12-07-2014, 02:30 PM | #1 | ||
hi
when turning mains water off do you have to turn tap off at the hws and when emptying lines does it empty cold and hot lines or just cold if you dont turn any taps in the hws any answers would be good |
12-07-2014, 02:43 PM | #2 | ||
5.4
Just turn off at mains.
BA XR8 ute. 5 speed manual. 3.73 diff gears. Herrod 2 1/2 cat back. Blue Power CAI. Powerbond 25% underdrives. Melling 10227 oil pump. Horsepower engineering cylinder head cooling mod. |
12-07-2014, 02:45 PM | #3 | ||
Bolt Nerd
Just turn the mains off and fully open both taps in laundry..
Hot & cold should both cease flowing
Current vehicles.. Yamaha Rhino UTV, SWB 4L TJ Jeep, and boring Lhd RAV4 Bionic BF F6... UPDATE: Replaced by Shiro White 370z 7A Roadster. SOLD Workhack: FG Silhouette XR50 Turbo ute (11.63@127.44mph) SOLD 2 wheels.. 2015 103ci HD Wideglide.. SOLD SOLD THE LOT, Voted with our feet and relocated to COSTA RICA for some Pura Vida! (Ex Blood Orange #023 FPV Pursuit owner : ) |
12-07-2014, 02:46 PM | #4 | ||
how longs it take to drain lines when doing basin shower kitchen or laundry
12-07-2014, 04:28 PM | #5 | |||
Where to next??
Make sure you do this before you do any work.... and if your main doesn't seal closed properly do what you need to do and get everything back together - I can do 2 washers, including a valve seat grind in 3 minutes as all the places I have worked on had old / dodgy main taps. Don't do what one person did (who may or may not have driven a Festiva) and go to change a washer in the shower only to find you have the wrong one and jump in the car to go to Bunnings and return to find that small trickle going into the wall cavity eventually hit the slab and soak a 3m diameter circle of carpet into the adjoining lounge room and bed room...
___________________________ I've been around the world a couple of times or maybe more....... Last edited by Yellow_Festiva; 12-07-2014 at 04:44 PM. |
3 users like this post: |
12-07-2014, 05:59 PM | #6 | ||
Bolt Nerd
Hope he hasn't drowned....
12-07-2014, 06:08 PM | #7 | ||
Dent Removal
Don't forget to turn off HWS power as a precaution if you are working on it
2 users like this post: |
12-07-2014, 07:37 PM | #8 | ||
born to be mild
12-07-2014, 11:55 PM | #9 | ||
hi
done the job went well put isolation taps in the threaded connections on wall and went out for a few hours and got home and theres no water on shelf in vanity cupboard theres no stains or moisture on wall or floor in room behind the vanity no obvious leeks would it be safe to say its ok whats the small echo sound of water running in pipes only when you open vanity cupboard and stick your head in when theres no moisture or stains on wall or carpet behind vanity in other room mean |
13-07-2014, 08:52 PM | #10 | ||
RPO 77
something is most likely running somewhere else within house/property
Q: If you have tried to sell it three times now and it is still not sold, do you think it might be over-priced? A: It is over priced - just like all the other falcon coupes for sale!! |
14-07-2014, 11:35 PM | #12 | ||
hi
what would you do to get plumbing experience well enough to replace a sink, unblock drain or flex hoses under sinks without leaking water just basic plumbing under sinks and outside taps and stuff thats part of house maintenance when you live in country without travelling to city that water noise in wall was water dripping under house those connections in vanity where flex hoses were leaking a bit and they needed tightening up |
15-07-2014, 10:40 AM | #13 | ||
it's all common sense........sinks are a piece of cake..Youtube is your friend and the interweb in general......hardware stores will help as well.
just don't do what I did when removing an "S" bend back a while ago, still full of water and crap, I undid it and, without thinking, poured it back down the sink drain......yep! the one I just took the "S" bend off. don't over tighten those flex hoses, they have a rubber inside that gets a bit crappy and can twist out then leak,.you don't want that in an internal wall. if you can easily access them, turn the water off again, release the pressure with a nearby tap, take the flex joints apart and replace the rubbers.
--------------------------------------------------------------- G'day....I'm Dave, ...everyone calls me Poppa,..05.. B.A. Fairmont mark II... may your day's be filled with smiles, your life be filled with love, may your children know nothing but happiness and joy, cherish the memory of those who strove before us for they cleared the way, spare a thought for those who serve we owe so much to so many, life and the freedom to enjoy it is a special gift that can be taken away far too soon! |
