Old 28-11-2013, 12:07 AM   #1
Bushbasher
When in doubt, GAS IT!!
Bushbasher's Avatar
Default OBD II reader and Forscan program.
A couple of weeks ago I invested a whopping $9.89, including postage, for one of those chinese OBD2 diagnostic scan tools and then downloaded the latest Forscan program to my laptop. When it arrived I went out to the Sportsman and plugged it in. Within seconds it connected to the car and asked me if it was LTD/Fairlane/Fairmont or Forte/Futura/XR! So it recognised the odd hybrid AU setup immediately and started scanning. It pulled up half a dozen old codes straight away and let me clear them then scanned again automatically and pulled up a current code that told me my VCT solenoid was playing up which I duly changed and now I've picked up about 50-60km to the tank.
That little $10 investment saved me a bucket load of cash chasing my fuel economy problem and the beauty of the Forscan program is that it not only pulls the codes and allows you to clear them but the codes it pulls, it tells you what they are and there's a troubleshooting guide to help you track down the problem, AND IT'S FREE!! What an excellent bit of kit.
It also does real time logging and other stuff but I haven't played with that yet but even without any of that it's an absolute must have in your AU tool kit as far as I'm concerned, I love it.
Just thought I'd share.
Bushbasher
MINE- AUII Forte
Old 28-11-2013, 12:10 AM   #2
rayban76
AU3 5.0L Fairmont Wagon
rayban76's Avatar
I know what you mean, mine actually arrived today but I managed to use AU11LTD's on my ute and did the same as you, scanned it, weed the codes which removed the airbag fault light for me as well ... Such a cheap investment for a great tool to have .
5.0L, 2.1l Kenne Bell, Tickford T3 Heads, Crow valve springs, YellaTerra 1.7 Rockers, Comp Cam, Comp D-Row Timing, 10mm LiveWire Leads, LC-1 & Moats Quarterhorse, B&M TransCooler, Walbro 255lph Fuel Pump, King Superlow Coil Springs, John Bowe Superlow Pro Leaf Springs, K&N 4" Pod & CAI, Pacemakers, 100c Cats, 2.5" Redback, 19" FPV Rims, BF-T Prem Brakes, TS50 Bumper with DTRL's, Custom FG Bulge, BA XR Side Skirts/Rear bar
Ford Performance Club of ACT
[SIGPIC][/SIGPIC]
rayban76 is offline   Reply With Quote Multi-Quote with this Post
Old 28-11-2013, 10:07 AM   #3
dgrover
Default Re: OBD II reader and Forscan program.
Bushbasher
Do you have an ebay link to the diag tool, thanks
dgrover is offline   Reply With Quote Multi-Quote with this Post
Old 28-11-2013, 10:44 AM   #4
auIILTD
5.6L x 2 pilot
auIILTD's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For the effort put into the Australia day cruise to Albury Tech Writer: Recognition for the technical writers of AFF - Issue reason: AU Tech article.
Search ELM327 on Ebay.
I agree Bushy, great bit of Kit. As Rayban76 mentioned above, we managed to clear his airbag light with it, so now he has a ute with working passenger airbag. Win Win.
I originally purchased it for the real time data that it can provide. As I cannot get a Quarterhorse strategy for my I6, I wanted it to show me how it is running by looking at the short and long term fuel trims. It works great on both my cars, I6 and V8.
There is a whole thread on this kit in the AU section somewhere - lots of great advice. Must find and read it again now.
Stu
2002 AU II LTD
5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust.
Quarter Mile: 13.73 @ 105.86mph
Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024
2002 XR8 pursuit 250
Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
auIILTD is offline   Reply With Quote Multi-Quote with this Post
Old 29-11-2013, 09:16 PM   #5
BHDOGS
I did this today myself got the trouble codes ect i tried the key on engine off or key on engine on diagnostics and while it started the test i could tell because the climate control displayed everything it kept saying test failed has anybody got this function to work on forscan yet?
Old 29-11-2013, 11:23 PM   #6
Bushbasher
Bushbasher's Avatar
Mine worked perfectly. I just followed the instructions that came up on the screen in the pop up window. Did you put your foot on the brake and turn the wheel when it asked with the engine running test?
MINE- AUII Forte
Old 30-11-2013, 02:13 PM   #7
BHDOGS
It never gave me the option test started after bout 5 seconds said test can't be completed and stopped itself
Old 30-11-2013, 02:33 PM   #8
BHDOGS
It says the following
error
unable to run test:
PCM- key on engine off (koeo)
Please make sure test conditions are in place.
Old 30-11-2013, 03:44 PM   #9
Bushbasher
Bushbasher's Avatar
Hold on, I'll go out and plug mine in and see what the test conditions are supposed to be.
MINE- AUII Forte
Old 30-11-2013, 03:54 PM   #10
Bushbasher
Bushbasher's Avatar
Ok,
Vehicle must be stationary and in Park or Neutral
Hand brake must be on
If your car is manual you may need to depress the clutch during the test
Do not activate vehicle switches during the test
... that's what the pop up window says.
MINE- AUII Forte
Old 30-11-2013, 04:35 PM   #11
BHDOGS
Hmmm I'll try handbrake on this time the rest I'm already doing Cheers bush basher
Old 30-11-2013, 06:21 PM   #12
BHDOGS
alright i did the test and it found these errrors
code:po116-suspect sensor
module: powertrain control module
not sure what that means
and error PO171
system to lean bank 1
then gives 5 possible causes for that error so seems to work pretty well
Old 30-11-2013, 06:30 PM   #13
Bushbasher
Bushbasher's Avatar
clear the codes and do the test again, They may be old codes.
MINE- AUII Forte
Old 30-11-2013, 06:34 PM   #14
supershifty
Missing a sock...
supershifty's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Dave has been a long time active member on the forums and in particular has been a busy volunteer whenever there are cruises and toys runs etc held in South East Qld. He actively gives up his time and ensures that the events are provided for, be it commun
Nice to see someone having a win bushbasher - thumbs up champ!
auIILTD - I think you're talking about these threads: http://www.fordforums.com.au/showthread.php?t=11373845 + http://www.fordforums.com.au/showthread.php?t=11326889
Cheers!
Real friends + great times = sheer bliss!
Considering becoming an organ donor? Click here
QLD Events, Cruises and Get Togethers: Click here
Gain success instantly - lower your standards.
It's not government funded - it's taxpayer funded.
supershifty is offline   Reply With Quote Multi-Quote with this Post
Old 02-12-2013, 09:02 PM   #15
bartsau
bartsau's Avatar
Well I think it is time I purchased a cable (only $8 or something.... http://www.ebay.com.au/itm/ELM327-V1...83b046c&_uhb=1
This may help me figure out what the hell my car has been doing of late...
AU III Forte wagon - V8, 5spd man, lowered, 18" Honeycombs, Stock diff rebuilt with TruTrac LSD, Leather Ghia interior/dash, custom twin 2.5" into single 3" exhaust.
Wagon Build
AU I Forte Sedan - No longer
Toy Car Build
bartsau is offline   Reply With Quote Multi-Quote with this Post
Old 02-12-2013, 09:55 PM   #16
Bushbasher
Bushbasher's Avatar
Mine is a bluetooth one and it works just fine. Cost me about $9.50. I didn't want the cable getting in the way while doing real time logging.
MINE- AUII Forte
Old 03-12-2013, 12:42 AM   #17
mif73
CNC fixer guy
mif73's Avatar
Hi basher.
I got a usb version from an aus seller for 18 bucks and it arrived 3 days later.
Running forscan and it is pretty cool.
I ran my au with live data on the scope screen and i like it a lot.
It also found a dtc code on the wifes fg hvac unit : B2010 servo motor panel door circuit failure.
After i saw the code i noticed the fan would not blow onto the floor position, so gotta mention that to the dealer as its under extended warranty.
You cant complain with what you get for so little.
If you like diy on your car then get one fellas.
Weekend Toy: S1 AU Fairlane V8 with LTD bits, Tickford 17" wheels, front and rear chin spoilers, series 2 front brake conversion with Super pro bushes, Pacemaker headers, rear muffler removed, Kings/Pedders lowered suspension, Koni adj rears, painted headlight bezels, HR 2300kg hitch, 2 stage shift kit, trans cooler, reverse cam and media player.
Wife unit's : 2010 update FG XR6, reverse cam, HR 2300kg Hitch, German Maestro speakers, parcel shelf sub, trimmed mudflaps, batman stickers.
mif73 is offline   Reply With Quote Multi-Quote with this Post
Old 11-12-2013, 10:14 PM   #18
bartsau
bartsau's Avatar
Ok so I have received the cable in the mail. I have also installed the Forscan program on my laptop and have now tried to use it. But with no luck just keeps coming up saying that "No ELM found. Please check connection and try again"...
Any ideas anyone?
Or is this the issue my car is having? I have tried 4 different scan tools so far and all can see the PCM without any issues but cannot see any other module? What could be the cause of this...any ideas would be appreciated as otherwise it is going to be a matter of pulling the entire dashfloor loom out and checking each and every connection/fuse/relay/module until I find the fault.
Wagon Build
Toy Car Build
Old 11-12-2013, 11:14 PM   #19
Evgeni
Auto Nerd
Evgeni's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: In recognition of the many hours spent scanning information for the benefit of AFF members.
I had that problem when I first ran forscan. Try a different usb port if you have one.
For the first time, I had to run the engine for the program to talk to the computer. After that it would hook up whilst the ignition was on reds.
Evgeni is offline   Reply With Quote Multi-Quote with this Post
Old 12-12-2013, 12:09 AM   #20
GASXD
For those having issues, try this link http://www.totalcardiagnostics.com/s...-obd2-software
Solved the problem I had, and might help others.
GASXD is offline   Reply With Quote Multi-Quote with this Post
Old 12-12-2013, 01:13 AM   #21
mif73
CNC fixer guy
mif73's Avatar
Yep do that.
You have to install the correct driver for your version of windows first.
Old 12-12-2013, 10:06 AM   #22
dgrover
Can anyone post a link on ebay for any OBD unit that will work on an 1999 AU1,
having difficulty finding one that works with Series 1, Cable or Blue Tooth
Thank's
Old 12-12-2013, 10:12 AM   #23
auIILTD
5.6L x 2 pilot
auIILTD's Avatar
Thank's
In post 4 dgrover.
Various options here. Cabled versions are a little cheaper.
http://www.ebay.com.au/sch/i.html?_t...at=0&_from=R40
Stu
2002 AU II LTD
Old 12-12-2013, 10:29 AM   #24
Revolver
Big Member
Revolver's Avatar
Is there a version for E-Series cars?
I missed out on a scanner that was in the for sale section. Lack of $$$ :(
Sold on ebay for 65 more than what it was advertised on here for. Double :(
The Scarlet Fairlane: 94 5.Slow Litre NC II Fairlane 488800kms & Climbing
Rollin' on genuine ELGT wheels.
K&N Filter
/////Alpine Sound.
EBGT Momo Woodgrain Steering Wheel
The Scarlet Fairlane Build Thread
Project "White Knight"
93 ED XR6
ROH Alloys
Momo wheel
Cruise
Sunroof
Premo Sound
Manual
HO Goodies
PWK Build Thread
1990 Yamaha FZR 250: 59000ks & climbing. New fairing, old tank, my angry mosquito in a coffee tin! 14.977 1/4mile.
Revolver is offline   Reply With Quote Multi-Quote with this Post
Old 12-12-2013, 09:16 PM   #25
FGII-XR6
FGII-XR6's Avatar
No there isn't a great deal you can do with the E series as they are OBD1 the AU is a ford version of OBD2 and although most scanners wont work the Forscan software has the ability to work with what's called "standard corporate protocol"
[SIGPIC][/SIGPIC]
Rides:
Old 12-12-2013, 10:38 PM   #26
hagarone
hagarone's Avatar
Stu
Hi Stu, what goes on with airbag light? When we put a passenger airbag in we did not have that problem. All good, first go!
hagarone is offline   Reply With Quote Multi-Quote with this Post
Old 12-12-2013, 11:05 PM   #27
auIILTD
5.6L x 2 pilot
auIILTD's Avatar
Gidday Hagar.
Not 100% of Rays sequence for changing BEM etc, but I am sure he orginally had the dummy plug in the passenger air bag and the put the passenger air bag in. Some how he had the air bag light flashing on the dash thereafter. When we cleared the code and resolved the flashing airbag light, Ray plugged the dummy plug back on again, we cleared the DTCs and then re-instated the passenger airbag - no more flashing airbag light!
Obviously somehow in the process, a trouble code developed - once cleared, all was good.
Stu
2002 AU II LTD
Old 14-12-2013, 11:49 PM   #28
Bill M
Bill M's Avatar
Nice work guys! watching this thread with interest.
AUII XR6 VCT ute
20 years and still going strong!
Bill M is offline   Reply With Quote Multi-Quote with this Post
Old 22-12-2013, 11:59 AM   #29
Bill M
Bill M's Avatar
Originally Posted by mif73 View Post
Yep do that.
Hello guys,
if I read this correctly I can use ELM327 on my laptop Windows 7 by downloading the correct driver for Win 7 even though the ELM 327 auction listing says no windows 7?
I am a windows newbie coming from a Mac household
AUII XR6 VCT ute
Old 22-12-2013, 12:12 PM   #30
auIILTD
5.6L x 2 pilot
auIILTD's Avatar
Yes, I am using windows7 Basic on my netbook.
2002 AU II LTD
