09-06-2014, 01:02 AM | #1 | ||
With the same displacement which design of motor has the better potential for power?
4000cc inline 6 or 4000cc V8? Assuming a modern design in both such as multiple valves and cams.... which design would be more likely to produce more power with the same displacement. |
09-06-2014, 09:57 AM | #2 | ||
Probably the same power but the v8 will sound better doing it so it wins
Had EB XR8 AU XR8 220 (awsome car ) AU Fairmont BA MK2 XR6 Turbo Now XDUB |
09-06-2014, 10:08 AM | #3 | ||
what bore and stroke of each combination?
09-06-2014, 10:12 AM | #4 | |||
Thailand Specials
That Toyota 1UZFE 4L V8 is a pretty neat engine:
09-06-2014, 10:19 AM | #5 | ||
09-06-2014, 10:20 AM | #6 | ||
RIP...
I would imagine that in a hypothetical question such as this, we can assume that a bore and stroke ratio optimised for each cylinder config.
Otherwise it's a huge can of worms with numerous answers. Considering this, the maximum outputs for each engine should be mostly similar.
. Oval Everywhere... |
09-06-2014, 10:22 AM | #7 | ||
Oo\===/oO
More cylinders = more valve area...
Does that mean more power though? String, how long...
09-06-2014, 10:28 AM | #8 | |||
RIP...
However if the bore/stroke is optimised for both, the valve area can be roughly the same.
09-06-2014, 10:32 AM | #9 | ||||
Thailand Specials
Someone on Fordmods has one in an E Series Falcon. |
09-06-2014, 12:11 PM | #10 | ||
If you don't like posts by any member put them on ignore
Anymore off topic posts and or digs will result in warnings being given |
09-06-2014, 12:32 PM | #11 | ||
The V8 will have more exhaust pulses allowing a bigger exhaust without loss of scavenging, lighter pistons and smaller stroke allowing higher rpm peak. The 6 cylinder will be simpler and likely produce more torque though.
09-06-2014, 12:52 PM | #13 | ||
Thailand Specials
09-06-2014, 01:09 PM | #14 | ||
They are a nice little engine, I have one in my ls400, my young brother has 3 cars with 1uz donks, soarers (one super charged one na)and one sleeper na in a smaller vehicle, and I have done the glass of water trick on the engine, they really are a nice smooth donk.
09-06-2014, 03:53 PM | #15 | ||
I'll take the one with the most useable torque.
09-06-2014, 06:08 PM | #16 | ||
Would have to assume engine configurations are optimised.
the reason I ask this question is that vehicle manufacturers seem to be fitting smaller boosted motors in bigger cars.. for instance mercedes is working on a 4000cc V8 to then turbo. Why didnt they go for the 6 cylinder of similar capacity? |
09-06-2014, 06:11 PM | #17 | ||
I6 is too long for most cars that's why they go v6 or v8
09-06-2014, 06:21 PM | #18 | |||
RIP...
Smoothness and packaging are also very important. V8's are inherently quite smooth and quite compact for the amount of cylinders. I6's are very smooth, but very long. V6's are very compact, but full of vibes and are difficult to make smooth, needing balance shafts, etc.
09-06-2014, 07:30 PM | #19 | |||
Oo\===/oO
British Racing Motors took advantage F1 of the rule of allowing engines under 1.5 being boosted. BRM got the slide rules out and found that the V16 gave them the best total valve area...with a huge 2in stroke... Not sure if the advantage is that great in this case (4L V8 v's V6), but I would imagine that there is some efficiency of displacement advantage... Plus you can have "V8 Kompressor" badges on the car...********* awesome in any language.
09-06-2014, 07:53 PM | #20 | ||
Still an I6 will use less fuel compared to a V8 plus they're very balanced even stock bottom end.....Look at the Nissan 3.0ltr engine Holden put in the VL commo....Great injected motor with only 3 ltrs.
09-06-2014, 08:03 PM | #21 | ||
Why would an I6 use less fuel, everything else equal?
09-06-2014, 08:10 PM | #22 | ||
Now Fordless
09-06-2014, 08:34 PM | #23 | |||
Long live the GT !
My bet would be on the V8 making more horsepower with peak torque arriving higher up the rev range than the same capacity straight six. You could use the BMW E92 V8 (309kW@8300rpm) as a benchmark, but I doubt a straight six would be making that kind of power at those revs..
2018 Ford Mustang GT - Oxford White | Auto | Herrod Tune | K&N Filter | StreetFighter Oil Separators | H&R Springs | Whiteline Vertical Links | Ceramic Protection | Tint "Whatya think of me car, XR Falcon, 351 Blown Cleveland running Motec injection and runnin' on methanol... goes pretty hard too, got heaps of torque for chucking burnouts, IT'S UNREAL !!" - Poida
09-06-2014, 08:37 PM | #24 | ||
TVR made a 300kw+ 4L Inline six back in the late 1990s
09-06-2014, 08:45 PM | #25 | ||
09-06-2014, 08:50 PM | #26 | |||
Also look at the GT3 RS 4.0 368 kW at 8250 rpm and 460 N·m of torque at 5750 rpm Last edited by dragons90; 09-06-2014 at 09:18 PM. |
09-06-2014, 09:35 PM | #27 | ||
Peter Car
One factor to consider is the more cylinders, the more friction would be generated from 8 pistons/conrods etc Vs 6 pistons/conrods etc.
But then again those 6 cylinders would have to be bigger so maybe it would balance out. I doubt there would be much in it at all, all things being equal. |
09-06-2014, 09:59 PM | #28 | ||
Why not a huge 4000cc 4 cylinder with vtec?
Discussion not limited to other types of designs. Just looking at a certain displacement and considering the options.. Let's say 4000cc |
09-06-2014, 10:00 PM | #29 | ||
Formerly ST170ish
Given the same specs the V8 should pip the six in torque because of the extra power strokes per single revolution of the crank.
My bad attitude escalates in direct proportion to the amount of stupidity I am presented with!!! |
09-06-2014, 10:28 PM | #30 | ||
Getting back to the question-
"With the same displacement which design of motor has the better potential for power? 4000cc inline 6 or 4000cc V8? The answer is the V8 and here is why. Divide the 4000cc by 6 for the inline 6 cylinder and you will get 666.66cc now Divide the 4000cc by 8 for the V8 and you will get 500cc First thing to notice is that inline 6 has a greater volume per cylinder than the V8 and this greater volume affects the amount of time for the flame front to cross the combustion chamber. The larger the volume, the more time the flame takes to cross the camber. Now we are talking in micro seconds here, but if you think about the size of the atoms/molecules colliding inside the combustion chamber and their relationship to the size of the combustion chamber this a big deal on their scale. Now the engine with the fastest complete burn time is the engine with the most potential, in this case the V8. 1. The V8 with it's faster burn time allows the torque curve to be raised up the rev range thus producing more power. 2. The faster burn time allows the fuel mixture to be leaned, (that is to run a leaner mixture under full throttle), a leaner mixture burns slower but releases more energy (heat) than a richer mixture, and this is compensated by the smaller combustion volume. The evidence to support this would be the very high revving motorcycle engines doing 10,000 rpm plus. I guess it would be like bolting 8 small high revving engines together. Peter |
