Hey guys, very very random question, i thought i would ask here.
i have a mini bike racing tire, im trying to find the circumference so i can set up my speedo. it is a - 110/50-6.5 Racing Slick ![]() circumference needs to be in MM. Hope someone can help. Cheers ![]()
"If Everything Seems Under Control, You're Not Going Fast Enough" - Mario Andretti 2009 Fg Xr6 Sedan n/a 5 Speed Auto - 14.1 @99 MPH Mods: Redback Exhaust & Cold Air Intake Untuned |
Tape-measure would be your friend here.
The Daily Driver : '98 EL Falcon, 5 Speed , 3.45 lsd The Week End Bruiser : FPV BF GT 40th Anniversary, 6 Speed Manual, 6/4 Brembo and lots of Herrod goodies Project 1 : '75 XB GS 351 Ute, Toploader, 9" with 3.5's Project 2 : '74 XB GS Big Block Coupe, Toploader, 9" with 4.11's In Storage : '74 XB GS 351 Fairmont Sedan XB Falcon Owners Group Mike's Man Cave |
Thanks! do you know how to messaure it using a tape? cheers
Wrap a cloth tape measure around the middle of the tyre, make sure it's fairly firm.
If you don't have a cloth one, use a piece of string and mark it clearly, then measure it. |
Clevo Mafia Inc.
![]() Join Date: Dec 2004
If you have trouble getting a tape around it try marking the edge of the tyre with chalk. Move said mark to the bottom and mark the ground where it touches.
Then move the tyre a single full revolution and mark the ground again. Then measure the distance between the two marks you have on the ground. This is how I used to setup my Husaberg speedo when using the Trail Tech Vapor. Would be best fitted to a rim and inflated before measuring. |
It is 110 mm wide and 50% profile which is 110 (55 mm top and bottom ) plus 6.5 inch wheel which is 165.1mm . Diameter is 110 plus 165.1 which is 275.1. Circumference is 2rp which is 863.8mm.
4 users like this post: |
#7 | |||
VF2 SSV WAGON
![]() Join Date: Mar 2009
the 50% side wall includes the part that goes inside the wheel right? so that maths may be out
VF2 SSV WAGON
just checked you are correct
http://tire-size-conversion.com/tyre-size-calculator/ |
Measure outside diameter then multiply by PI (3.142)
Ed Xr6 Turbo manual, GT3540, 6Boost Manifold, Autronic SM4, 285 rwKw @ 4800 rpm, 4 dead T5's, countless clutches - Now moving on to FG XR6T 6M transplant 2010 Triumph Street Triple R, Q/Shifter & Arrows minus restrictors |
Although tyres do have set dimensions ... not all are equal ... but come close to be classed for that size.
For ultimate accuracy though ... it is best to have the tyre in front of you on the rim at the inflated pressure and measure that way preferrably.
#12 | ||
As esppwr said PIxD (3.1416 x ?)
2017 Mustang GT (Magnetic) |
#13 | |||
Radius of a tyre changes depending on pressure and speed when mounted on a vehicle . Manufacturers will publish both static and rolling diameter of a tyre at 60 km/h ( bit hard for us to measure a rolling tyre ). Here is the example of a tyre calculator that uses dynamic and static diameter , contact patch size , air volume , tyre comfort suspension value etc. http://bndtechsource.ucoz.com/index/...alculator/0-20 Last edited by SumoDog68; 22-08-2015 at 07:27 AM. |
#14 | ||
But Pies AREN'T squared? They're round.
Crazy Dazz
Kicking Hippies in the Balls since 1966 |
#15 | ||
wow, 10 responses before someone used their high school maths.
![]() Good on ya esppwr.
My ride: 2007 Falcon Ute BF XR8 Orange, MTO. |
#16 | ||
