCII40's Avatar
Default Caliper Bolts NM SPECS HELP!!
I need to know how tight the caliper bolts are that bolt the whole caliper assembly in one piece with brake pads and all to the bracket at the back and front??
Um in the ford au workshop manual it say caliper retaining bolts 30nm then later on its saying 68 to 92 nm?? WTF
check here in the parts data sections its like 115nm
which one is it??
please help its getting dark haha
NCII40 is offline   Reply With Quote Multi-Quote with this Post
Old 06-08-2013, 07:43 PM   #2
Evgeni
Auto Nerd
Evgeni's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: In recognition of the many hours spent scanning information for the benefit of AFF members.
Default Re: Caliper Bolts NM SPECS HELP!!
As a general rule the thicker the diameter, the higher the torque. I normally go about 30nm for the guide pins and up to 90nm for the anchor plate bolts.
Never had a problem.
Evgeni is offline   Reply With Quote Multi-Quote with this Post
Old 06-08-2013, 08:52 PM   #3
NCII40
XR6T BA 2002
NCII40's Avatar
which are the anchor plate bolts?
they bolt the whole assembly?
cause i just undid 2 bolts and the whole caliper came off the bracket with pads still in and everything
those are the 2 bolts are i can't get a name on or NM spec to match
Old 06-08-2013, 08:59 PM   #4
Gaz
Got Ghia?
Gaz's Avatar
The 13mm ones? has the slide pins in them with rubber boot?
Not overly tight, never really torque them, just by feel. Probably somewhere around the 30-40nm i guess.
2007 BF MKII Ghia V8 - BA GT Exhaust| F6 Intake | Superlows | 19" GT-P's | 30mm Swaybar | - Sold
2002 AU2 XR8 Ute - Manual | Leather | Injected LPG | Pacemakers
Gaz is offline   Reply With Quote Multi-Quote with this Post
Old 06-08-2013, 09:33 PM   #5
Evgeni
Auto Nerd
Evgeni's Avatar
Yes, they are the ones. From the specs it looks like 115nm for the fronts and 92nm max for the rears.
Old 07-08-2013, 12:13 PM   #6
NCII40
XR6T BA 2002
NCII40's Avatar
will go with that evgeni, thanks heaps
if they snap off i know who to PM hahaha
they 15mm bolts x 2 of them
Stupid falcon manual, its so retarded with its wording
I need the factory manual, the ones on ebay look dodge or prob the same as the one i already have
thanks heaps for the help!!!
Old 07-08-2013, 08:53 PM   #7
Bill M
Bill M's Avatar
Evgeni got it right...
AUII XR6 VCT ute
20 years and still going strong!
Bill M is offline   Reply With Quote Multi-Quote with this Post
Old 09-08-2013, 09:44 PM   #8
NCII40
XR6T BA 2002
NCII40's Avatar
done thanks so much
