Old 19-08-2013, 09:17 PM   #1
080
Default Laser now starts for 3 seconds then stops
I have a laser which will start for 3 seconds then stop.
I put a test light onto the negative out of the dizzy.
It lights when you turn on the ignition then sort of blinks very fast when it runs. I would not say it flashes. It looks more like an incredibly fast twinkling. Then everything just stops.
What is going on? Which one is most likely to be?
Modulator
Coil
fuel pump
fuel filter
Thanks for the help.
080 is offline   Reply With Quote Multi-Quote with this Post
Old 20-08-2013, 08:23 PM   #2
080
Default Re: Laser now starts for 3 seconds then stops
Changed the fuel filter which was not done for the 36 000km I have driven the car.
Not sure if it was change in the previous 206 000km.
Started 10 sets of cranks later and ran nicely.
The fuel that came out of the filter that was taken out was filled with what would be described as fairly fine black silt. The fuel was black too. I could still blow air through the filter with my mouth.
Hope this info can be of some use to someone down the track.
It was the fuel filter.
The fuel filter wins!!!!!!!!!
Soooooo,,,,, filters are important right?
Old 21-08-2013, 08:41 AM   #3
YOB POM
YOB POM's Avatar
2011 FG XR6 Turbo
Luxury Pack,Tech Pack,V8 bonnet,bobtail spoiler.
YOB POM is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2013, 05:16 PM   #4
Quinsta
Thumbs up Re: Laser now starts for 3 seconds then stops
Hmmm, might check mine, the car has been sitting for quite a few years now, car runs fine .. but still!! .. good work
Quinsta is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2013, 11:01 PM   #5
080
The only think I could say it did to give any warning was what felt like a very fine tap on the throttle while cruising at 70km. Sort of like a surge. It did this once a day for about 2 weeks before it quit.
Need to do the timing belt soon and the clutch is slipping if I push it.
Will be back for more info then!!
