Old 01-07-2014, 07:22 PM   #1
becchops
Secret Squirrel
becchops's Avatar
Default LED trailer lights wiring issue
hi all, got an issue with wiring new lights onto trailer, hope i explain this clearly enough and someone can help,
1, blinker, tail light and brake light works individualy on 12v power supply
2, connect all, but brakes, up to trailer, all good
3, as soon as i connect the brake wire, i lose the tail light
4, tested lights off trailer with 12v power supply again, and when i have tail lights connected, i am getting 12v coming back out of light on the brake wire???
Sounds clear in my head, not so sure about everyone else, thanks in advance
Livin' the dream
becchops is offline   Reply With Quote Multi-Quote with this Post
Old 01-07-2014, 07:52 PM   #2
DP GTP
DP GTP's Avatar
Default Re: LED trailer lights wiring issue
IF you have wired up everything as per standard wiring the its most likely a poor earth. It also depends on your trailer is wired for 5 pin or 7 pin, same goes for your vehicle.
Daz
Daz
2010 GT-P 5.4
Black (silhouette) with Blue
ZF
Herrod CAI
Herrod 2.5 twin Stainless Cat back
DP GTP is offline   Reply With Quote Multi-Quote with this Post
Old 01-07-2014, 07:54 PM   #3
XR Martin
XR Martin's Avatar
What vehicle?
Alot of late model cars have issues with LEDs
2004 BA wagon RTV project.
Old 01-07-2014, 07:58 PM   #4
becchops
Secret Squirrel
becchops's Avatar
DP GTP - bad earth is what i thought, so i connected straight to trailer plug on 3 cars, and still same issue.
XR6 Martin - three cars have done the same, my SZ Territory, my dads 2011 navara and also his BA falcon,
Starting to think maybe faulty lights, not sure
Livin' the dream
Old 01-07-2014, 09:02 PM   #5
DP GTP
DP GTP's Avatar
You may have already done it....but perhaps disconnect 1 side of the trailer and see if 1 set of lights is causing the issue. Could still be a poor connection on 1 side.
Daz
2010 GT-P 5.4
ZF
Herrod CAI
Old 01-07-2014, 10:26 PM   #6
jmack
Had same prob with boat tail clearance lights would come on when you hit brakes. Lights that use same leds just different voltage for brightness give feed back .voltage drops off when a load is applied as in car brake tail globes .
jmack is offline   Reply With Quote Multi-Quote with this Post
Old 02-07-2014, 07:06 AM   #7
foxtrot3
foxtrot3's Avatar
Hi. You could try a 3 amp diode in the brake and tail light wires to each lamp or send them back to China and get some quality narva lamps that work first time, every time. Cheers MD
HI
I'M MICHAEL
foxtrot3 is offline   Reply With Quote Multi-Quote with this Post
Old 02-07-2014, 08:21 AM   #8
ebv8
ebv8's Avatar
are the light cheap ebay ones or bought from an autostore like repco or supercheap?
i have had similar issues with ebay chinese ones, the connections are just really poor and wires are way too thin
LEDs look great but only work on certain cars so replace them with regular lights maybe?
I have LED's on my trailers and they work on my VX Commodore fine but not on my brothers territory or a mates X5 so that just means i don't lend it out anymore which suits me.
My dads new Pajero needed a wiring loom mod so it can run LED lights on trailers
CURRENT RIDES
BA GT Mk1 #0009 - Narooma Blue
SY Ghia AWD
Black VZ LX8 Adventra
Holden HX 50th Anniversary
AU Saloon Car racecar
1980 GS1000ST - Wes Cooley Rep
ebv8 is offline   Reply With Quote Multi-Quote with this Post
Old 02-07-2014, 09:19 AM   #9
randel
randel's Avatar
Agree with the other guys - did you run an earth wire in the loom/plug?
Daily Driver - FG GS Ute
Toys - 351 XY Falcon and FG GT
randel is offline   Reply With Quote Multi-Quote with this Post
Old 02-07-2014, 02:40 PM   #10
Itsme
Experienced Member
Itsme's Avatar
Are you also losing the car stop lights when applying the brake?
I think you might need load resistors to be wired with the LED's
Itsme is offline   Reply With Quote Multi-Quote with this Post
Old 02-07-2014, 02:59 PM   #11
Crazy Dazz
So when you apply 12v to the Tail-light connection, the tail light illuminates, BUT you are reading 12v on the "unconnected" brake-light wire?
I'm assuming the brake and tail LEDs are separate?
SOUNDS like either the tail lights have been cross-wired to the brake lights, or there is a short to earth in their somewhere.
Making Whine from the Tears of Hippies
Old 02-07-2014, 03:15 PM   #12
vztrt
IWCMOGTVM Club Supporter
vztrt's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: vztrt is one of the most consistent and respected contributors to AFF, I have found his contributions are most useful to discussion as well as answering members queries.
I have LED tail lights on my trailer and it doesn't effect it (no special brand but that what it came with). I did have an issue with the brake lights not working at but that was the brake wire was rubbed through by poor installation by the trailer mob.
Daniel
vztrt is offline   Reply With Quote Multi-Quote with this Post
Old 02-07-2014, 04:31 PM   #13
Itsme
Experienced Member
Itsme's Avatar
Could be crossed wired but no shorts to earth as he should be blowing fuses.
Old 02-07-2014, 04:39 PM   #14
Olbucko
Olbucko's Avatar
I had exactly the same problem, I removed the conventional tail lights that were working correctly, wired in the new LED Narva lights, tried all day to solve the above problem, then gave up and reinstalled the old lights which straightaway worked correctly.
Could the socket on the car be wired up incorrectly
Is there a sparky somewhere that can tell us what we are doing wrong
Don't try and teach a pig to sing, it just wastes your time and annoys the pig.
Olbucko is offline   Reply With Quote Multi-Quote with this Post
Old 02-07-2014, 06:18 PM   #15
burnz
VFII SS UTE
burnz's Avatar
use a jumper lead and clip it to the chassis of the car and trailer.
if this works, then look for a poor earth in the wiring harness of the trailer and car plug side.
GO SOUTHS
Old 02-07-2014, 06:57 PM   #16
becchops
Secret Squirrel
becchops's Avatar
yes you are correct, i have a earth wire in the loom from the plug, but get this it all works fine on my uncles 2013 ranger, go figure
Livin' the dream
Old 02-07-2014, 06:59 PM   #17
becchops
Secret Squirrel
becchops's Avatar
would like to thank every one for their input, it has been great, i am getting a new set sent anyway, so we'll see if that makes a difference, will let you all know
Livin' the dream
Old 02-07-2014, 10:43 PM   #18
Cashie
Cashie's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Multiple helpful contributions throughout the tech area.
The issue is normally because the brake and tail lights share a common return (original lamp had a dual filament globe). You'll most likely need a diode on the brake light circuit.
What car is it and how is the trailer socket connected to the car (genuine loom)?
Current Rides:
2017 Ford Mustang
2020 Ford Everest Sport
Past Rides:
2017 Kia Stinger GT
2008 FG XR6 Sedan
2008 FG G6E Sedan
2004 BA XR8 Sedan
2008 BF XR6 Turbo Sedan
2004 BA XR8 Sedan
2003 BA XR8 Ute
2003 BA XR6 Sedan
Cashie is offline   Reply With Quote Multi-Quote with this Post
Old 03-07-2014, 12:41 AM   #19
Itsme
Experienced Member
Itsme's Avatar
Yeah all lights share a common return (earth/negative) and usually everything goes pear shape when the return has a break or poor connection.
Bit strange the lights work ok on another vehicle but not his, I think his trailer loom wiring has a fault & I'm backing it will be the earth wire.
Old 03-07-2014, 07:36 PM   #20
BPXR6T
I put a new tail light on my trailer a couple of weekends ago. All the sudden tail lights start flashing, then nothing would work, the one indicator would work. So I stood there and shouted expletives at it for 15 minutes. Magically everything started working and has ever since. Worked for me...
