Old 03-03-2014, 04:02 PM   #1
drew1491
290 BF XR8
drew1491's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Excellent write up on coli-over installation.
Default Car cover for long term storage
Hi all,
I'm looking at getting a decent car cover, my car is parked in a garage full time and will be for the foreseeable future, i have heard of many car covers that will harm paint if left on for long periods, can anyone recommend a cover that will be suitable for long term use? I like the covercraft form fitting covers but $600 is a bit much.
The main thing I want to protect it from is dust as well as possible scratches from people that might brush past it as they walk past the car.
Cheers in advance
EL Series 2 XR8
In the build
Boss 290, ZF6, BF K Frame
BF XR8 in Bionic
Back burner for now
NL Pajero
Camping/adventuring vehicle
Faded paint and smells funky
Honda CBR 300R
Daily
drew1491 is offline   Reply With Quote Multi-Quote with this Post
Old 03-03-2014, 05:53 PM   #2
XRtowcar
Mustang GT mmmmmm......
XRtowcar's Avatar
Default Re: Car cover for long term storage
Don't use plastic like my mates dad did on his 71 corvette.
Got wet under the carport and enough water got into the blanket he had underneath the plastic and blistered the paint.
I have become a Mustanger.
XRtowcar is offline   Reply With Quote Multi-Quote with this Post
Old 03-03-2014, 06:21 PM   #3
drew1491
290 BF XR8
drew1491's Avatar
I definitely wont be using plastic, was looking at something like this;
http://www.carcareproducts.com.au/pr...er/x_large_car
Just wanted to see if anyone has any feedback first
EL Series 2 XR8
In the build
BF XR8 in Bionic
Back burner for now
NL Pajero
Honda CBR 300R
Daily
Old 03-03-2014, 07:09 PM   #4
Johnnyboy
I've been using a Kenco Tyvek (made by Dupont) cover on an XB that's been sitting for over 10 years without any problem.
Because the cover 'breathes', when it was outside, I found I had to put a large moisture trap inside the car to avoid condensation like this:
http://www.bunnings.com.au/550g-slim...-unit_p4470048
Otherwise, while in the shed, it's perfect.
Johnnyboy is offline   Reply With Quote Multi-Quote with this Post
Old 03-03-2014, 07:24 PM   #5
pottery beige
summer bed sheets, light, cheap, no scratches ftw
Old 03-03-2014, 07:36 PM   #6
Yellow_Festiva
Where to next??
Yellow_Festiva's Avatar
Was thinking the same thing....
If your priority is to just keep dust off it then I would just use some flannel sheets.
Oh, if you are going to leave your car sitting for a long time there are a few other things that are advisable to do.
Really depends on how long I guess.
___________________________
Old 03-03-2014, 08:34 PM   #7
drew1491
290 BF XR8
drew1491's Avatar
It's been sitting go for about 5 months, it's been moved a bit but doesn't run so it I can't take it for a drive, I've put a small about of oil in each cylinder and have been cranking it by hand periodically, anything else worth doing?
EL Series 2 XR8
In the build
BF XR8 in Bionic
Back burner for now
NL Pajero
Honda CBR 300R
Daily
Old 03-03-2014, 08:40 PM   #8
2011G6E
2011G6E's Avatar
Cotton sheets, as long as the storage area is absolutely dry.
As for a car cover, it's a long shot, but if you're serious about protection for the long haul, look at some of the British classic car magazines. They have car covers that are specifically designed to repel moisture and not harm the paint finish...probably understandable from a country that is damp as a mermaids bum and where some people lay up their cars for half the year to prevent using it in wet or cold (salted roads) conditions.
2011G6E is offline   Reply With Quote Multi-Quote with this Post
Old 03-03-2014, 09:02 PM   #9
drew1491
290 BF XR8
drew1491's Avatar
Storage area is usually dry, however when it rains the garage door gets wet and drips when it opens, sheets night not be the best idea on second thought
EL Series 2 XR8
In the build
BF XR8 in Bionic
Back burner for now
NL Pajero
Honda CBR 300R
Daily
Old 03-03-2014, 10:45 PM   #10
pottery beige
dont open the door when its been raining
Old 03-03-2014, 10:54 PM   #11
pottery beige
my bomb and its bedding, come to think of it, its a big king size doona cover i filleted
and a light sheet thrown over the bonnet
ten year shed dwelling veteran
Old 04-03-2014, 12:31 AM   #12
Xauterus
If you dont want to scratch it then make sure car and cover are very clean before you put the cover on. Its the dust and dirt caught between that scratches things.
Xauterus is offline   Reply With Quote Multi-Quote with this Post
Old 06-03-2014, 04:25 PM   #13
snowcone
Supercheap sells a "Show Car Cover" for around $95
This can be left on for long periods and won't scratch the car.
Not to be used outdoors though as it is not waterproof.
I just bought one for my Customline and it was on sale for $70
snowcone is offline   Reply With Quote Multi-Quote with this Post
Old 06-03-2014, 04:36 PM   #14
5.8
5.8's Avatar
I have used autotechnica ones for about 20 years. They are just under $200, fully waterproof and felt lined. My cars are in a garage but I still use the waterproof ones. Very good quality covers IMO.
5.8 is offline   Reply With Quote Multi-Quote with this Post
Old 06-03-2014, 10:47 PM   #15
XB GS 351 Coupe
Chief car cover(http://www.carcovers.com.au) to protect the paint then a cheap dust cover to stop the dust getting to the cloth cover causing abrasion (http://www.supercheapauto.com.au/onl...d=156741#Cross), bought the second cover after a big dust storm.
Been storing my cars like that for years with no issues.
Same for my FPV GT been stored like that for years since new:
The Daily Driver : '98 EL Falcon, 5 Speed , 3.45 lsd
The Week End Bruiser : FPV BF GT 40th Anniversary, 6 Speed Manual, 6/4 Brembo and lots of Herrod goodies
Project 1 : '75 XB GS 351 Ute, Toploader, 9" with 3.5's
Project 2 : '74 XB GS Big Block Coupe, Toploader, 9" with 4.11's
In Storage : '74 XB GS 351 Fairmont Sedan
XB Falcon Owners Group
Mike's Man Cave
XB GS 351 Coupe is offline   Reply With Quote Multi-Quote with this Post
Old 07-03-2014, 10:23 AM   #16
MercurySilver
Isn't it obvious?
MercurySilver's Avatar
ive gotta do something as well for the xb
shes no show car thats for sure and ive got her in an old shed with a blanket over it some bed sheets followed by a tarp and a massive piece of that green shade cloth over the top of the lot
prob not ideal
ive cracked the window a smidge on the drivers door too, again not sure if this is ideal
while the shed doesnt leak it does get a possum in it, again def not ideal
ive blocked up every hole i can see and still there is possum poo on the blanket on the hood
last time i pulleda car out the shed (a vh) the possum had decided to make a nice bed full of leaves beside the battery box
i prob should start it too hasnt been turned over in over two months (battery is out tho)
think i might look at a cheapo car cover
08 Strike G6E T.
10 Ergo G6E
Sept 75 XB Falcon in mushroom beige, 3 on the tree 200cid for sale, offers in the teens
MercurySilver is offline   Reply With Quote Multi-Quote with this Post
Old 07-03-2014, 11:56 AM   #17
pottery beige
I spent $200+ on one of those flash *** ones..
Found it heavy and no likey dragging it across a new car / new paint
It lives on PB now
Old 07-03-2014, 09:59 PM   #18
Johnnyboy
As mentioned, if you don't want a heavy cover or one that will get damp and cause rust, check out the dupont tyvek material covers. Amazing stuff. It's like a cross between paper and cotton. Very light, breathes but is water proof. In fact, it's also used for envelopes and protective clothing.
My XB is as clean as the day I put it on 10 years ago.
Old 08-03-2014, 12:01 AM   #19
ebxr8240
Performance moderator
ebxr8240's Avatar
I stored my old WRX in NZ for 21/2 years. Left windows 20mm open , doors on first latch , on jack stands with paper type cover in garage.. Added 1/2 cup 2 stroke oil to 1/4 of tank Then drove around block, disconnected battery . My bro charged the battery every month or two.. When I imported it , it started straight up . Was concerned with using the plastic type covers about condensation being held under the cover..
Daily driver GTE FG..
