Old 27-05-2015, 01:02 PM   #1
Sam1112
Over Macho Grande??
Sam1112's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Technical conbtributions
Default Forscan AU-BA PATS Key Programming
Hi all, I noticed that Forscan is beta testing PATS Key Programming for AU/AUII/AUIII and BA Falcons and Territory 2004-2006.
If you want to give it a test and help them out with the testing check out this post on their forum.
http://forscan.org/forum/viewtopic.php?f=13&t=1485
I've emailed them and got a copy of the test version of the software to try it on my BA, I'm sure there is lots of other people like me with only one programmed key who will find this useful.
Sam1112 is offline   Reply With Quote Multi-Quote with this Post
Old 27-05-2015, 06:56 PM   #2
Sox
RIP...
Sox's Avatar
Default Re: Forscan AU-BA PATS Key Programming
This is good news, and perhaps will lead to complete PATS reset allowing us to change ECU's and BEM's ourselves.
Oval Everywhere...
Old 30-05-2015, 02:18 PM   #3
Sam1112
Over Macho Grande??
Sam1112's Avatar
Well my next request to them will be to try and get ICC reprogramming included so we can swap them without having to go back to Ford.
I have tested the Keys programming and apart from a small bug (Messagebox kept popping up) that they have now fixed thanks to me, it should work flawlessly as I have had no issues with 3 BA's that now have several keys programmed.
Old 30-05-2015, 08:31 PM   #4
Simple6
Simple6's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Tech article on rear bushes.
That's really awesome to see! It's great to see this stuff getting broken down and allowing for DIY use.
1976 XB Falcon 500 Wagon - BUILD THREAD
Sherwood Green | 3spd/250CI | Running Whitewalls on a 2.5" Drop
Simple6 is offline   Reply With Quote Multi-Quote with this Post
