Old 06-03-2014, 12:03 PM   #1
Bushbasher
When in doubt, GAS IT!!
Bushbasher's Avatar
Default Urgent help required. ASAP
I've put this up in the AU section but there's more traffic here during the day and it'll be too late by tonight so here's the story.
I'm changing the tie rod and drivers side front hub on an AU and the car is in pieces as we speak so I need an answer asap if anyone can help. I need to replace the drivers side tie rod as the rose joint is rattly but the tie rod doesn't seem to want to budge and undo from the rack. I can feel that there is a small cut out on the bottom of the rack shaft where the tie rod screws in and was wondering if it's a key way or something as I can't get my fat head under there with the car just jacked up and supported. Is there a key way under there with a key locking the tie rod in place or is it just that the tie rod is stupidly tight and I just need more leverage? I don't want to go leaning on it if it is locked in place as any number of nasty things can potentially happen if I put enough muscle into it, so any guidance would be much appreciated.
Bushbasher
MINE- AUII Forte
Old 06-03-2014, 12:36 PM   #2
johnydep
johnydep's Avatar
Default Re: Urgent help required. ASAP
Sorry, but that's scary - mucking around with steering + no qualification + lack of knowledge.
Take it to a specialist.
The true danger only occurs when you take a potentially dangerous piece of machinery
and place it in the hands of the most unpredictable species on the planet.
Human behaviour, as history has catalogued, cannot account for what any persons actions may be,
especially concerning their love of the motor vehicle.
http://www.fireservicecollege.ac.uk
johnydep is offline   Reply With Quote Multi-Quote with this Post
Old 06-03-2014, 12:45 PM   #3
Bushbasher
Bushbasher's Avatar
Gee, thanks for your support and bountiful knowledge. You must have missed the part where I said I already have it in bits. It's a tie rod, not rocket science and there's no indication on the new tie rod of any key way or key but it is an aftermarket unit so I just want to be sure before I proceed.
As soon as I change the rod I can put it back together and it's booked in for a wheel alignment first thing in the morning just up the road.
MINE- AUII Forte
Old 06-03-2014, 01:30 PM   #4
Trump
bitch lasagne
Trump's Avatar
Soak the tie rod end in Penetrene or some other thread release fluid.
Scaled Business Solutions
For Your Small Business IT Needs
Trump is offline   Reply With Quote Multi-Quote with this Post
Old 06-03-2014, 01:31 PM   #5
JC
JC's Avatar
OK, couldn't find my AU book, but I have an ED manual and a BF one. Both say you remove the rubber boot first (so I assume you've done that anyway). The BF one says the rack end should come off using vice grips to lever it. Th ED one says to turn the steering all the way left so that the RH rack end is exposed, and then you can undo the rack end from that point, holding the rack end with vice grips to stop it going back in. Do the opposite for LH side. Maybe a combination of these will work on an AU??? There is mention of a tapered shaft, so it will be tight.
Good luck with it.
Ford Performance Club ACT
Old 06-03-2014, 01:36 PM   #6
Bushbasher
Bushbasher's Avatar
Thanks JC, that's all I need, no key way so it's just a matter of muscle. Back to it, cheers.
Bushbasher
MINE- AUII Forte
Old 06-03-2014, 02:00 PM   #7
DJR-351
I am Groot
DJR-351's Avatar
If the above does not work my "Bodge-it & Scarper" manual recommends a bigger hammer......
Jokes.....good luck with it....
McLaren F1
Dick Johnson Racing
"Those were the days when the cars were cars, they weren't built out of an Ikea pack like they are now and clothed in plastic; they were real cars." John Bowe
DJR-351 is online now   Reply With Quote Multi-Quote with this Post
Old 06-03-2014, 02:21 PM   #8
Grunter
Not of the Sooty variety!
Grunter's Avatar
"To be afraid is to be alive - to act against that fear is to be a person of courage."
Current
The Toy: 2002 AUIII TS50
The Daily and Tow Vehicle: 2016 VW Amarok
Grunter is offline   Reply With Quote Multi-Quote with this Post
Old 06-03-2014, 02:42 PM   #9
Bushbasher
Bushbasher's Avatar
Ok, done, it's all good. I just had to drop the sway bar to get enough range of motion to screw it off with a spanner.
MINE- AUII Forte
Old 06-03-2014, 11:49 PM   #10
Bushbasher
Bushbasher's Avatar
Well, the job is done and the car back together and tracking better than ever. Thanks JC, for telling what I needed to know, it helped alot.
Upon reassembly, and using my best guestimate as to alignment, the car was all but spot on. It had a slight pull to the left but no worse than it's been for the last 4 years since the last wheel alignment and after a quick tweak of a 1/4 turn of the tie rod the car now tracks perfectly straight at all speeds and is as good as it's ever been. I'll still get it double checked on a wheel alignment rig but I'm pretty confident it won't need much adjusting if at all.
So the scary "mucking around with steering + no qualification + lack of knowledge" wasn't such an obstacle after all. Maybe it's dumb luck or maybe, just maybe, it's a basic mechanical aptitude and understanding plus a bit of common sense that got me there, but I'll let others be the judge.
Bushbasher
MINE- AUII Forte
7 users like this post:
Old 07-03-2014, 08:20 AM   #11
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
I still have to do this, want to drive up to Sydney and done mine?
UK
Old 07-03-2014, 10:02 AM   #12
Bushbasher
Bushbasher's Avatar
, no can do UK, I'm the car pool school taxi, but you're more than welcome to pop in here any time you like and we'll get to it. I even have a spare tie rod we can use as I bought a pair and only used 1.
Bushbasher
MINE- AUII Forte
Old 09-03-2014, 11:06 AM   #13
Bushbasher
Bushbasher's Avatar
Well, I took the car in to Port Lincoln get the wheel alignment checked yesterday and ................. it was spot on!! The caster was within .02 of perfect and well within spec and the camber was still exactly the same as it was the last time the car had a wheel alignment over 100,000km ago, which tells me the front end bushes are still fine as well so I'm a very happy camper. While I was there we got the car up in the air and double checked that the tie rod was tight to the rack as I was concerned I didn't get enough leverage on it when I fitted it on the ground, and while at it we chucked in some new sway bar shackle bushes as well, so now it's as good as new.
Sorry everyone, I know that all sounds a like a bit of a self indulgent brag but I just couldn't help myself as it was my first foray into front end components and geometry, and that was quite daunting before hand but proved itself to be not as hard as I expected.
Bushbasher
MINE- AUII Forte
