Old 21-01-2015, 02:28 PM   #1
Redxr601
Default Au xr6 2001 ac compresser bearing
Anyone no what size the bearing on the ac compresser pully is ?
Redxr601 is offline   Reply With Quote Multi-Quote with this Post
Old 21-01-2015, 04:53 PM   #2
Maka
Au Falcon = Mr Reliable
Maka's Avatar
Default Re: Au xr6 2001 ac compresser bearing
Hi Redxr601 & welcome to AFF, i dont know the size of the bearing but if you dismantle your a/c compressor & take the bearing down to a local bearing place they can measure it up & supply one one for you. Good luck!
cheer's, Maka
Old 21-01-2015, 06:14 PM   #3
Redxr601
Thanks mate I can get one off eBay I just don't no the measurements
Old 22-01-2015, 10:24 PM   #4
BOTTLEDUP
Out with the verniers then...
BOTTLEDUP is offline   Reply With Quote Multi-Quote with this Post
Old 05-02-2015, 12:12 AM   #5
Redxr601
And does anyone no if a El falcon gearbox will go in my au xr6 series 2?
Old 09-02-2015, 12:50 AM   #6
Spurious
A guess, but I'd say it'd go close.
Unless someone jumps in here & says "yes", then it may require both gearboxes to be placed on the ground next to each other & compared/measured up.
If you're keen on the exchange, get a couple of junk casings/bellhousings & see how they compare.
I don't think the engine blocks have changed much, but the "bellhousing to engine" bolt holes may be different, & the gearbox cross mount would be different. Then there's the electronics/speedo to consider.
Again, I'm guessing here.
Spurious is offline   Reply With Quote Multi-Quote with this Post
Old 09-02-2015, 01:13 PM   #7
Redxr601
Okay thanks I don't know what to do my gearbox slips then u give it a rev or to and it pops in only sometimes tho maybe a oil change will fix it ? Any ideas?
Old 12-02-2015, 12:14 PM   #8
auIILTD
5.6L x 2 pilot
auIILTD's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For the effort put into the Australia day cruise to Albury Tech Writer: Recognition for the technical writers of AFF - Issue reason: AU Tech article.
Start with transmission service, as this is the cheapest option - Filter and 4L of TQ95. Can be amazing the difference a service will make.
According to the work shop manuals, both 6 cyl EL and AU run a BTR 93LE tranmission, and both are controlled from the EECV ECU. My guess is that they would fit.
Stu
2002 AU II LTD
5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust.
Quarter Mile: 13.73 @ 105.86mph
Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024
2002 XR8 pursuit 250
Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
auIILTD is offline   Reply With Quote Multi-Quote with this Post
