Old 29-08-2014, 03:08 PM   #1
guscorty
Default Heat in the Mickey Thompsons
Hi Everyone,
I'm running the Mickey Thompson Street Et Radials on my car. Someone said to me that I wasn't putting enough heat into them in the burnout. Someone else said that they don't need much heat. Any advice would be appreciated.
guscorty is offline   Reply With Quote Multi-Quote with this Post
Old 29-08-2014, 08:25 PM   #2
prasac
prasac's Avatar
Default Re: Heat in the Mickey Thompsons
Big first burnout, at least 5-sec big smoke, then little after that. High speed burnout, rev it out.
prasac is offline   Reply With Quote Multi-Quote with this Post
Old 29-08-2014, 09:44 PM   #3
Giant
Giant's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Organising Nulon to sponsor AFF.
Electric hot blankets
Giant is offline   Reply With Quote Multi-Quote with this Post
Old 18-09-2014, 03:39 PM   #4
ronnyBB
Channel 4 news team
ronnyBB's Avatar
They get worse when too hot
Slicks like more heat
Buy a cheap temp gun and get someone to monitor while you are staging
XE ESP V8 9.3L 9.6@140
ronnyBB is offline   Reply With Quote Multi-Quote with this Post
Old 24-10-2014, 08:13 PM   #5
ash68
Small burn to clean them is all you need
ash68 is offline   Reply With Quote Multi-Quote with this Post
Old 02-11-2014, 08:29 PM   #6
Shonky.
Shonky.'s Avatar
what temp would you be aiming for?
Shonky. is offline   Reply With Quote Multi-Quote with this Post
Old 03-11-2014, 12:07 PM   #7
ronnyBB
Channel 4 news team
ronnyBB's Avatar
The one that grips the best ;)
Try hotter, try colder...
Old 04-11-2014, 11:41 AM   #8
guscorty
Thanks for the replies everyone. Just changing the subject, at the last meeting I couldn't believe the difference changing the tyre pressure made. I went from 24 psi on the first run and getting bad wheel wheel spin, to 20 psi on the second run about 3 hours later and they stuck like glue. Admittedly the air temp was also slightly cooler and whether the track temp was also slightly cooler I don't know. A lot to learn.
Thanks Guys.
Old 04-11-2014, 02:46 PM   #9
prasac
prasac's Avatar
we usually run 17psi, 3200lbs, 275, 15x10
They definitely hook, we found no difference between them and a slick in performance. weight is different about 6kg
Old 04-11-2014, 10:43 PM   #10
XR8menace
^^^this^^^
I found 17psi cold which is around 18psi after burnout is the go on a decent track, running 275 MT Pro radials, 3900lbs, 1.3s 60ft 15x9.25 rims but I'm looking at getting a set of 15x10s as Paulie said! Burn out short and with decent wheel speed. You don't need to see big smoke, some of my mates call my burn outs soft, I just reply but I wana go fast!
Corey
XR8menace is offline   Reply With Quote Multi-Quote with this Post
Old 05-11-2014, 12:42 PM   #11
ronnyBB
Channel 4 news team
ronnyBB's Avatar
I get best results around 20psi warm, 3960lb car, 275/60/15, 1.4s 60'
Old 06-11-2014, 12:37 AM   #12
Shonky.
Shonky.'s Avatar
For 400 - 450rwkw in a Zf Miami sedan would I unstick 265/40/18 ET 2s?
I want to buy my first set of drag radials and mount them on 18x9.5 +38s
Would I be better squeezing a 305/35/18 on the rim, or does the bulge it would get on a 9.5 inch rim make the 265 a better choice?
Old 06-11-2014, 09:07 AM   #13
prasac
prasac's Avatar
the more sidewall you can get the better. M&H make a decent radial as well for IRS cars, check out VPW. Pretty sure they do a 275/40/18 and 275/50/18, either will suffice.
Old 06-11-2014, 10:09 AM   #14
Shonky.
Shonky.'s Avatar
I guess I was hoping to keep similar diameter as the front so I can drive it to the track, but a low profile sidewall is probably too much of a compromise?
Old 06-11-2014, 11:27 AM   #15
ronnyBB
Channel 4 news team
ronnyBB's Avatar
Do you have to run a 18" rim?
For best results, the shortest rim you can fit over your brakes with the tallest tyre you can fit in the guard
A taller tyre gives more rubber on the track also
Old 06-11-2014, 12:49 PM   #16
Shonky.
Shonky.'s Avatar
Yeah, I've got 4 piston brembos on the back which other than a few notable (and expensive) exceptions need an 18
I'll probably just get the wheels, dummy fit a steet tyre and then measure what it will take from that.
So sounds like the message is height before width.
If I turn DSC off will it drive to the track ok with way taller tyres on the back?
*sorry for the massive thread jack everyone*
Old 06-11-2014, 04:07 PM   #17
ronnyBB
Channel 4 news team
ronnyBB's Avatar
Both height and/or width help
Do whatever fits
Dont even know what DSC is lol
Im old school
Old 07-11-2014, 01:11 AM   #18
prasac
prasac's Avatar
She should be fine driving on the street to track. Sidewall is good to a certain point then start going width. Put it thithis way they are running 4.8@163mph to half track on a 235 radial
Old 07-11-2014, 02:20 AM   #19
Shonky.
Shonky.'s Avatar
Thanks guys
Dsc = dynamic stability control
It thinks different tyre sizes are a fault cause of different speeds
