14-09-2014, 08:45 PM | #1 | ||
Over Thinker
someone has asked me to help fit a clutch in a fiesta
done front wheel drives before not a festiva .. only toyotas mitsubishis what the easiest way to do the job on this Ford dont have a repair manual -no nice hoist- so need a how to DIY guide gearbox out from under what has to be done for this way Take the motor and gearbox out any annoying quirks to doing this
My car goes Brumm Brumm |
15-09-2014, 05:59 PM | #2 | ||
Over Thinker
humm
how to on - clutch jobs not coming up in a search will need a repair manual
15-09-2014, 07:37 PM | #3 | ||
Over Thinker
dam its a mazda engine and gearbox ...
clone of the mazda 121 hatch http://www.ebay.com.au/itm/Mazda-121...item23400e8729
My car goes Brumm Brumm Last edited by dirty hands; 15-09-2014 at 07:45 PM. |
15-09-2014, 07:57 PM | #4 | ||
should be able to do it from underneath, with the engine supported. you know the have an internal slave cylinder yeah. is it festiva or fiesta?
21-09-2014, 03:38 PM | #5 | ||
Over Thinker
he tells me its a fiesta -- get to see the car this week - to confirm
internal slave cyl -nope didnt know - you mean inside the bell housing -whos bright idea was that ? one repair manual for a fiesta Mark 3 89-95 -300 pages - no gearbox section wow engine and gearbox remove togeather ---thats it http://vk.com/doc-50029547_161721090...13b3cd81cf1c0b
My car goes Brumm Brumm Last edited by dirty hands; 21-09-2014 at 03:59 PM. |
21-09-2014, 04:14 PM | #6 | ||
Over Thinker
clutch slave not cheap
can come with the whole clutch kit (makes sense) uses a a borg and beck Concentric Slave Cylinder for the Ford Fiesta so If the clutch slave is suspect --the box has to come out - just to replace this part and slave cyl part is holding the throw out bearing to the clutch -over the input shaft will do a write up about this job ...if it comes my way
My car goes Brumm Brumm Last edited by dirty hands; 21-09-2014 at 04:31 PM. |
23-09-2014, 01:21 PM | #7 | ||
Over Thinker
i went to a wrecker and found a ford fiesta
they removed the manual gearbox from below motor the subframe inplace gives some hope
27-09-2014, 11:00 AM | #8 | ||
box out from underneath leave subframe in place.
OR if you don't have AC in the car its quicker and easier to drop engine and box out from underneath then split |
27-09-2014, 12:40 PM | #9 | ||
What model fiesta was it exactly?
SZ TS Territory TDCi '13 WQ LX Fiesta '08 XG Falcon '94 |
27-09-2014, 01:00 PM | #10 | ||
Shouldn't matter as long as its a fiesta not a festiva out the bottom it needs to come.
Advertising removed. |
30-09-2014, 10:23 AM | #11 | ||
Over Thinker
found out today - and looked at it for the first time its a 1999 model
getting a battery to test drive it and do diagnostics and compression test unreg for some reason how do you bleed the internal master cyl pretty good shape straight no rust - had a lot of work done 444000 k but not the original motor gearbox from the bottom will work better for me looks like undo the centre brace drive shafts out take off gearbox attachments - drop out below - not too bad I would say no repair manual yet doing more research
30-09-2014, 11:12 AM | #12 | ||
Thailand Specials
It'll be a Festiva, not a Fiesta as we didn't get them in Australia until later.
I've got the genuine shop manual for a WF Festiva, I'm scanning the manual trans removal procedure and I'll link to it up here. Fluid inspection and replacement: Last edited by Franco Cozzo; 30-09-2014 at 11:42 AM. |
30-09-2014, 03:37 PM | #13 | ||
unlucky :(
the fiesta was such a better car! good luck with the box swap mate.
30-09-2014, 09:00 PM | #14 | ||
Over Thinker
now confirmed --- its a 1999 Ford Festiva Hatchback
a mazda 323 clone thank you the scanning in of the required parts that is great
30-09-2014, 09:19 PM | #15 | ||
crikey , that looks like hard yakka, will this need a dual mass flywheel ?
good there job BigDamo. |
30-09-2014, 10:00 PM | #16 | |||
Thailand Specials
Depending on engine variant you have, it'll either be a Mazda B3 (1.3L) or B5 (1.5L) engine. I have one here also, pretty easy to work on lots of room in the engine bay compared to most FWD cars getting around today. I don't think it would, thats more of a modern thing, these Festivas are quite basic cars but damn they put up with some punishment though, we've had ours since new, 274,000km with missing services its whole life and she still starts up and runs, never had a mechanical failure either. |
01-10-2014, 06:43 AM | #17 | ||
Over Thinker
yes it has a Kia name on one engine bay tag ---
going to be interesting if the parts guy doesnt know kia -ford -mazda parts no to fitting a dual mass flywheel --they are trouble (failure rates high) badges on side of car say its a 1.5 motor (thank you BigDamo.) yes plenty of room in the engine bay yep thats the gearbox alright didnt know the speedo was the gearbox fill up point now this forum has festiva information fantastic this is similar to the car
My car goes Brumm Brumm Last edited by dirty hands; 01-10-2014 at 06:55 AM. |
01-10-2014, 10:47 AM | #18 | ||
Thailand Specials
Yep thats a WF Festiva
31-10-2014, 10:51 PM | #19 | ||
i like the simple style cars, i just watched a video of bmw clutch job, dual mass the whole bit, crikey , for a clutch job they did have to replace a lot of parts, my mate had a clutch done on bmw mini, for the cost of his clutch repair i could buy half a fiesta or a kia, ive said this before, but if some people new the cost to do repairs/general maintenance on their small economy cars up front......they would not go near them.
