I just wanted to get some feedback from ST owners on the following to determine if these are common. It seems from overseas threads that quite a few owners are experiencing similar problems. Some have been diagnosed as sensor issues and some have had the wiring harness replaced.
I have taken the car to the dealer and they advised me that they could not replicate these issues and have asked me to keep a log when they occur. These are the issues: 1) Idle increasing to 1100rpm when clutch is engaged? This not happen all the time, therefore to me, it does not seem normal. 2) Idle Hunting: When blipping the throttle, idle drops right down below 500rpm almost stalls and then rises above 1000 rpm and then eventually settles to normal idle. 3) Stalling: When the clutch is engaged as you are about to stop, the car stalls. This is happened about five times all in varying circumstances i.e. when the car is cold and after being driven for an extended period. Any help would be appreciated as I know of one other FF member that is having similar problems. Thanks |
#1 seems to be on purpose. Goes from something like 7-900 and 0.8l/h to 1200 with 1.2l/h fuel.
I figured it was some sort of antistall/launch assistance of some sort. Happens as you clutch in and foot off the brake for first. No problems with 2 or 3. |
I get #1 all the time, the other ST's I've been in have done the same thing too?
I've not had 2 or 3 though. |
Thailand Specials
The new manual Ford Transits also do number 1, in first and reverse so I'm assuming its a Ford anti-stall thing.
Barra Turbo > V8
Yep i get #1 rest havnt had yet.
2011 XR6 Turbo Ute - Manual - Lux Pack - Twin 2.5" Stainless Exhaust - Antz Turboside Intake - CCForged Phatlux wheels - Tuned by LS Tuning and Performance |
Red Rocket...
Yep same. I get #1. Also notice that when sitting still for a while with the clutch pressed in, the revs would normally sit slightly higher (maybe 900ish), then drop (to 750ish) once my foot comes off the clutch (with the shifter in neutral). Happens every time, thus seeming normal to me
The others, havent noticed them either.
2012 Colorado Red Focus ST |
Yeah, another one with the occasional No1
2018 Ford Focus RS |
So the check engine light finally come on.....so I'm thinking great, I'll finally get a resolution to the stalling issue. Dealer advised it was the O2 sensor it was replaced and for most of the journey home all seemed good, but just before I got home, pushed in the clutch whilst I was approaching a stop sign and it stalled. Did it another two times before I got home.
From what I've read, the idle hunting/stalling issue seems to be a common problem with the US ST's and the Ford Motor Co have issued a technical service bulletin (TSB) which relates to wiring splice associated with the MAP sensor. The dealer is investigating this as Ford Aust have not issued a local TSB for this. I've advised the dealer that I'm happy to pay for it. I have booked the car in with the dealer to hopefully rectify the issue under warranty. From what I've read on the US ST forum, once the TSB was performed the issue was resolved. |
The Ford dealer completed the TSB associated with the MAF sensor......cost me $116.00 as Ford Australia do not recognise this as an issue as yet. It was not easy as the dealer wanted to argue that performing the TSB may lead to warranty issues.
As expected, no problems as yet and for me this is a small cost given that the car spent just on three weeks at different stages whilst Ford stuffed around trying to replicate the problem. My advice is do your research and use the overseas forums. Without the knowledge of the overseas TSB, the car would still be with the dealer. Hopefully I can again start to enjoy driving this great little car. |
Glad to hear you got it sorted. it is a real shame when a common problem is recognised OS and not here. I have never had the near stallling thing myself, but did replace the rear motor mount after a month or two, another one recognised OS. It has got me beat how that elastic thing wasnt considered worthy of replacing.
The stalling issues are almost symptomatic of a leaking BOV, but if it is the MAF then I'm sure you don't mind paying $116 to have it fixed.
2013 Ford Focus ST
#12 | |||
Interesting about the EPV... Occasionally the revs in mine drop low to the point where it almost stalls but to date it hasn't stalled on me yet. Something to keep an eye on tho.
Is the sensor you replaced the one on the airbox?
2013 Ford Focus ST
#14 | |||
The O2 sensor the dealer replaced (under warranty) based on what they explained to me is associated with the exhaust system. |
#15 | ||
Barra Turbo > V8
How many kms do you have on your car as it sits?
Mines the same as Aratics, hasnt stalled yet but it gets low in the revs sometimes
#16 | ||
#17 | ||
So two months down since the Overseas TSB was completed and no problems at all with the idle hunting/stalling issue. Anyone that is having a similar problem should push for this to be done. I've written to Ford requesting a refund, but given the issue is not recognised here, we'll see what happens.
#18 | ||
So got a response back from Ford and as expected, they denied my request to refund me the $116.00, claiming that they will not recognise the US TSB. They suggested I request a refund through the dealer.....why would I do that when it is clear that the issue with my car is the same as the OS models, therefore it should be a warranty issue. I've owned many, many Fords over the years and always serviced them through Ford Dealers and I've got to say that this whole issue has been the tipping point for me. The cars I have will be the last Fords for me. I reckon it's cost me about $200.00 in fuel costs alone ferrying the car back and forth to the dealer whilst their useless POS technicians fumble around. I understand that car issues are often difficult to replicate, but in this case I presented them with the fix, but they wanted to argue that it didn't apply in my case......well hello it did and it's fixed. I can safely say these will be my last Ford. I've given Ford the benefit of the doubt on more than one occasion, but not any more.
#19 | ||
No excuse for ford but I think they all try hard not to help if the problem is hard to diagnose or involves admitting to a reoccurring issue.
#20 | ||
Thailand Specials
Everyone worried about modifying their new cars and getting knocked back on warranty.
What warranty? It seems theres many more bad experiences out there with trying to get something fixed under warranty then there are ones where they did a good job, there is always some sort of fight. |
#21 | ||
Its just like the problem with the engine mounts we all know its there and they have a fix for it in the US but Ford AU ignore it
GH Sigma EFI 351, 394whp @6500rpm |
#22 | |||
Twin Turbo
#23 | |||
Twin Turbo
No. 2 kind of normal, mine does it too. No. 3 not normal. Mine is currently on 40,000k. |
#24 | |||
Twin Turbo
#25 | |||
born to be mild
They initially carried out a scan tool test & found no codes evident, they then carried out a data logger test & wire wiggle test ![]() The dealer said this was the 2nd st they've seen with this problem. From what I was told ford are aware of this problem as they advised dealer how to fix |
#26 | |||
I'd like to follow this up with Ford as I had to pay for the repair. Thanks and appreciate the feedback. |
#27 | |||
#28 | |||
#29 | ||
Thanks to ronnas07 and black13 for the feedback......it seems the stalling issue is more common than Ford are willing to admit.
#30 | ||
