Old 18-10-2015, 12:37 PM   #1
laserpointer
Default KQ Laser head gasket replacement
Hi all. I am new to this forum and would appreciate some help. I have a blown head gasket on my 2001 laser SR2. Is it possible to change the head gasket and timing belt with the engine in the car. It doesn't seem to have a lot of room in the front of the engine to remove the crank pulley. I have the manual and although it looks a bit complicated I think I should be able to manage it providing I can do it without removing the engine. Any tips would be helpful.
laserpointer is offline   Reply With Quote Multi-Quote with this Post
Old 19-10-2015, 10:52 PM   #2
dirty hands
Over Thinker
dirty hands's Avatar
Default Re: KQ Laser head gasket replacement
yes engine stays in
very quick write up
car stands
support motor on a floor jack and block of wood
undo and remove battery
undo the top engine mount
take off all the parts that need to be removed to get to the timing belt cover
alternator
power steering pump if fitted
dont undo air con compressor pipes ..that unit can be tied up or supported out of the way
for working the bottom part of the engine
take of the wheel and you work through the wheel arch
replace the timing cover seal
where is the water pump ..if driven by the timing belt internally
you would normally fit a new pump
make sure all the timing marks are lined up and marked with white out or white paint
before thinking of removing the timing belt
mark the old belt positions as well and direction of rotation
you may like to take out the starter motor
to hold the crank firm while undoing the crank pully
My car goes Brumm Brumm
Old 20-10-2015, 05:57 PM   #3
laserpointer
Thanks heaps for the reply. Good to know the engine can stay in. Will let you know how I go. Hopefully I will get time this weekend to get it sorted.
