WOGBOY69
Hi all
i have a major problem with my peddal box. The sir clip that holds the pin cames of and my clucth peddal moves. Has anyone got any better ideas for this problem.... I was thinking even putting a bolt straite threw ...your thoughts..on this thanks |
Over Thinker
are you able to drill a hole through the pin and pop a split pin in the drilled hole
if you use a bolt make sure its a nulox nut and flat washer that will hold
My car goes Brumm Brumm |
Tippy-tronic Free Zone
Presume you mean the 1/8" thick square section circlip. Probably just stretched.
A photo would help to confirm the item. PM me your address and email...I'll send one to you gratis. |
WOGBOY69
Hi dirty hands
that was my first thought . But drilling a hole while its still up there mite be very hard . I realy dont want to pull everything apart again. Booster and pedal box . Its a real pain. Such bad spots to work in. Allanv6gt i dont know about square section. Its at the end were the clucth pedal is round pin and it has a slot on the end of it to put a circlip . The circlip is very new maybe the clucth pedal has play in it and wants to kick out the peddal ..ill send you a pm.. |
WOGBOY69
Hi all
just want to know can you pull the pin out while every thing still stays there . Or do you need to pull every thing out thoughts |
Wogboy, PM today, and email sent yesterday with pics for confirmation of part
