Old 20-12-2014, 09:37 AM   #1
Trikes
Trikes's Avatar
Default Hill Climb Ka
Hi Guys I've bought a 2000 Ka and am going to build it up for Hill Climb racing here in Tassie. I ran a Proton Satria GTi last year on road tyres and finished 4th but the cars ahead of me are dedicated track cars (trailer queens) so I'm going down in Class (and engine size) to get away from the guys with big bucks. Sooo the Ka is a stocker and am going to go to Coil Overs as the first mod. Any suggestions on brand? Must height and be multi adjustable. Have checked out Pedders C/O and am considering Koni's as I've used Koni's before in other cars. Any suggestions recommendations for other brands will be carefully considered and researched.
Trikes is offline   Reply With Quote Multi-Quote with this Post
Old 20-12-2014, 12:52 PM   #2
jpblue1000
jpblue1000's Avatar
Default Re: Hill Climb Ka
I run konis and bilsteins on my race car (mk1 escort) and Konis on my road car.
I prefer the Bilsteins but cost a lot more and don't have any adjustability.
I will be changing out to Koni custom competition inserts
http://www.summitracing.com/search/p...-strut-inserts
internally modified to suit my spring rates and car weight.
They are also much shorter than most other shocks which is helpful.
Id also be modifying my own struts rather than buying of the shelf at great premium.
JP
jpblue1000 is offline   Reply With Quote Multi-Quote with this Post
Old 27-12-2014, 11:07 AM   #3
Trikes
Trikes's Avatar
I'm hearing a lot of good stuff about Ohlins atm. I looked at the gear you suggested and am comparing and still looking around. Lots of gear to start ordering soon. Much more gear to check out. Bit worried by the amount of U/S the Ka has on ****** tyres in std form, have to find someone to dial that out. Firstly though I need to work out it's Weight Transfer Number........ so I can plan a balanced suspension package.
Old 27-12-2014, 11:08 AM   #4
Trikes
Trikes's Avatar
Who's got light weight Seats and Runners out there?
Old 27-12-2014, 11:12 AM   #5
Trikes
Trikes's Avatar
Waiting on a reply from Extreme about a CM Flywheel and a Button Cushion Clutch. I have an Australian Extreme 3.5kg CM with a B/C Clutch in my Satria GTi and it's hook up is super impressive and street drivable unlike a straight Button Clutch.
Old 15-03-2015, 02:12 PM   #6
ispy1960
Any updates on the hill climb Ka. I have just purchased a Ka with a blown head gasket, and I intend to fit a 2 litre Zetec to give it some power. Intend to upgrade suspension and brakes, want to use 17 inch wheels (easier to get good tyres in this size). I will run the Ka gearbox, but I am looking for an LSD to help make use of the extra power. Any advice is welcome. Have no intention of putting it on the road. thanks
ispy1960 is offline   Reply With Quote Multi-Quote with this Post
