Old 17-03-2014, 01:20 PM   #1
Petrosg85
Default Install of cruise control
After receiving a fair number of speed fines, I decided that it would be wiser to install a cruise control if possible. I want to maintain automatically the indicated speed. Does anybody have a clue where can i get information and cost about this?
Petrosg85 is offline   Reply With Quote Multi-Quote with this Post
Old 17-03-2014, 03:42 PM   #2
Pursya
Default Re: Install of cruise control
Aftermarket cruise controls used to be available.
They relied on magnets wired to the drive shaft with a sensor that picked up the revolutions.
These days most cars will have the electrical wiring already in the vehicle loom(s). So you would be best to look to Ford or wrecking Fiesta to pick up the required bits and pieces. Including a new steering wheel of course.
Just found this and it doesn't look good.
http://forums.whirlpool.net.au/archive/2049295
Talked to the dealership this morning – apparently they cant install CC on the base fiesta model
Pursya is offline   Reply With Quote Multi-Quote with this Post
Old 17-03-2014, 04:05 PM   #3
Petrosg85
That is bad indeed. So do i have to replace te whole steering wheel? Cannot I install one more cntroller behind the existing wheel?
Old 17-03-2014, 08:46 PM   #4
Pursya
Well the wiring is in the wheel. I'm assuming here your car is a late model Fiesta.
You could bang in an aftermarket generic unit but you would have to wire it complete.
Check ebay for generic units.
Old 17-03-2014, 08:56 PM   #5
foxtrot3
foxtrot3's Avatar
Hi. Get in touch with The Command Auto Group ( tcag.com.au ) and find out if they have one and who can fit it in your area. Cheers MD
HI
I'M MICHAEL
foxtrot3 is offline   Reply With Quote Multi-Quote with this Post
Old 17-03-2014, 09:17 PM   #6
Yellow_Festiva
Where to next??
Yellow_Festiva's Avatar
Got a quote for aftermarket CC for our new mirage and the circa $900 cost was a little too much.
___________________________
Old 17-03-2014, 09:23 PM   #7
fiestaz
fiestaz's Avatar
Foxtrot3 Command is a great system. Have one in my work Iload. Supplied & installed came to around $900. it does a great job, but in my opinion, a car with factory cruise control is better, as it has a cancel button!
But i would recommend the command system.
2016 Mazda 3 SP25 GT
2019 Hyundai i30 Active.
fiestaz is online now   Reply With Quote Multi-Quote with this Post
Old 17-03-2014, 09:46 PM   #8
foxtrot3
foxtrot3's Avatar
Hi. Try hitting the off button, If you dont turn off the ignition it still remembers the last speed so if you turn it on again and hit resume it will go to your last set speed. Cheers MD
HI
I'M MICHAEL
Old 18-03-2014, 04:27 PM   #9
fiestaz
fiestaz's Avatar
Yeh, we have done that, doesnt do it. System is about a year old.
Old 19-03-2014, 05:06 PM   #10
Petrosg85
I was informed today for two guys that take care of the installation of the cruise control on my car and they are in my area (sydenham 3037). tony and tagg. Their price was 750$ and 800$. The duration of the setup is 1-1,5 hour. What do you think?does it worth it? May i have any issues?
My car is a Fiesta 2011 automatic (not wetec)
Old 19-03-2014, 07:30 PM   #11
fiestaz
fiestaz's Avatar
look at reviews on the brands of system they use. Command is the best one ive heard of.
Old 19-03-2014, 08:38 PM   #12
Yellow_Festiva
Where to next??
Look at the switch gear they use, and ask exactly where it will be mounted.
If your Fiesta came out with CC as an option the installer should be able to source the factory hardware (or one that's very close) and mount it in the factory location.
Old 20-03-2014, 08:47 PM   #13
Pursya
Factory location is the steering wheel.
So you would need to replace that as a minimum.
Old 22-03-2014, 10:24 PM   #14
80rs
buy a fiesta steering wheel with cruise buttons and swap it for you current wheel then go to the dealer and get them to activate cruise control. should cost only a few hundred.
Heres the link http://fiestawiki.net/tiki/tiki-inde...Cruise+Control
80rs is offline   Reply With Quote Multi-Quote with this Post
Old 22-03-2014, 11:11 PM   #15
Yellow_Festiva
Where to next??
Depends, with some cars the location is just blanked off with plastic like the old i30.
Then you have the old Focus, where I think the CC was attached to the underside of the inner part of the wheel.
I googled 2011 Fiesta wheel and got these:
With:
Without:
Buy the switch:
http://www.ebay.com.au/itm/NEW-OEM-R...item53fb84a572
And you just need to arrange the new wheel trim, which you can probably get online as well, or from a wrecker.
Old 23-03-2014, 11:21 AM   #16
Pursya
At $47 for shipping it might be worth using that part number and giving the local dealers a call.
Old 23-03-2014, 01:24 PM   #17
Yellow_Festiva
Where to next??
You will probably find that Ford will distance themselves from installing anything bought online.
I had a warranty claim for the chrome trim on my Focus steering wheel. I was told that they need to replace the WHOLE WHEEL at a cost if $1200.
I told them the trim looks like it's just glued on, and sure enough, you can buy them online for around $20. When I told the dealer about this they just told me it isn't how the part comes and that a new wheel was needed.
Why all the arguments?? It was 1 month out of warranty and they wanted to slug me with the cost of the wheel...
Old 23-03-2014, 09:19 PM   #18
Pursya
I'm sure the actual switch would be available as a separate item as it is a part that can fail, that's why it has a part number. And that's why I think a call to Ford Oz wouldn't hurt as the part cost and the shipping might be much the same as the local supply.
The trim may be harder to source as it's a Fiesta. I would expect Ford to do exactly as you said they did for the Focus.
Old 23-03-2014, 11:14 PM   #19
80rs
i can sell you the steering wheel with switches for $200
