Old 07-10-2014, 07:43 AM   #1
dirty hands
Over Thinker
dirty hands's Avatar
Default 1999 festiva gearbox locked in fifth
Is this a common problem
are there any adjustments possible to remedy this
will check the engine mounts
symptom
as soon as it is put in fifth it gets stuck fast and hard
every other gears selection and changing is fine while driving
clutch is fine -
slave no leaks or problems
no crunching or other noises in the box
oil level ok
My car goes Brumm Brumm
Old 07-10-2014, 08:00 AM   #2
99AUXR
Brad
99AUXR's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Installing starter motor advice on ba / bf 6cyc Falcon.
Default Re: 1999 festiva gearbox locked in fifth
Pretty sure these use two cables too shift the gearbox, I also think that there is a little it of play where they connect that could cause an issue like this.
Silhouette BF MKII F6
Plazmaman Intercooler Kit, ID1000, 34mm Internal Wastegate and Turbosmart Actuator, Tein Coilovers, Focal Audio, XXR 521 18x8.5 18x10
99AUXR is offline   Reply With Quote Multi-Quote with this Post
Old 07-10-2014, 09:51 AM   #3
dirty hands
Over Thinker
I wish it was cables
I wish it was just the bush to replace ..car drives so well
gear stick isnt sloppy
the other gears and reverse pops in and out easy as
this 1.5 manual box wants to be to be a pain
has a single shift rod into the box
and a stay bar
thanks to Big Damo
post 12
second picture scan 41-B10
this link http://www.fordforums.com.au/showthread.php?t=11425382
Old 13-10-2014, 06:28 PM   #4
mik
mik's Avatar
where is the clutch cutting in? if its very close to the floor and the clutch is adjustable,
i would try adjusting it up just a tad and see if it makes a difference.
Old 13-10-2014, 07:42 PM   #5
dirty hands
Over Thinker
. cant get into it
.hope the owner finds his keys .
.clutch pedal length and adjustments will check
Old 29-10-2014, 12:26 AM   #6
dirty hands
Over Thinker
owner found the keys today
and will have the cash soon to take out and refit another gearbox
not helping 35 degree heat plus days . in the open on sloping pavers no power points
Old 17-11-2014, 10:53 PM   #7
dirty hands
Over Thinker
got a text from the owner --two days ago
he is going to sell the fiestiva as is
i should be greatful and not ****ed off
