66 Mustang
My AU 2 XR8 (Auto - 3:45 LSD) has 235/45 17 tyres on it but the speedo is 4-5% slow ie. sit the speedo on 104-105, car is doing 100.
As most 75% of my driving is on the highway in 100 zones, it is quite frustrating. I was thinking I could use a speedo corrector, ie. like the jaycar one, or change the speedo gear to one for a 3:23 ratio auto. But... Running 235/50 or 245/45 tyres could fix the problem and give a slightly better ride. I had 235/50 tyres on the other AU ute and the speedo was spot on, I have 245/45 on the back of that one now and the car does 98-99 when reading 100 on speedo, which I'm cool with... What are your thoughts? |
Next upgraded Mk1 Leopard
I know everyone like a 'low look' but everyday drive I'd take the better ride path.
UK
CNC fixer guy
I had 235 45 r17 all round on 3.23:1 fairlane, the speedo was like yours (a few km out).
I ended up fitting 255 45 r17 (not such a common size) to fill the rear guards a bit (max legal width tyre for an 8 inch wide 17 inch diam rim). The speedo is now spot on with the gps. 245/45 would be good, go for it.
Weekend Toy: S1 AU Fairlane V8 with LTD bits, Tickford 17" wheels, front and rear chin spoilers, series 2 front brake conversion with Super pro bushes, Pacemaker headers, rear muffler removed, Kings/Pedders lowered suspension, Koni adj rears, painted headlight bezels, HR 2300kg hitch, 2 stage shift kit, trans cooler, reverse cam and media player. Wife unit's : 2010 update FG XR6, reverse cam, HR 2300kg Hitch, German Maestro speakers, parcel shelf sub, trimmed mudflaps, batman stickers. |
245/45 is what is standard for commodores, I think, so would be cheaper than a 235/50, and would give the same overall diameter.
66 Mustang
Fg started with 235/50, changed to 245/45 in 2010/2011.
5.6L x 2 pilot
![]() ![]() Join Date: Dec 2009
104 at 100 I have found to be pretty standard. So to bring the speedo down, you will need a larger rolling diameter.
This site might help. http://tire-size-conversion.com/tyre-size-calculator/ Cheers Stu
2002 AU II LTD 5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust. Quarter Mile: 13.73 @ 105.86mph Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024 ![]() 2002 XR8 pursuit 250 Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
#8 | |||
![]() UK
CNC fixer guy
If you cant be bothered with metric to imperial conversion then you can try this one too:
http://www.willtheyfit.com It also has a handy visual reference in regards to wheel widths and offsets. Cheers.
