Old 07-06-2014, 05:25 PM   #1
King Dribble
King Dribble's Avatar
Default Cubic inches
Just curious, at what level (in cubic inches) is the general cut off number between a small block and a big block??? Just wondering.
1000hp Plazmaman FMIC kit. 660cc Blueprinted injectors. Modified turbo housing and actuator. Bluepower CAI. 4" X-force turbo back exhaust. Atomic valve springs and Herrod Motorsport 400 L/Hr in tank pump. Turbosmart dual port BOV. X-Cal 3 and custom tuned. Pedders sportsrider suspension. Lets call it 399.3RWKW. Extra trans cooler for protection. (I don't like milk)
King Dribble is offline   Reply With Quote Multi-Quote with this Post
Old 07-06-2014, 06:07 PM   #2
Xauterus
Default Re: Cubic inches
It is more to do with the block model rather than its capacity. A windsor can be 289, 302, 351 but can be takem to over 425cu but they are small blocks. FE were considered big blocks from 352 to over 400cu. The 385 series are the 460s and smaller are big blocks.
Probably all began with the physical size of the blocks when originally produced.
Xauterus is offline   Reply With Quote Multi-Quote with this Post
Old 07-06-2014, 06:09 PM   #3
MrEL
Sick Puppy
MrEL's Avatar
Its not hard and fast.
A 396 Chev is a big block but a 400 Chev is a small block.
MrEL is offline   Reply With Quote Multi-Quote with this Post
Old 07-06-2014, 07:41 PM   #4
smciner1
Detroit Locker Equiped TM
smciner1's Avatar
The defining point is usually the Bore Spacing.
Apollo Blue 1974 XB Falcon GT, 557 HP
Blue Pearl 2004 BA FPV GT, 290 kW
Originally Posted by MRJUCY
Simple give the car a rev & have a listen a Windsor makes a sort of wheezy drone similar to an angry Hugh Grant when a Clevo will sound like Satan has woke up with a hangover & realized he is out of coffee & cigarettes
Falcon GT Club of Geelong.
http://www.facebook.com/FalconGTClubGeelong
smciner1 is offline   Reply With Quote Multi-Quote with this Post
Old 07-06-2014, 08:08 PM   #5
Crazy Dazz
Well, it kinda IS a hard rule. The BLOCK is the block, its one or the other.
The Windsor, Cleveland, and Modular (inc Coyote) are considered small blocks. The MEL and 385 were big blocks.
In answer to the OP's question, I suppose the changeover is somewhere around 400.
Some small blocks, such as the Chev and Clevo can go to around 400, usually with raised decks to accommodate a longer stroke. Big blocks typically start in the high 300's. A better way might be to look at the bore. Small blocks top out at 4 inches, and that's about where big blocks START.
Old 07-06-2014, 08:55 PM   #6
FPV GTHO
Technical Contributor: For members who share their technical expertise. - Issue reason: Sharing his knowledge of performance exhaust setups for the NA 6 cyc Barra Falcon from BA to FG.
Generally the Windsor and Cleveland/335 family engines are small block and the FE and 385 family engines are big block. There's also the older family engines that those 4 replaced. The newer engines don't really have a big block/small block distinction. Since the introduction of the 6.2 it's probably the first time since Ford dropped the 302 that they've had multiple V8 families. AFAIK GM kept things a lot simpler and as such they're cheaper to upgrade.
The smallest factory big block I know of is the FE family 352 and the biggest small block is the 335 family 400M. I've also seen the FE family refered to as more of a medium block.
FPV GTHO is offline   Reply With Quote Multi-Quote with this Post
Old 07-06-2014, 10:55 PM   #7
pottery beige
you need big rocket covers
big blocks have big rocket covers
Old 07-06-2014, 10:58 PM   #8
Bossxr8
Peter Car
Bossxr8's Avatar
I think deck height is a good indicator for wether it is a big or small block.
But the lines can get blurred, Ford Racing are offering 460 cubic inch Windsors now.
Old 07-06-2014, 11:09 PM   #9
BIONIC MAN
Two turning.. two burning
BIONIC MAN's Avatar
do you think the OP is asking at what cubic inches the "cutoff number" is, thinking that a particular engine can become a big block when bored/stroked?
like a 302 Windsor is a small block, but a 434 Windsor is now a big block?
As has been said before its to do with bore spacing of the original block... not directly related to cubic inches.
I LIKE BLOWERS, TURBO'S.. AND ENGINES BIG ENOUGH NOT TO NEED EITHER
BLOWN, 2013 FPV GS UTE
TURBO TERRITORY GHIA
545ci XB GS UTE
Daily, 2006 F250 crew cab
BA2 Fairmont Ghia
BIONIC MAN is offline   Reply With Quote Multi-Quote with this Post
Old 07-06-2014, 11:13 PM   #10
BIONIC MAN
BIONIC MAN's Avatar
Sure.. like I need new SEAL panels for my car.. they must have got fully rusted out from the salt water with all the seals living in there!?!?
545ci XB GS UTE
BA2 Fairmont Ghia
Old 07-06-2014, 11:32 PM   #11
pottery beige
https://www.youtube.com/watch?v=ZUabDrfjATY
Old 07-06-2014, 11:41 PM   #12
XB GS 351 Coupe
I am guessing they are covers covering the rockets rather than the much more common rockers.
The Daily Driver : '98 EL Falcon, 5 Speed , 3.45 lsd
The Week End Bruiser : FPV BF GT 40th Anniversary, 6 Speed Manual, 6/4 Brembo and lots of Herrod goodies
Project 1 : '75 XB GS 351 Ute, Toploader, 9" with 3.5's
Project 2 : '74 XB GS Big Block Coupe, Toploader, 9" with 4.11's
In Storage : '74 XB GS 351 Fairmont Sedan
XB Falcon Owners Group
Mike's Man Cave
XB GS 351 Coupe is offline   Reply With Quote Multi-Quote with this Post
Old 07-06-2014, 11:42 PM   #13
BIONIC MAN
BIONIC MAN's Avatar
hahaha... now back to big block/small block discussion...
big block must have rockets under their covers.. that's why they go so fast.
545ci XB GS UTE
BA2 Fairmont Ghia
Old 07-06-2014, 11:46 PM   #14
pottery beige
i've still got icecream over my beak
Old 08-06-2014, 12:17 AM   #15
Crazy Dazz
Not really, the same basic block is often made with different heights. The bigger Clevos or "M" blocks had a 10.3 inch deck, the same as the 385 big block.
They're not actually Windsors, but yes it does show how the lines can be blurred with newer technology. Those "Man-O-War" blocks are externally compatible with Windsor fittings and weigh only 60kg more. So you can now get a "big block" in a small block package.
Old 08-06-2014, 12:55 AM   #16
Moby Vic
Cynical Idealist
Moby Vic's Avatar
Correct. The terms "big block" and "small block" refer to the design rather than the displacement. Small blocks use thin-wall casting.
AMC offered a 390 and 401 that used the same block as the 360 and smaller variants (I can't remember the original displacement--327 or 343, maybe). It was a small-block engine with "big block" displacement.
Your plastic pal who's fun to be with!
Moby Vic is offline   Reply With Quote Multi-Quote with this Post
Old 08-06-2014, 07:40 PM   #17
Bossxr8
Peter Car
Bossxr8's Avatar
Originally Posted by Crazy Dazz View Post
Not really, the same basic block is often made with different heights. The bigger Clevos or "M" blocks had a 10.3 inch deck, the same as the 385 big block.They're not actually Windsors, but yes it does show how the lines can be blurred with newer technology. Those "Man-O-War" blocks are externally compatible with Windsor fittings and weigh only 60kg more. So you can now get a "big block" in a small block package.
Its a Ford Racing 351 block.
And it's a straight Windsor.
http://www.fordracingparts.com/parts...KeyField=23194
Old 08-06-2014, 08:10 PM   #18
Charliewool
Bolt Nerd
Charliewool's Avatar
Correct!... In fact FE's are a "medium block".
Bore spacing is the only way to define "big block"/ "small block" in Fords.
Cubic inches and deck height are irrelevant.
Eg: Windsors were as small as 221cu and as large as 351.
FE's Started at 332cu to 428 with some odds in between like 406 & 410.
Won't even mention Y blocks (272, 292, 312 etc) which by bore spacing are "small block".. until you try and lift one!
Current vehicles.. Yamaha Rhino UTV, SWB 4L TJ Jeep, and boring Lhd RAV4
Bionic BF F6... UPDATE: Replaced by Shiro White 370z 7A Roadster. SOLD
Workhack: FG Silhouette XR50 Turbo ute (11.63@127.44mph) SOLD
2 wheels.. 2015 103ci HD Wideglide.. SOLD
SOLD THE LOT, Voted with our feet and relocated to COSTA RICA for some Pura Vida!
(Ex Blood Orange #023 FPV Pursuit owner : )
Charliewool is online now   Reply With Quote Multi-Quote with this Post
Old 08-06-2014, 09:15 PM   #19
MethodX
MethodX's Avatar
396, 427, 454 are big blocks true.
The 400 is a stretched version of the 350 is it not?
But didn't Chevrolet still produce a 402 version of the 396 big block?
MethodX is offline   Reply With Quote Multi-Quote with this Post
Old 08-06-2014, 10:01 PM   #20
GTP-RPD
GTP-RPD
GTP-RPD's Avatar
I had read once that all 396's became 402's in 1970 but were called 396 for insurance purposes.
GTP-RPD is offline   Reply With Quote Multi-Quote with this Post
Old 08-06-2014, 10:09 PM   #21
MethodX
MethodX's Avatar
Then you have the 348 and 409 big blocks. The w heads, Which were available until the mid 60's
Shes so fine my 409.....
Old 09-06-2014, 12:55 AM   #22
barnz_xr8
Turbo 358W
barnz_xr8's Avatar
its deck height and bore spacing, cubic inch's are irrelevant .
barnz_xr8 is offline   Reply With Quote Multi-Quote with this Post
Old 09-06-2014, 01:33 AM   #23
Crazy Dazz
Nope.
Ok, that IS the Ford Racing Version, but the same thing applies. The one thing it definitely is NOT is a "straight Windsor."
It's a NEW speciality block which again is mostly externally compatible with Windsor peripherals. The deck height is higher again, and the material is a lot stronger (high Nickel content I believe) again allowing a larger bore.
Old 09-06-2014, 04:30 AM   #24
chevypower
chevypower's Avatar
GM Powertrain also has a 454 LSX (small block).
chevypower is offline   Reply With Quote Multi-Quote with this Post
Old 09-06-2014, 08:52 AM   #25
Sox
RIP...
Sox's Avatar
This is the right answer.
Oval Everywhere...
Old 09-06-2014, 06:26 PM   #26
noflac52
noflac52's Avatar
All of the engine displacement, deck height etc stuff is not really relevant. Its the weight of the block. You have to compare apples with apples and in the sixties and seventies they were made of cast iron and the big blocks weighed more than the small blocks hence big blocks, small blocks.
We aren't talking about engines here for those who will come back and say such and such engine weighs more than such and such engine. We are talking about blocks.
If a bigger displacement of more than 400cu in or so was required a bigger block was cast to build a bigger engine. With todays technology big block/ small block isn't as defined as it was then.
noflac52 is offline   Reply With Quote Multi-Quote with this Post
Old 09-06-2014, 06:33 PM   #27
pottery beige
what are you on
Old 09-06-2014, 06:38 PM   #28
noflac52
noflac52's Avatar
Facts
Old 09-06-2014, 06:51 PM   #29
FPV GTHO
Of course, generally if you design a motor from scratch with a taller deck height and wider bore spacing it's going to weigh more. Both of those are needed for a wider bore and longer stroke. In a perfect world, each unique displacement would have a unique block casting, but that would be massively expensive, so you're left with manufacturers pushing the limits and getting small blocks matching and exceeding capacities of big blocks.
Old 09-06-2014, 07:01 PM   #30
GTB 351
GTB 351's Avatar
its bore spacing. 4.8 inches for hemi, 4.9 for 385 family, 3.84 for bb chev. Top fuel runs Hemi's because the rules limit you to 4.8 inches, not because they are the best! Most small blocks are around the 4.3's or less.
Deck height Phhhttt! big block chevs are 9.2 same as a clevo, 351 windsors are 9.5. Don't give a rats asse what a small block chev is coz I'll never touch one.
Then theres rod length - 5.7 for the bigger smallblocks [except mopar which are a bit longer] Big block fords and mopars are 6.6 inches plus, chevs a bit less...................................blah blah
The Car -
http://www.fordforums.com.au/showthread.php?t=11358570
The Engine Rebuild-
http://www.fordforums.com.au/showthread.php?t=11361067
GTB 351 is offline   Reply With Quote Multi-Quote with this Post
