23-08-2014, 09:15 PM | #1 | ||
Brad
Anyone got any tips for starting a flooded RX8. Followed allot of the guides just cant get it to go. My dad moved my brothers car and didnt allow it to warm up properly. Looks like a common thing, ******* rotors
Silhouette BF MKII F6 Plazmaman Intercooler Kit, ID1000, 34mm Internal Wastegate and Turbosmart Actuator, Tein Coilovers, Focal Audio, XXR 521 18x8.5 18x10 |
23-08-2014, 10:13 PM | #3 | ||
Brad
Thanks may sign up there have tried following alot of guides and no cigar.
23-08-2014, 10:28 PM | #4 | |||
Sling Shot
23-08-2014, 10:35 PM | #5 | ||
Brad
Yea followed that and ran the battery flat . Dont like the use of the starter so looks like Ill remove the plugs tomorrow. Damn rotors.
23-08-2014, 10:40 PM | #6 | ||
growing up is optional
Had one at work a few months ago that we towed in. Tried all the things on the other forums several times. Ended up tow starting it after fitting new plugs.
23-08-2014, 11:25 PM | #7 | ||
Now Fordless
Fit new spark plugs
24-08-2014, 02:27 AM | #8 | ||
Definitely worth taking the plugs out and having a look to see if they are in fact wet. If so dry them off and if they look easy to replace quickly try heating them up with a cigarette lighter before replacing them - with lawn mowers at least this seems to make them easier to start. If they're not wet then I'd start to wonder whether it is in fact flooded - assuming you mean fuel and not car in body of water?
24-08-2014, 07:34 AM | #9 | ||
Excessive Fuel Ingestion
Nothing wrong with rotors, just a bit tempermental is all.
A fair bit similar to an 8 with a giant cam etc. Remove the plugs, and give it a wind over to help clear the combustion chambers, and try again. Ed
Recommended Forum Traders: RSGerry, trimmaster, 51OAU, EB-92, adxr8, my67xr, RG, ZA-289, kruptor, gassa, Felony, RNXR, Rhino 351, Anchor, Smoke Pursuit, Mr. FPV (through E-Bay), |
24-08-2014, 08:16 AM | #11 | ||
FG Falcon fan
I think the RX8 is a terrible car.
Good: good handling, looks funky, unique, funn-ish Bad: awful fuel economy, modest power, very cramped inside, expensive RRP when new You cant have a tiny car which chews 13L/100km AND also not be super fast. And be super expensive when new, i.e around 58,000. Sorry, its a joke. |
3 users like this post: |
24-08-2014, 08:56 AM | #12 | ||
If you have a glass cleaner machine then chuck the plugs in there.
03 BA Turbo 6466 external gate Hi comp motor Built BTR 4k TCE stall FG inlet and exhaust manifolds |
24-08-2014, 11:18 AM | #13 | |||
bitch lasagne
24-08-2014, 11:25 AM | #14 | |||
Thailand Specials
RX8 is still a nice car though. |
24-08-2014, 12:32 PM | #15 | ||
Generally a tow start is the best bet in rx8's then give it a dammed good hiding once it's up and running.
Biggest issue with these cars is people baby them around.
2011 Vixen fg turbo ute. Plasmaman cai, pipework, intercooler, surge tank, 044, injectors, 4 inch dump pipe, 5 inch cat. Custom engine tune + zf tune by WRC developments ~20psi boost. |
24-08-2014, 04:27 PM | #16 | ||
Hi mate I work for mazda and this is how we get them started.
First thing to do is remove the spark plugs and clean them with some carby or brake cleaner. It would be best to replace the plugs Then disconnect the crank angle sensor and crank the motor over for about 5 seconds this will remove excess fuel from the rotar housing. Next you will see 2 rubber plugs on the intake manifold remove these and with an squirt oil can and a piece of vacuum hose put about 4 pump of rotary oil into each. This will oil up the rotar housings and help you get some compression. When the motor floods it removes all the oil from the housing and makes it difficult to get compression. Next make sure the crank sensor is reconnected and plugs are refitted then crank car with foot flat on the throttle till the motor kicks then release as soon as the motor start to run give it full throttle otherwise it will just stall. Hope this is of some help it can take many attempts to get it started there is a little bit of a technique required with the throttle but it's a little hard to explain in writing. Good luck |
5 users like this post: |
25-08-2014, 07:45 AM | #17 | ||
BAM---solved...
25-08-2014, 12:17 PM | #18 | |||
Brad
Had a look at the price for plugs and they make my iridium plugs in the turbo look cheap!
25-08-2014, 12:19 PM | #19 | ||
Trev
Keep an eye on the oil too as if doing lots of short trips the oil doesn't get hot enough to get rid of the condensation that can built up overnight in the motor, particularly if parked outside, then you get a lot of condensation water diluting the oil and seeing some white streak on the dipstick etc. In winter it can pay to tape up the oil cooler etc. so the motor gets to and keeps temp better. They are a good fun drive though!
Trev (FPV FG II GT-E thus the fully loaded burger with the lot as standard +Alpine/Dynamat fitout - 2 of only 4 ever made GT-E factory 9" rear rims - Michelin Pilot Supersports - Shockworks Suspension) |
25-08-2014, 01:49 PM | #20 | ||
Call me 'Al'
Location: On a flattened-out cardboard box out the back behind the wheelie bins.
Depends on what else you've driven. We know what you know now.
25-08-2014, 01:51 PM | #21 | ||
The 'Stihl' Man
Um without going to OT can I ask a question...what is it like driving one of these for a daily?
Ive been in a RX8 GT before, a quick spin if you like, but as far as living with one is it that doable? Because without being rude I had a quick look on carsales and they are pretty cheap! Whats the catch? I love the last of the RX7's but they seem to be double the price of some RX8's for what is essentially the same car?
25-08-2014, 01:56 PM | #22 | |||
Call me 'Al'
The later RX7s - series 5s onwards - were turbocharged and were proper performance cars. The RX8 were an NA rotor (welcome to 1981!) and too much of a compromise. Last edited by Alan D Segal; 25-08-2014 at 02:23 PM. |
25-08-2014, 02:20 PM | #23 | ||
The 'Stihl' Man
Fair call, was curious if it some something that suited being a daily that you can have some fun with the odd track day aswell.
I cant believe they even sold an auto..LOL
25-08-2014, 09:38 PM | #25 | ||
Oo\===/oO
Sounds like more fun then a flooded Nitro RC haha
2 users like this post: |
28-08-2014, 08:26 PM | #26 | ||
Brad
Got it going. Took it for a good drive before giving it back to the little bro. Quite a fun little car to drive but my F6 produces so much torque I found it a bit bland in a straight line. Like it through a few twisties though.
28-08-2014, 09:52 PM | #27 | ||
28-08-2014, 10:41 PM | #28 | ||
28-08-2014, 10:48 PM | #29 | ||
My son is on his second RX8, he had never had the problem nor had he even heard of it. I think I had doing some research when he was buying the first.
igodabigblackshinycar and I relented and allowed a BMW into the garage. |
28-08-2014, 11:03 PM | #30 | ||
Brad
Just make sure its warmed up before shut off. Thats what causes it.
